Possible to disable 3 warning beeps when opening and shutting doors when keyfob is not in vehicle?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Brian Mel, Aug 15, 2014.
  1. FroggyTaco
    FroggyTaco Member
    211
    59
    Paso Robles, Ca
    I have the same complaint when I make many stops where I'm in eyesight of the vehicle & I live in a low crime area.
    I have found that if you close the door at the first "click" but not all the way it doesn't beep at you. Also because of that slightly ajar door the other doors & hatch will not beep if you open & then fully close them.
  2. RobH
    RobH Senior Member
    2,369
    978
    70
    Sunnyvale, California
    Another possibility is to leave the keyfob in the car, but use the mechanical key to lock the doors.
  3. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    I must be missing something.
    I assume that you press the park button.
    Why don't you press the off button instead?
  4. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    You are in Victoria, I am in Mississippi. In Victoria I would turn off the car as well, but here it is 95F (35C) with about 75% humidity. If I turn off the car even for a minute, it will take 30 minutes for the A/C to catch up.
    Today
    High 96 | Low 75 °F
    20% Chance of Precip.
  5. energyandair
    905
    339
    Victoria BC Canada
    That would be a problem that would lead me to find a way to leave it on too.
    What I don't understand is why your a/c isn't doing better.
    We have a second place in La Quinta California (near Palm Desert) and while we try to find shade, we have often parked in the sun at temperatures well over 100F but the car has never taken long to get the temperature under control. Our Canadian car has no window tinting. If we will be parked for any length of time under these conditions, we use a reflective window shade.
    While you have high humidity, that should not have a large effect on the a/c if you shut the OA intake to the extent that the car will permit.
  6. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Palm Desert may have 5% humidity.
  7. Stevevee
    Stevevee Active Member
    821
    224
    Vermont
    The humidity is a real bear for the AC in any vehicle. After you feel the ac starting to work well, then the recirculate should be used. Whenever we get higher than 65% or more, I use the recirc which gives the ac a chance to work.
  8. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    We are 27 messages into this thread and I feel the need to ask:
    What would a delivery driver (you) do if you had a conventional, non-hybrid car in the same circumstances ?
    If the answer is "Leave it running with the key in the ignition." then I don't see how leaving the FOB in the car would be any different.
    Brian Mel likes this.
  9. Brian Mel
    Brian Mel Junior Member
    To answer your question.. This is my 5th delivery vehicle. I have boughten all my vehicles with about 45k mi and sold them at over 200k mi. As you an tell, I drive a lot. With my conventional cars I leave them on when I am at the customers door since I will only be away for a minute and I can see my vehicle. When I return to the pizza place, when I cannot see my vehicle or when I will be away from the vehicle for more than a few minutes like when I deliver to a hotel, I will turn off the vehicle and lock the car.
    I have always done this and don't think it would be any different with a hybrid. The difference being that with a hybrid, turning it on and off all the time means on every delivery I would have to hit the power button to turn on the vehicle, then drive to the customers house, hit the power to turn it off 30secs - 1 min later hit the power again to turn it back on, drive it back to the shop and hit the power yet one more time to power it off. Now times that sequence for about 120 deliveries a week. That's a lot of button pushes in just one week. Now times that by 52 weeks. That's 25,000 pushes a year not including normal personal driving. Now you see why I want to leave the car on at the customers house.
    Second, leaving the key in the car would just be an extra step as I would then have to remember to take the key back out when I go back in the pizza shop. It's not practical. Furthermore, if the engine is warm, you get better MPG. Going from a cold start it takes a while to build up the MPG. When your car reaches S4 mode you will have optimal mpg. In theory, powering off your car will yield lower mpg than leaving it on for those few minutes.
    And the reason why the power button lasts so long is probably because people don't press it nearly as much as I would be doing on a daily basis. Even taking into account taxi drivers.
  10. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Since you always buy used, you will have little sway with a Toyota dealer, but some mechanic must see you a lot, check with him to see if they have a OBDII programmer.
    If you had a location listed, some PriusChat reader with an OBDII device could say "Come on over with a six pack and a pizza, and I will program it to beep at 0 volume as Jimbo described in post #2" but without a location I can't see that happening.
    docs.google.com/spreadsheet/ccc?key=0Ar6-3mN7UK-CdG9OWlJZT3BjSEpFVjJ4QkJSZ0FLcHc#gid=0
    under the US sheet item 21 might be it. Item 84 seems close.
  11. Mike500
    Mike500 Senior Member
    2,593
    763
    You need to purchase this "mongoose" clone TIS mini-vci Techstream cable off of Amazon.
    I haven't explored the three "beeps." option, but I programmed my door handle to unlock all of the doors and hatch on my 2012 Prius"v," and I conveniently added a third Smart Key to the car.
  12. Brian Mel
    [COLOR=rgba(0, 0, 0, 0.701961)]Is there a way to disable the 3 beep outside alarm when the car is in ready mode and the smart key is out side of the vehicle? I work a job where I exit my car several times a day for a short period of 30 sec - 1 min where it makes no sense to turn off the vehicle especially on cold days where the car needs to warm back up again. I may have 35-40 stops during an entire day and I sometimes work past midnight. The job sometimes requires me to grab items from several spots in my car which means opening several doors and 3 beeps per door can get extremely annoying. Why Toyota didn't allow this to be turned off is beyond me. I have had several people make comments about it and I am tired of defending such a stupid, annoying, useless feature which no other vehicle on the planet has.
    Toyota charged me $50 to customize the beeping and I said this is what my main concern is. Since I was there, I had them remove the reverse beep and seatbelt alarm then I go home to find the three beeps are still there. I called Toyota back only to find out those three beeps can't be removed and I spent $50 for nothing because I can deal with reverse beeping and seatbelt alarms but I need to find a way to get rid of these three beeps if at all possible.
    If Toyota can't do it is there way I can do it myself with a programmer? According to Toyota the best they can do is bring it down to two beeps and the volume can't be changed. I'm looking in the manual and it says something about a wireless door lock buzzer assembly. I'm wondering if that can be disconnected possibly which might disable all the warning beeps for the doors.
    Thoughts?[/COLOR]
  13. JC91006
    16,470
    8,385
    You can simply leave your key (or 2nd key) inside the car.
  14. Easy Rider 2
    1,584
    257
    Ocala, FL
    Or simply turn it OFF......which is about what happens at a stop anyway.
    And if his description is accurate, it won't even begin to cool of in one minute.
  15. bisco
    49,079
    might as well leave it in the car, they can steal it with or without the key.
  16. Mendel Leisk
    38,332
    And insurance rates go up. Isn't it illegal to leave an unattended running car? :confused:
  17. JC91006
    16,470
    8,385
    Is it? I do it all the time
  18. cheizy
    cheizy Member
    94
    129
    Los Angeles
    Yup might as well leave the key in the car... someone can steal your car regardless if you take the key out with you and it beeps. The car is still fully functional.
  19. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
    The only thing I can think of is that if you can't come at the problem programmatically, then look at it mechanically.
    Is there a way to physically override the door switch?
    As a Priuschat Moderator, I have to remind everyone that this is a forum for the open exchange of ideas and information. How people use the information on this site is their own concern, benefit, or problem. The Priuschat Terms of Service clearly state - multiple times - that this site or anyone on this site is not responsible for how an owner modifies their personal property. We are all supposed to be mature adults and responsible for our own actions.
    frodoz737 likes this.
  20. Brian Mel
    Yes. I have posted this before and like always instead of ideas always people say turn your car off it will get stolen. First off, if I can't see my car it gets turned off and locked. But it makes no sense to turn off the car when I am 20 ft away from it dropping off an item in a driveway. I've tried keeping my keys in the car, but then when it comes time to lock the car, I forget they are in there and I have to go back in and grab them. It is just much easier to have the alarm silenced.
    if someone here actually works for Toyota, maybe they know something about the door lock buzzer assembly or a way to bypass it because I'd rather not turn my car on and off several dozen times a day for a 30 second drop off each time.
