Plastic undercarriage shield
Discussion in 'Gen 3 Prius Main Forum' started by dr_rock, Nov 7, 2014.
  1. dr_rock
    dr_rock Junior Member
    28
    Pennsylvania
    I ran over a curb and damaged the plastic shield under the front of my 2011 Prius. Can I get a replacement and fix it myself? Thanks
  2. situationalawareness
    83
    43
    San Tan Valley, AZ
    I'm wondering the same.
  3. dr_rock
    28
    Pennsylvania
  4. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    You will also probably need some of the plastic push-pins that fasten it.
  5. Mike500
    Mike500 Senior Member
    2,593
    763
    Toyota uses 7mm clips. Two larger ones in the back are 9mm.
