Plug in battery into gen 3
Discussion in 'Gen 3 Prius Main Forum' started by Ensol, Aug 23, 2016.
  1. Ensol
    Ensol Junior Member
    27
    Uk
    Hi i have aquired a prius plug in battery from a 2013 prius! Am windering if i can fit this to my gen 3 2010 model! Can i use both batteries together? Wil yhe ecu reconise the other battery ! Wil i have to make any other changes?
    Thanks
  2. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Without extensive modification, you can't add a second battery to a stock Prius. You -can- buy a "plug-in" kit, but it uses a different battery, not a stock Prius battery.
    JTT2 likes this.
    49,083
    agree^^^ it will not recognize it, it's never been done, and yes, you would have to make extensive software changes. even the add on kits have new controllers. heck, i don't even think you could fit it in.
  4. Ensol
    Ensol Junior Member
    27
    Uk
    Thanks
    Now that am in possesion off this battery what are my best options
    Thanks
  5. BZzap!
    BZzap! Senior Member
    1,607
    877
    EBay.
    JTT2 and bisco like this.
  6. Ensol
    Ensol Junior Member
    27
    Uk
    What are they worth?
  7. bisco
    49,083
    we've never heard of one going bad, so no purchase price yet. you could look and see if anyone else is trying to sell one. iirc, someone in nz, aus or u/k spotted one asking $1,500., but i'm not positive.
  8. Ensol
    Ensol Junior Member
    27
    Uk
    Ok thanks for your help will ring the dealers in morn to get a rough idea
  9. bisco
    49,083
    please let us know how you make out. any idea how many miles on it?
  10. Ensol
    Ensol Junior Member
    27
    Uk
    Mileage is under 6000 was a front end salvage
  11. bisco
    49,083
    wow, you got a good one!(y)
  12. BZzap!
    1,607
    877
    Right now these batteries are probably going to be a hard sell. Statistically, there aren't a huge number of plug-ins out there. The battery being unique to the plug-in puts a real damper on it's saleability. The Nmh batteries typically go for between $800-$1500 on eBay. Your Lipo battery is zero on eBay. OMT, if that lithium battery goes flat it takes special equipment to revive it. If it does go flat, you'll have a 75lb piece of junk.
  13. David Beale
    5,963
    1,981
    Edmonton Alberta
    Wait! Is this the 100 lb+ Prius Plugin battery or just a normal Prius battery? If a normal one it's worth about $2500 new, maybe half that used. The Prius Plugin battery is worth a lot more. It's very large and very heavy. The standard Prius traction battery is maybe 70 lbs.
  14. BZzap!
    1,607
    877
    You're absolutely correct. My mistake. The Toyota Prius Lithium Ion weighs in at 330 lbs.. That is forklift removal time.
  15. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    I just checked Car-part.com (Salvage yard search engine) and the Plug in Prius batteries, Lithium are going for $1105
  16. Ensol
    Ensol Junior Member
    27
    Uk
    Any suggestions wHat i can do with it?
  17. Ensol
    Ensol Junior Member
    27
    Uk
    I also hav a gen 1 which has a hv battery built from gen 3 cells can i connect both somehow
  18. Nougatti
    Nougatti Member
    119
    59
    Norway
    You're thinking of combining a Lithium ion battery pack with a Nickel Metal Hydride one, or replacing the NiMH pack with a Li-ion one? You do realize there would have to be immense software changes? It's not like an AA-battery with a + and a - which hooks up to the car. There are extensive electronic circuits wired into all of this and it's all configured to a specific battery chemistry and capacity. You can't just interchange them willy nilly.
  19. kenmce
    kenmce High Voltage Member
    1,512
    496
    NY
    Unlikely. How experienced are you at working with electrical control circuits??
    Difficult.
    No.
    The entire car is tightly integrated to itself. If you make a random change to the battery the car will probably go nuts. It will know something is wrong, but not how to respond.
  20. Nougatti
    Nougatti Member
    119
    59
    Norway
    The car will most likely respond "dumb". Meaning it won't go anywhere. Probably not start and get to READY either.
    I expect it's programmed with a bunch of self-tests that it goes through before READY is displayed. If any of those fail, it will not start. If it's a "common" problem leading to the test's failure, it will throw that code. All other instances; Nothing.
