P0420 (Catalytic Converter) and P1116 (Temp Sensor) Repair
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Baby Prius, May 25, 2016.
  1. Baby Prius
    Baby Prius Junior Member
    Oklahoma City, Oklahoma
    P0420: Bank 1 Catalytic Converter Failure
    P1116: Heat Storage Tank Temp Sensor Failure
    Dealer wants $2500 for both. Is there a cheaper alternative?
    Thank you.
  2. JC91006
    16,470
    8,385
    Get an after market catalytic, and you don't really need the heat storage tank
  3. andrewclaus
    andrewclaus Active Member
    993
    324
    Golden, CO
    I agree with the above, with caveats:
    If you live with the P1116 code and ignore the light, you won't know if something else more serious throws a new code. Salvaged tanks are available on eBay for around $200 and you'll need $50 in coolant and the specialized tools and knowledge to change coolant (good threads here on that topic). If you can find a Prius mechanic to put in a used part, total cost should be under $500, half that for DIY.
    If your county has emissions testing, be sure your car will pass if it has an aftermarket cat (should be no problem outside of CA). Parts are about $250 on eBay, it looks like. If you can't DIY, any muffler shop can put that in, total should be well under $500.
  4. Baby Prius
    Thank you both for quick replies. However I'm still quite concerned to replace only the catalytic converter as the dealership stated on the paper they provided: "TEMP SENSOR FAILURE CAUSING CATALYTIC CONVERTER TO OVERHEAT." And if I have to do a coolant replacement I was thinking about waiting until my next coolant service. What will happen if I keep driving with these codes on? Also, do I have to replace the catalytic converter with exhaust system (which is about $300+ on Amazon) or just the catalytic converter? I see on Amazon a catalytic converter for under $50 (by Eastern) but I'm not sure how it will perform or if it will be durable enough (it does have good reviews though). Any specific brand you would recommend? Lastly, how much would be an ideal labor charge for catalytic converter replacement and heat storage tank separately?
  5. andrewclaus
    993
    324
    Golden, CO
    The P1116 code for the coolant storage tank is, as stated in the first response, for a system that's not even needed. It's a sort of an accessory. There should be no way for that sensor to cause the engine to overheat and the cat to fail. Worst case system failure will mean the car runs cooler on start-up, causing more emissions for a few minutes. So the mechanic's written diagnosis makes no sense. If there are no other codes, something else may have caused the cat failure. Could be burning oil, unburned fuel, bad head gasket, road damage, etc.
    As long as the radiator (not just the reservoir) is full, you can drive with the P1116 code until you can drain the system and replace the tank.
    Sorry I can't answer all your cat questions. I think driving it safely depends on the failure mode. If there's any exhaust restriction, that's not good for the engine. I don't know how to check that.
    I've heard of some exhaust system problems near the header from rust, so there may be a good reason to replace more than just the cat.
  6. kswahl1
    kswahl1 Junior Member
    46
    If you don't notice any vehicle performance problems and you don't have to get emissions testing annually you don't really need to change out your converter.
    I just had my catalytic converter changed out for $260 parts/labor (P0420 code was on for 3 years). There are two of them. Only one is monitored; the one closest to the engine. So change that one out and you should be good to go. They just cut it out and weld an aftermarket in. Shop around get some different quotes.
