plugless PHV driving stories
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by john1701a, Jul 28, 2012.
  1. Zythryn
    Zythryn Senior Member
    6,408
    4,406
    Awesome stories. So far it does appear there are a number of improvements 'under the hood' that we not apparent in the EPA numbers. Makes it even better for those that go beyond the electric range!
  2. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    In general, the use of extension cords with the EVSE is highly discouraged, no matter the length, mostly because the user is not protected from a potential electrical short should something in the extension cord fail. The other reason they don't want them being used is voltage loss, especially in the cheaper thin extension cords. While the voltage at the outlet might read 120V, by the time it reaches the end of a 300 foot cord using 16AWG wiring, the voltage will have dropped to 91 volts, which is useless for the EVSE. Even with an extension cord using 12AWG wiring, the voltage would drop to 108, which may or may not be outside the spec. To ensure that you could charge, you'd need an extension cord that used 10AWG wiring.
  3. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    I was wondering if anyone else noticed that.
    In order to run an extension 300 feet, it would have to be an extreme cable. I cannot imagine what a 300 foot cable would cost that would be able to deliver 120v over 300 feet. If one even exists.
    With my limited electrical knowledge, I would not recommend anything over 50' and for that I use 12AWG.
  4. Did your trip ever show any EV charging?
  5. devprius
    devprius /dev/geek
    979
    291
    The longest length I've been willing to use is 25 feet using 14 AWG and only when absolutely necessary. It's what I was using at home until I got a 240V EVSE installed.
  6. Tideland Prius
    16,493
    Definitely. You can have all if it displayed.
    HUD - HSI
    MID - Energy Monitor
    MFD - Consumption Screen
    as an example.
    We don't get the HUD in Canada =(.
  7. bisco
    51,501
    no we're flatlanders mostly, and there aren't many opportunities to recharge except the normal hv stuff. the biggest hill i have on my daily commute only maintains the current ev range over a little more than a mile.
  8. john1701a
    john1701a Prius Guru
    12,802
    5,286
    57
    I jumped onto the 70 mph highway today, for the morning commute. I forgot that I had hit the HV/EV button to startup the engine. It wasn't until the MPG average about 5 miles later dropped to 98 that I noticed. Eeek! Of course, that's a heck of an endorsement the efficiency of HV mode for that to happen.
  9. fuzzy1
    10,337
    ... especially when we previously had pictures of non-plugin 2010 with virtually identical results. It will take more careful work to quantify any PiP improvement.
  10. john1701a
    12,802
    5,286
    57
    With factors like vehicle break-in (bearings, tires, etc) also contributing to efficiency, it's going to be virtually impossible to actually quantify that. Fortunately, the goal of not taking an HV efficiency penalty hit from the battery and plug components is fairly easy to confirm.
  11. bisco
    51,501
    i think you're right on as far as break in is concerned. i'm still seeing minor improvements in ev range. last night i left for work with a full charge, 87 degrees and extemely high humidity. set the a/c on 79 and did my 15 mile commute and still had 1.5 miles estimated range left when i got home. a/c really seems efficient on this car.
  12. Same here, I am finding that when I am getting to my closer destinations ( 2-4 miles ) my miles left are significantly higher. From, say 9 miles to 12-13 miles. As a result, should there be a chargepoint, charge times are lowered from one hour plus to only a half hour or less. I am wondering tho, which procedure is more beneficial for the battery, the above, or running the charge down to zero, even if it takes 2-3 days with NO wall charge??
  13. You are right, 78, 79 degree setting has little effect on the charge, Incidently Bisco, you are doing exceedingly well.
  14. bisco
    51,501
    thanks, i have a great commute. 30-40 mph, highway at 55 and back of shopping area at 10-15. 50' of elevation change.
  15. bisco
    51,501
    i wouldn't think it be a big deal either way, but maybe someone has a better answer.
  16. I was wondering how Power Factor enters into the charger efficiency. That is Impedance: Inductive reactance VS Capacitive reactance. This may be irrelevant on a short extension 15-20 Ft, but with long extensions, could affect the cars charger as well as sending your power consumption off the screen. Any double EE's out there WITH a PIP ?
  17. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I don't know if it's true with the PIP but when I continually run my battery in my smartphone to 65% or so, then charge it to full the phone remembers the partial charge and lasts a shorter time. but letting the battery drain to about zero, then fully charge it up restores the full battery capacity.
  18. fuzzy1
    10,337
    I don't have a PIP, and haven't done mains connected power supplies in decades, but any modern device that large should have built in power factor correction.
  19. TY AND POST 77 Both make sense.
  20. JamesCSmith
    JamesCSmith New Member
    59
    I just did a long drive with no EV charging so I got to really test the PiP's HV mode. I drove from Orange County to Vegas and back. It was 530 miles round trip with lots of elevation changes from 500 feet to 4,000 to 2,000 and lots of smaller changes in between. I was pleased with the calculated 59.9 MPG. (display was higher). This seem good considering the AC was on full blast most of the way since it was 110 degrees and I didn't do any P&G or any other tricks to save gas. I use the dynamic radar cruise control 98% of the time and . I "just drove it" at the speed limit (or often lower due to traffic congestion).
    I am glad that with no effort I got a nice MPG for such challenging conditions. But I am a little sad how much this lowers my average. Just a couple weeks ago I had my best tank at 82.9 MPG.
