Possible heater issues?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Kamputty, Nov 14, 2014.
  1. Kamputty
    Kamputty New Member
    Santa Cruz California
    Hi all
    Ok, I just 3 weeks ago had all my fluids changed and a cabin air filters. Ever since, I swear the air heater is not functioning right.
    1. The air seems cooler, not as hot
    2. Repair shop burped coolant line 3 times
    3. The air from floor vent warmer than front vents.
    4. Connected scan gauge 2 and all looks good
    Any thoughts?2010 model
    Kam
    #1 Kamputty, Nov 14, 2014
    48,999
    unfortunately, the prius needs to be burped more than regular cars. have them look at the toyota service manual on line.
  3. Kamputty
    Kamputty New Member
    Could an air bubble explain the temperature difference between the top and bottom air vents?
    Kam
    48,999
    absolutely.
  5. Kamputty
    Kamputty New Member
    cool. MMy plan is
    1. Park car on big Hill pointing uphill
    2. Put car in maintance mode to keep engine running
    3. Turn heater on "Hi" blowing max
    4. Wait 15(?) minutes
    Questions :
    1. Should I open the coolant overflow container cap?
    2. Is 15 minutes too long or short?
    3. Will this require more than one session?
    Kam
  6. bisco
    48,999
    i've never heard of doing it that way, so i guess it would be an experiment. you might try reading through some of the existing threads for help on bleeding the air out of the cooling system. remember, it doesn't work like a regular car.
  7. Kamputty
    Kamputty New Member
    I read on this board about raising the front end and maxing hot air...
  8. bisco
    48,999
    excellent, let us know how it works out!(y)
