Parking a Prius over a month
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by fopoku2k2, Jul 23, 2015.
  1. fopoku2k2
    fopoku2k2 Member
    292
    59
    Columbus - Ohio
    I would be shipping my 2010 Toyota Prius to Africa in a few days. It takes approximately a month to get there. Any advice on what to do to have the car still running on arrival esp to prevent the batteries from going dead?
    A0001 ?
  2. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Difficult, because to and from the ship it will be driven and possibly mishandled. I went to Europe for 2 months and first charged both battery systems, I then disconnected the HV disconnect switch.. When I returned everything was fine. But I was in total control. And I was confident the battery charges would sustain.The stevedores that oversee, move, park, etc cannot be trusted to be knowledgable about the Prius, plus they have a penchant for playing the radios, etc, when bored. Your unfortunately handing over total control to the irresponsible. I wish you luck. You may be able to buy insurance for any malfeasance. Wish you luck.
    fopoku2k2 likes this.
  3. fopoku2k2
    fopoku2k2 Member
    292
    59
    Columbus - Ohio
    So you think 30+ days on the sea without a charge is okay?
    A0001 ?
  4. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    disconnect the 12 volt battery by removing the negative wire from the cars body
    pull the orange safety plug out
    car will be dead..
    hope for the best
  5. Andyprius1
    2,327
    859
    Cool CA
    How can you protect? The stevedores must move the car.
  6. Andyprius1
    2,327
    859
    Cool CA
    Understand, my Prius was in my garage while I was in Europe. Nobody was MIS handling it.
  7. bisco
    49,010
    it's the 12v that is a concern. if you can't do anything about it, pack a booster pack/charger that plugs into african juice.
  8. Andyprius1
    2,327
    859
    Cool CA
    READ POST # 2
  9. jzchen
    jzchen Newbie!
    3,296
    1,006
    Arcadia, CA
    I'm not worried about the HV battery, just the 12V. Disconnect the neg terminal. Hopefully everything will be okay.
    MT2L03 ?
  10. Patrick Wong
    18,200
    6,464
    Plan to have a 12V booster pack with you to start the car as the 12V battery will probably be dead upon arrival. I assume your car is not going to be the first one being unloaded with a dead battery so the dock presumably will have a procedure to deal with that.
    A major problem will be caused if the person jumpstarting the car reverses the polarity of the jump cables, as that may destroy the inverter.
  11. fopoku2k2
    fopoku2k2 Member
    292
    59
    Columbus - Ohio
    Geeez!!! Now we wouldn't want that happening. Anyways can the prius be jump started like regular ice's with a jump start cable and another car?
    A0001 ?
  12. Patrick Wong
    18,200
    6,464
  13. bisco
    49,010
    but not by an african scalawag, make sure you're there to guide her.
  14. fopoku2k2
    fopoku2k2 Member
    292
    59
    Columbus - Ohio
    Hahahahahaha.
    A0001 ?
  15. Blizzard_Persona
    1,787
    944
    Pa.
    2023 Prius Prime
    XSE
    Are you moving to Africa and bringing the car with you permanatly or are you taking an extended trip/ vac or something of the sort where renting a Veh. Once you get there is an option?
    Renting might save you some headaches and worries and money, that is unless this is a permanent move and then disregard my question..
    Where in Africa?
  16. fopoku2k2
    fopoku2k2 Member
    292
    59
    Columbus - Ohio
    this is a permanent move. I am moving to Ghana - West Africa
    Andyprius1 likes this.
  17. bisco
    49,010
    have you checked on prius service after you're there? many of our worldwide friends have difficulty.
  18. fopoku2k2
    fopoku2k2 Member
    292
    59
    Columbus - Ohio
    I know for a fact that the local toyota dealer does not sell prius, but there are a few shops around that service the few prius in town. I would try as much as possible with the help of this forum to do my own servicing.
  19. Patrick Wong
    18,200
    6,464
    Well then, I suggest that you start by subscribing to techinfo.toyota.com and downloading the repair manual sections for your model year to the extent that you are comfortable performing those repairs.
  20. Blizzard_Persona
    1,787
    944
    Pa.
    2023 Prius Prime
    XSE
    I'm not sure how the Gasoline purity is in Ghana, but we did have a member here from Nigeria that had issues with local gas and pretty much wrecked his spark plugs.
    Might want to consider running a bottle of fuel additive to each tank if at all concerned....
