Prius c water pump connector/plug
Discussion in 'Prius c Technical Discussion' started by Daniel912010, Apr 16, 2016.
  1. Daniel912010
    Daniel912010 New Member
    Miami
    Hi everyone, so the enginr water pump on my prius c went out not sure why, upon further inspection I saw that the connector is bad as well and now I'm in the process of replacing it and not sure where to find the plug. If anyone could help of send me a link of where I could buy a replacement, I would greatly appreciate it. Thank you 14608215005931472476923.jpg 1460821521969-457885558.jpg
  2. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    Sorry, can't help you sourcing the parts, but (and you probably realized this as well but I thought I'd mention it anyway just in case) you probably want to fix the connector and re-test before buying a new pump in case it's just the bad connection that's causing your problem.
  3. Montgomery
    Montgomery Senior Member
    2,254
    2,235
    Orange County, CA
    Yeah, it looks like the connector was/is the issue. Heat may have caused this.
  4. orenji
    orenji Senior Member
    5,884
    3,486
    How many miles on your car?
  5. Ksolgallegos
    Ksolgallegos New Member
    Minneapolis
    Hey Daniel, I seem to have the same problem! Did you ever figure it out?
