Parting out 2006 Prius in front drivers accident
Discussion in 'Private Sales' started by socaldano, May 1, 2014.
  1. socaldano
    socaldano Junior Member
    St Louis Missouri
    Hello, I have parts, lots of parts. My silver/gray interior Prius II group 7 was crashed last year. It is in Missouri. The car had 110k miles on it, mostly freeway. It was in great shape when it was borrowed without permission and crashed. I was the only owner.
    This is perfect for someone looking for a body from a rear end collision...
    The traction battery was replaced under factory warranty about 2001/2002 with only about 20-30k miles on it. This is $800 plus shipping or best offer
    Engine, trans, MFD (had nav, bluetooth, smartkey).
    The side doors and the body behind the firewall are in pretty good shape, but missing rear hatch and rear passenger lights (sold)
    I am only willing to break up larger components if it makes sense (no I am not going to ruin the wiring harness for a $4 connector)
    I will entertain any reasonable idea....including selling it complete as it sits for a reasonable price..you get it.
    write or call
    hyattdj at googles mail (to avoid bots)
    314 - 473 8713
  2. JC91006
    16,470
    8,383
    Can you clarify the battery for a 2006 that was replaced in 2001/2002 with 20k-30k miles at the time?
  3. socaldano
    St Louis Missouri
    The first traction battery was replaced under factory warrenty at 87,000 miles. I think it was from too much driving up steep grades in the hot hot california desert... but by the time it had failed I had moved to St Louis. The dealership replaced the traction battery, the coolant pump and something else under factory warranty or recall depending on the pump.
    The car was crashed at about 107k miles ..which is about 2 years old and 20,000 easy flat miles.
    does that answer your question?
  4. JC91006
    16,470
    8,383
    Yes that answers my question. Coming to visit CA soon? I'll consider the battery :)
  5. socaldano
    St Louis Missouri
    The battery would have to be shipped unless you knew someone who was driving from STL or Illinios area to Califronia
  6. socaldano
    St Louis Missouri
    Yes, the battery was replaced by the dealership as Toyota provides California bought cars have a 10 year 150k hybrid warrenty on cars originally sold in cali
    Battery replaced in 2011 or 2012 with 87k miles, it went off line with 107 or 110k miles
  7. socaldano
    St Louis Missouri
    2012 not 2002 that would be an awesome trick if I could pull it off...
    The original had 87k miles, the Toyota warrenty replacement has about $20k miles on it.....easy miles flat midwest
  8. JC91006
    16,470
    8,383
    100 lbs (not sure of actual weight) from st. louis to CA is $112 dollars via UPS
  9. socaldano
    St Louis Missouri
    OK....if you got the battery for $800, I would include the first $50 of shipping....I don't mind dropping off at a dock within 10 miles of my house.
