Plugin Charger issues
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Mehul, Mar 18, 2014.
  1. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    I didn't see this thread the first time it came around. It was pretty painful to read especially when OP came back after the ordeal with a clueless dealer and with instructions from Priuschat and still didn't understand how to use the timer.
    The timer is really easy to use but it appears it isn't simple to setup. Reminds me of VCR's blinking 12:00. I remember it was common knowledge they were hard to program. I fiddled with it once and managed to get it to record my afternoon cartoons that I missed when the bus was late.
  2. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    So, we have seen now two 2015 PIPs with some Hybrid systen problem!!! What is going on here?? A bad batch of parts from supplier to Toyota?
    52,760
    i'd say 2 is way below industry average. you're not expecting perfection, are you?
  4. GregP507
    GregP507 Senior Member
    3,002
    481
    The timer looks like a last-minute, dollar-store addition to the system, and seems to work about as well as you might expect. That's why I'd use a timer in the supply circuit.
  5. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    I am referring to the following from two new 2015 PIP owners :
    WARNING in the dash, "CHECK HYBRID SYSTEM, STOP THE VEHICLE IN A SAFE PLACE" AND "CHARGE RESULT : CHARGE STOPPED DUE TO SYSTEM MALFUNCTION"
    Read more: Plugin Charger issues | Page 3 | PriusChat
    Follow us: @PriusChat on Twitter | PriusChat on Facebook
  6. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Two as we know it here on the forum. The 2015 PIP hasn't been sold very long and how many of the new owners find their way here to the forum??
  7. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    KISS often does give that impression.
    As for it working, mine has been bullet-proof over the past 2.5 years. Any issue a new owner is having would either be user misinterpretation or a genuine problem with their particular unit/source.
    retired4999 likes this.
  8. retired4999
    2,652
    627
    Eau Claire, Wi.
    No problems here!!
    2.5 years, charging 1-2 times a day every day.
    Timer works flawlessly.
  9. bisco
    52,760
    all the ones with problems.:)
  10. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    A sample size of two doesn't tell us much, does it? Oftentimes, we see defects when a car is brand-spanking new, because that's when a part or assembly defect will most likely show itself.
  11. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Sure does, by the odds. Probably only a few members here with a 2015 PIP, so 2 would be a very high percentage then.
  12. OnePiP
    OnePiP New Member
    SF Bay Area, CA
    2015 Prius Plug-in
    Another PiP owner here. I dropped off my PiP last week with the exact same message: "CHECK HYBRID SYSTEM, STOP THE VEHICLE IN A SAFE PLACE". They say they will be replacing "the charger". The dealership was been a pain to deal with, it seems they had no clue about what was wrong with the car.
  13. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    We are up to three on here and toyota doesn't know what is wrong yet!
    Maybe a separate thread needs to be started to keep track?
    Why would a charger give an out of the blue error message like that? I thought the PIP was supposed to function as a regular prius without ion battery?
    Sounds like more than a charger issue.
  14. bisco
    52,760
    prius screen messages are often difficult to interpret and codes are what is used for diagnosis. what does 'pip was supposed to function as a regular prius without ion battery' mean?
  15. Rebound
    3,996
    2,645
    Portland, OR
    It means, "My car isn't working."
  16. GregP507
    3,002
    481
    Technical opinion: "It's broke."
  17. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Car should keep running even when the lithium ion battery is depleted.
  18. bisco
    52,760
    it does keep running, you just get the scary message.:eek:
  19. bisco
    52,760
    it's just like the message for a bad 12volt or fob battery, 'move car to flat surface and place in park'.:p
  20. GregP507
    3,002
    481
    The hybrid system can't run without a hybrid battery. The plug-in has a larger, lithium-ion battery, with a plug-in virtual partition. It also has a partition for hybrid operations, and another reserve partition, which maintains a minimum amount of energy to maintain system integrity.
    That's the way I understand it, but I defer to those who have some actual expertise on the subject.
