Prius Eco 58 MPG vs Prius 54 MPG - What's the difference?
Discussion in 'Gen 4 Prius Fuel Economy' started by cyclopathic, Nov 18, 2015.
  1. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    VVT-i - Wikipedia, the free encyclopedia
  2. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    If you have been reading -all- the Toyota supplied info. (good luck with that! - there is so much now), -Toyota- will be offering a kit to cover the white plastic interior parts. So that becomes a non-issue, though -I- still like the white! So there! ;)
    I am certain that the mileage figures given are EPA measurement method results, probably currently sitting in the EPA "in basket", waiting for adoption. The manufacturerers are still required to do the measurements and submit them. Always subject to further testing by an EPA contractor, of course.
    Now, while lately (last 3-5 years) the EPA numbers are very close to what many get, with just a little work most can best those numbers, some by a lot!
    There has been speculation that the G4 may offer a lot of opportunities to do so (better the EPA numbers). Certainly in colder areas it appears to have advantages over the G3.
    I submit to you my opinion that the mileage improvement of the "model 2 ECO" is due to the measurement methods. Whether it appears in the "real world" remains to be seen.
    As for the special tyres purportedly used, -I- prefer tyres that work as tyres, that is, give good traction, don't fail after "minor" incidents, and don't require "white glove" treatment. The best work well in all weather environments, tyres such as the Nokian WRG3. Just in case you might think my wants are impossible. ;)
    cyclopathic likes this.
  3. cyclopathic
    3,292
    547
    2014 Prius c
    I have considered Nokians on several occasions and the issue with them they don't last in warmer temperatures. Consumer Reports tested ENTYRE2 and the estimated lifespan ~35,000mi well below 80k warranty. The closest Nokian dealer is ~150mi North they are well aware of the issue and don't sell anything that far south.
  4. Mendel Leisk
    38,325
    Ok, valve opening/closing varies, that's different.
    Variable lift valves is something the Civic Hybrid used, worked well. The usual lift was sufficient 90% of the time, improved mpg, but if you had a heavy load the higher lift cams were shifted over, and you got a momentary boost.
  5. retired4999
    2,652
    625
    Eau Claire, Wi.
    What color?
    White Duct tape! ?
  6. goldfinger
    goldfinger Active Member
    535
    402
    Buffalo
    If reduced weight can't fully account for the eco's improved MPG:
    • Could it sit slightly lower
    • Tweaked engine software
    • Tweaked cam
    • Different tires
    • Is it missing a mirror
    • Better binned inverter parts?
  7. Mendel Leisk
    38,325
    Just dragging out stuff from my Civic Hybrid experience, yup: tweaked cam is a possibility, and maybe dual spark plugs per cylinder?
  8. GasperG
    GasperG Senior Member
    1,168
    598
    Slovenia
    2018 Prius
    No you can't, because there are numerous occasions where you want sub 10 kW of power from the ICE, even at 1,000 rpm at WOT in 1.8 engine there would be too much power.
  9. cyclopathic
    3,292
    547
    2014 Prius c
    they are doing it now on the very same 1.8 engine in Prius aren't they? actually they are running it 20 to 40% WOT, just enough to ensure low manifold vacuum, ~1.5psi
  10. Tideland Prius
    16,081
    Sorry, couldn't resist. :D
    Tracksyde and Mendel Leisk like this.
  11. Gokhan
    Gokhan Senior Member
    4,394
    1,789
    Paramount CA
    I'm thinking that the Prius Eco's CVT works in some permanent Eco mode, as you could do by pushing the Eco mode on the regular Prius. I think the weight reduction only accounts for a small part of the fuel-economy gain, the rest coming from the CVT permanently running in some Eco mode.
  12. Mendel Leisk
    38,325
    ECO mode pretty much does squat.
  13. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    Maybe the Eco model's Eco Mode is different.
    Maybe Eco Mode for all Gen 4's is different
    Maybe the Eco model's default start-up is in Eco mode so the EPA testing for it is done in Eco mode with the other models tested in Normal mode, their normal start-up mode.
    OTOH, maybe not. At this stage its speculation.
  14. Mendel Leisk
    38,325
    IIRC, Toyota's said all the modes have been shifted, in the direction that the 3rd gen pedal Normal response will roughly equate to ECO in 4th gen.
  15. bisco
    49,075
    maybe they filled the chassis with hydrogen.
    kgall likes this.
  16. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    And the super LRR tires, but the rubber can't contain the H2 very well and so need to be refilled every time you refill the main tank every several days.... :)
  17. kgall
    kgall Active Member
    984
    152
    Olympic Peninsula, WA
    bisco and Jeff N:
    They'll stay that way until the Hindenprius disaster, which will cause everyone to change to helium.
    Jeff N, bisco and bwilson4web like this.
  18. Gokhan
    4,394
    1,789
    Paramount CA
    US Prius 2016 just went online at toyota.com today. So, it's not the weight. It's not the battery. It's not the tires. The only variable that is left is a different CVT programming for the Eco.
  19. bisco
    49,075
    why is it not the tyres, high performance windscreen and rear wiper?
    #99 bisco, Jan 5, 2016
  20. Gokhan
    4,394
    1,789
    Paramount CA
    Same-size tires. LRR or not makes almost no difference. Weight difference is only 40 pounds between Prius Eco and Prius 3 or 4.
