Prius 2008 EU - switching to 15" rim and 185/65R15
Discussion in 'Gen 2 Prius Accessories & Modifications' started by V-Twin, Jul 4, 2014.
  1. V-Twin
    V-Twin Junior Member
    Italy
    Hi all.
    I'm considering the possibility to switch from the 16" wheel and 195/55 tyres to 15" wheel and 185/65, but I can't find any information if the 15" wheel is compatible with the rear disk brake. I assume that the diameter of the disk+caliper is bigger than the drum, so perhaps the 15" wheel will interfere with the brake.
    Maybe someone here has some information about?
    Thank you all.
    PS: sry for my bad english, it's not my mothertongue
  2. Munpot42
    Munpot42 Senior Member
    1,391
    543
    Santa Monica, Ca. 90405
    All I can say is that most U.S. spec Prius had 15" wheels as standard, but I think U.S. spec cars (gen 2) had rear drum brakes, while the gen 3 cars all had 4 wheel disc brakes and most were equipped with 15" wheels. Hope this helps....
