P1118 Check engine light code
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by poisonjam, Nov 16, 2011.
  1. poisonjam
    poisonjam
    Expand Collapse
    New Member
    Chicago
    I recently had someone run a scan on my 2008 prius, which just had a check engine light pop up on it.
    It came back with the following code:
    P1118 MANF. CONTROL FUEL AIR METERING
    how serious is an issue like this, and what's a worst case scenario for what it may cost to fix? (it's not under warranty, too many miles)
    Thank you all for your help,
  2. northwichita
    northwichita
    Expand Collapse
    480
    94
    29
    Wichita KS
    Any issues (from engine) aside from the check engine light?
  3. seilerts
    seilerts
    Expand Collapse
    Battery Curmudgeon
    3,326
    1,445
    38
    Santa Fe, NM
    1118 is for the coolant temp sensor at the coolant heat storage tank. Had a long thread about this one, also a guy from Chicagoland, where the connector was corroded.
    First thing is to check to see if you have coolant in the system, and if you have a leaky engine water pump.
  4. poisonjam
    poisonjam
    Expand Collapse
    New Member
    Chicago
    northwitchita: No other issues at all, car seems to be running perfectly.
  5. poisonjam
    poisonjam
    Expand Collapse
    New Member
    Chicago
    seilerts: i'm not really a car person, is this something one with no real experience working on cars could check?
  6. seilerts
    seilerts
    Expand Collapse
    Battery Curmudgeon
    3,326
    1,445
    38
    Santa Fe, NM
    Let's take a step back. This is covered by powertrain warranty, 5 year or 60,000 miles. Visit a dealer if warranty is applicable.
    Unfortunately, this is not a problem that lends itself to an easy fix. If the car is low on coolant, then there is a leak, probably the water pump. If the connector is corroded, then it needs to be repaired. If the sensor is bad, it needs to be replaced.
  7. poisonjam
    poisonjam
    Expand Collapse
    New Member
    Chicago
    it's not under warranty, it's got over 80k miles on it. i bought it used and i'm guessing it was originally a sales car or something like that.
