Prius Noises
Discussion in 'Gen 2 Prius Technical Discussion' started by ifosso, Jan 9, 2007.
  1. ifosso
    ifosso Junior Member
    Forks Township, PA
    Noticed two strange noises I can't figure out, though I'm sure their normal.
    After turning on car and hitting break while not moving I hear what sounds like an electric motor doing something behind the dash. Lasts about 3-5 seconds.
    When turning the car off and getting out, for 10-15 second I hear an electric motor run, I think I heard this before on my last car (Mazda 3).... almost sounds like something is getting wound up as the pitch changes right before it stops.
    Any ideas what these are/do?
    Thanks.. Ian
  2. Beryl Octet
    Beryl Octet New Member
    1,293
    Abingdon VA
    After you turn it off, it pumps the coolant into the thermos so that it's toasty when you are ready to drive it again next time. One of those things that makes you go "why doesn't every car do that?".
    The other noise you describe is a pump pumping up pressure in the brakes.
    Both of these are perfectly normal.
  3. member
    member New Member
    202
    These are listed in the manual.
  4. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Turn off the "tunes", roll up the windows and listen to the car. If you watch and break lightly up to a stop light you will hear MG2 as it generates electricity and slows the car. You can listen to ICE on and ICE off. The display will not always tell you this.
  5. orrink
    orrink New Member
    I've noticed a weird sound from behind the dash also. Sounds like a very faint party noise maker, the kind you twist and spin in your hand. Am I nuts?
    <div class='quotetop'>QUOTE(Display Name @ Jan 10 2007, 09:57 PM) [snapback]373950[/snapback]</div>
  6. Bill Merchant
    Bill Merchant absit invidia
    4,096
    58
    <div class='quotetop'>QUOTE(orrin kohon @ Mar 15 2007, 09:46 PM) [snapback]406586[/snapback]</div>
    You may be, but that is the brake accumulator pump. It pumps up pressure in a reservoir to give you hydraulic braking if you need it.
    There's an old saying that your car doesn't have to go, but it has to stop. The Prius has three braking systems, to make sure you can stop when you need to, plus ABS and VSC to give you better control in emergency stops.
