Prius 2007 battery replacement
Discussion in 'Gen 2 Prius Technical Discussion' started by Dimitrisgr, Aug 15, 2016.
  1. Dimitrisgr
    Dimitrisgr New Member
    Greece
    hello
    I have a Prius with battery problem.
    I want to ask if anyone knows if can I replace the old nimh battery cells with lithium cells???
    Thanks
  2. JC91006
    16,470
    8,384
    Who makes lithium cells?
  3. Dimitrisgr
    Greece
    18650 cells or 26650 or 38120....
    49,075
    welcome! anything can be done, but no, it's practically impossible. the whole car would need to be retuned. new software, inverter and etc.
  5. Dimitrisgr
    Greece
    The mods that I saw with lithium batteries it is parallel for phev??
  6. bisco
    49,075
    yes, they operate on different software than the mains battery. but they still require a massive amount of engineering to work properly.
  7. Dimitrisgr
    Greece
    Sure.i am thinking to build a battery pack with the same specs (Ah,voltage)with the traction Nimh battery but with lithium cells.i have electronics knowledge to do that but I have some spaces about the Prius working.
    Has anyone do this mod?
  8. bisco
    49,075
    if you're talking about replacing the oem modules with lithium, no, no one has ever done it. it wouldn't be worth the time, cost and effort.
  9. bisco
    49,075
    most people have a hard enough time just trying to replace bad cells and balance everything.
  10. Dimitrisgr
    Greece
    No I mean to replace bad cells from the old battery and install one more parallel with lithium cells ,with external charger..
  11. bisco
    49,075
    okay, yes, i think that has been done, but not since toyota came out with the pip. all the profitability went out of the kits. there are a few people who have done it on their own, and you can find the threads by searching the gen 2 mods forum.
    at the very top of the gen 2 mods forum page, you'll see a special forum for aftermarket plug in modifications. it's all in one place. there's a guy from france, planetaria, who has an amazing system.
    #11 bisco, Aug 15, 2016
  12. bisco
    49,075
    there was a fellow from austrailia who really detailed it out, i believe.
  13. ericbecky
    ericbecky Hybrid Battery Hero
    4,365
    3,210
    Madison, Wisconsin
    Anything is possible with time and money.
    If you want to do it yourself for free, it is not possible.
    What is your budget?
  14. Dimitrisgr
    Greece
    I don't have budget amount yet,because I don't know exactly what to do...replace the old cells with new lithium cells ?instal another battery parallel with external charger??
    What you propose??i have electronics knowledge but I am not sure how to apply it on a hybrid car.
    That is the reason that I need help from the forum
  15. bisco
    49,075
    did you look up the threads i pointed you to? you won't get any current help, no one is doing it anymore. they have all moved on to pure ev's.
  16. dolj
    dolj Senior Member
    7,528
    3,782
    Wellington, New Zealand
    ^^^ What Bisco said above ^^^
    In addition to what people have said above in regards to anything is possible (given enough time and money), I would counter that with just because you can do it doesn't mean you should do it.
    The answer is NO, unless you don't care how much it costs. I think this is one of the times when the cost and effort outweighs the benefit–by a wide margin. The biggest consideration is that to use Li-Ion tech you will need to, either, completely reprogram the Prius HVCU to manage the new Li-Ion battery pack or insert some sort of spoofer to trick the Prius into thinking that the battery contains NiHM modules when it, in fact, has Li-Ion modules.
    You would be better off replacing the existing cells with new NiMH modules and then building a separate Li-Ion battery externally and then linking them.
    No-one, that I read, did a modestly priced job that worked–there were, however, a couple that did a satisfactory job where the cost was not a priority for them.
    You can read all their stories in this forum: Prius PHEV Plug-In Modifications
    As Bisco said, you will probably not get any useful answers in this forum as no-one is doing it anymore since there is a factory solution that does this–the Plug in Prius/Prius Prime.
    Hope that helps.
    #16 dolj, Aug 16, 2016
  17. TMR-JWAP
    TMR-JWAP Senior Member
    6,109
    5,819
    Columbia, SC
    Can you explain to me what doing this would accomplish/what you're looking to gain? Where would a break even point be, once you consider time, effort, reliability and $$ poured into it, as opposed to just installing a 28 cell pack from a 2015/2016 wreck that would cost about $800?
  18. bisco
    49,075
    she probably figures lithium is more advanced, and if it can be done cheaply, why not?
    Dimitrisgr likes this.
  19. Dimitrisgr
    Greece
    Where can I find battery from 2015 with this price?
  20. ericbecky
    4,365
    3,210
    Madison, Wisconsin
    Use google to look up the phone number and addresses of salvage yards in your area. Then call or visit them and ask whether they have the part you want.
    If they don't, ask if they can refer you to a salvage yard that might have it.
    Expand your search area as needed.
    Repeat until you get the part.
    And just for reference, in my region salvage yards do not have packs available for $800. They cost more than that, plus you have to turn in your core or pay a huge core fee, sometimes equaling the cost of the battery itself.
    Additionally, there is no guarantee that a pack that went to a salvage yard isn't already filled with random junk modules. It's a roll of the dice.
