Prius doors locked and engine running(power on).
Discussion in 'Gen 2 Prius Main Forum' started by randylecc, Dec 3, 2006.
  1. randylecc
    randylecc
    Expand Collapse
    New Member
    Maybe this is on the forum somewhere but I couldn't find it.
    I wanted to leave my Prius powered-on on a cold winter day to keep my dogs warm. I kept getting defeated by the feature that prevents the doors from being locked when you get out of the vehicle with the engine running.
    I finally stumbled on this method. Power-on the Prius. Get out and shut the door. Lock the door with the key(not the remote lock, the little key in the Smart Key fob.) You will have to unlock the door with the key as well.
    The temperature stays at about 50 degrees with the temperature setting on LO.
    This is working well for me but I wonder if anyone knows of a reason why it might be detrimental to the Prius?
    Thanks!
  2. Beryl Octet
    Beryl Octet
    Expand Collapse
    New Member
    1,293
    Abingdon VA
    <div class='quotetop'>QUOTE(RandyMaine @ Dec 3 2006, 09:52 AM) [snapback]356931[/snapback]</div>
    One thing that occurs to me is that someone notices a car running, breaks a window, jumps in and drives off.
  3. randylecc
    randylecc
    Expand Collapse
    New Member
    Yes, I careful where I leave it running. Plus the two dogs are probably a deterrent.
  4. Beryl Octet
    Beryl Octet
    Expand Collapse
    New Member
    1,293
    Abingdon VA
    <div class='quotetop'>QUOTE(RandyMaine @ Dec 3 2006, 10:19 AM) [snapback]356939[/snapback]</div>
    Other than that, I don't believe leaving it sitting like that should hurt anything. I'm planning on doing something similar for home power in case of ice storms, floods etc., with my Prius.
  5. eagle33199
    eagle33199
    Expand Collapse
    Platinum Member
    5,122
    266
    2015 Prius v wagon
    It won't hurt anything - so long as the car is in park. The ICE will turn on as needed, the car will take care of itself. HOWEVER, don't leave it in neutral. if you do that, the ICE won't come on to recharge the batteries, which can be bad.
  6. hobbit
    hobbit
    Expand Collapse
    Senior Member
    4,084
    418
    Bahstahn
    I do this all the time for quick-stop errands. Avoids the whole
    warmup-cycle of engine running after another power-up. Having to
    use the physical key is mildly annoying but the car *is* trying to
    make sure I don't lock myself out. I looked into mods to allow
    using the RF clicker while powered on, but the functionality to
    ignore it is buried deep in the body-ECU code so I gave up on
    that avenue.
    _H*
