p0420 code at 60,000 miles??
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by solar, Jul 4, 2014.
  1. solar
    solar Junior Member
    Albuquerque, nm
    I have a 2008 Prius. It now has 98,000 miles and a Po420 code, but it had ~60,000 when I first got a code (I assume it was the same code, but never got it read). I live in NM now. I was living in CA when I first got the code, but it was running fine, I didn't need a smog check (smog check for Prius not required in CA), and the dealer was going to charge $100 to diagnose it. At the time I thought it was a faulty intermittent CEL since I think I had had a faulty intermittent code before on that car, didn't realize an autoparts store could check the code for free, and didn't realize the catalytic converter (cat) would be under warranty. Water under the bridge.
    When I moved to NM 7 months ago, I needed a smog check to register my car. I googled and found I would probably need a $2000 cat, and put off doing anything about it til now. Dealer diagnosed last week ($100) and told me I needed a cat. ($2200), a mechanic then diagnosed ($60) and said I could use a Walker direct fit cat. ($900). Then I went to Midas and they said they would diagnose for free and use a universal cat. (if it can be fit to it) for $430.
    The car has run well the entire time, and gets ~45 mpg.
    1. What are the cops likely to do if they pull me over and find that my car is not registered in either CA or NM?
    2. Which of these cats. would be likely to clear my code and enable me to pass the smog test? Will they do anything for me if it doesn't clear the code/enable me to pass the smog test, or am I out the money and back to square 1?
    3. Does the cat. failing (most likely) at 60,000 miles indicate that something else is likely to go wrong (such as the cat. failing again) even after I replace the cat.? If so, should I just get a new car? I have been thinking about a cmax energi plug-in hybrid, which I can afford, but I don't like to waste $36K if I don't have to.
    Thanks in advance.
  2. Patrick Wong
    18,200
    6,464
    1. Give you a ticket.
    2. Any of those catalytic converters should allow your car to pass the smog check. The difference is how long a particular catalytic converter will last and you can expect a positive correlation between the amount you spend and the service life of the cc. You are on your own if the engine has some other issue besides a failed cc. However if in fact P0420 is the only DTC logged then a replacement cc should do the job.
    3. It is unclear that the cc failed at 60K miles so you should not worry too much about that. Since the vehicle mpg is in the mid-40s that indicates the engine is in basically good condition.
  3. TampaPrius.com
    TampaPrius.com Active Member
    461
    296
    Tampa, Florida
  4. solar
    solar Junior Member
    Albuquerque, nm
  5. Alli
    Alli New Member
    St. Petersburg, FL
    I actually just moved back to FL from the DC area 3 weeks ago. While en route, a bunch of warning lights came on (red triangle, check engine, a few others). My husband was behind me in his car-- he ran a diagnostic and I believe we received that same code. I was advised by a local dealership in SC not to drive it. It turned out to be a recall and took no time to fix and cost me nothing. Maybe this info will help! Also my car was right at 63k miles.
  6. TampaPrius.com
    461
    296
    Tampa, Florida
    Yes, all on Gen II's. There is only one catalytic converter. The other two things that may look like cats are resonators. The cat is the one closest to the engine. I have heard many people recommend "try replacing the O2 sensors first because they are cheaper" however in my experience it has never been the O2 sensor so IMO that is just a waste of money.
  7. solar
    solar Junior Member
    Albuquerque, nm
    Thanks. When I took it to Midas, at first they quoted me for a universal cat. and asked me to come back and get a free diagnosis to make sure the cat was the problem and to see if the universal cat would fit. When I came back they confirmed it was the cat, but told me the universal they had quoted me wouldn't fit and that there were 2 cats in the car. They then quoted me the Walker direct (which presumably wouldreplace both cats) for $750.
    Does it sound like Midas don't know what they are doing and that I shouldn't get the work done there? Or is it hard to screw up the work of bolting in a direct cat? Does the direct cat replace the (one) cat and both resonators all the way back to the back bolts? I didn't like the mechanic (I'm new in town and don't know any mechanics) I took it to that quoted me $900 on the direct cat, so I am not going to give them the work. I don't plan on keeping the car that long (although I may change my mind on that), I just want to pass the emissions and give myself a year or two until the next test. I wouldn't mind saving the money on a universal cat, but I don't want to spend much more time and energy on this problem if I can get away with it.
    Any other advice would be much appreciated.
  8. bisco
    49,056
    sounds like they don't know what they are doing. but if it's the easiest place for you to go, talk to the manager and tell him what you know. if you can't come to a reasonable meeting of the minds, move along.
  9. Patrick Wong
    18,200
    6,464
    You are asking good questions and they should be posed to the manager of the shop. Usually with an aftermarket cc, the existing exhaust system will be cut to the extent necessary to remove the old and fit the new cc in, which will be welded to the existing pipes.
    Ask to see a picture of the replacement part so that you can visualize how much of the existing exhaust system will be replaced.
  10. TampaPrius.com
    461
    296
    Tampa, Florida
    Even the walker direct fit has to be welded on one side. Just buy the Magnaflow on eBay for $90 and call several muffler shops and find one that will weld it on for you. Offer to pay in cash. You should be able to find someone to do it for $50-$100. If you don't have any luck, post an ad on Craigslist for someone to weld it on for you. When you are done the old cat is worth $$$ in scrap.
  11. goldfinger
    goldfinger Active Member
    535
    402
    Buffalo
    Solar, Don't take my word for this, but I think you can pass inspection with one readiness monitor incomplete in any state but CA. See this YouTube video of a guy that reset his codes and drove around just enough to finish all monitors but cat then ducked into an inspection quick. Good luck.
    A Free Fix For A Failed Car Inspection P0420 Code.:
  12. solar
    solar Junior Member
    Albuquerque, nm
    I ordered the magnaflow cat from ebay. I'll keep everyone posted as to how it turns out.
  13. MortenAZ
    MortenAZ Junior Member
    26
    Phoenix AZ
    I had the p0420 code and I went to autozone to borrow a better code reader. Remember to keep the gas tank about half full. I drove around until everything was ready and pulled in and got the inspection. Here in AZ you can test 3 months early, and it's good for 2 years (plus 3 months, in my case). A pending code showed up on the way home, probably due to about half a quart oil burning every 1000 miles. Love this car
  14. solar
    solar Junior Member
    Albuquerque, nm
    I got the Magnaflow cat. recommended. Went to a Midas to have them install it and they quoted $240. I went to a small garage next door and they said $200. I said, I was told it should be $50-100. The guy said 'ok, I'll do it for $100'. Took it back to Midas and told them they would do it next door for $100 and they said that once it was up on the rack, they would tell me it would cost more than $100 at the other place. Then I took it to Meineke and they said $220. This was Saturday and I wanted to make sure to get it done that day, so I let them do it.
    Drove 100 miles that weekend. CEL still off. Came back to Meineke on Monday to get the OBD and they said two readiness monitors still incomplete. Drove about 40 more miles, then yesterday at Meineke they said 2 readiness monitors still incomplete, but they told me if I took it to a certain emissions tester they would pass me. I did and they did.
    Thanks everyone for the advice. I hope the new cat will last me longer than I keep the car (probably less than a year or 2).
  15. MortenAZ
    26
    Phoenix AZ
    Ok thanks for the update. I have an update myself. My p0420 pending code clears itself and doesn't trigger a check engine light. Yay.
