Prius operating costs vs. another midsize car
Discussion in 'Gen 3 Prius Main Forum' started by cycledrum, Jan 27, 2011.
  1. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Since buying my 2011 Accord Coupe and experiencing the difference in fuel economy from my 2nd gen Prius, I decided to look at the bigger picture of operating costs for comparison - gas, insurance, registration and maintenance, and resale after 7 years, and found..
    at 6k miles driven per year, Coupe ~ 39 cents/mile, Prius ~ 30 cents/mi
    (Not sure of costs at 12k/yr as I don't have insurance rates for that).
    This is a surprising amount, but it goes down with higher miles driven. However, a resale loss after 7 years would be as much as operating costs. My car was $28.5k OTD. If I drove it 42k miles and sold at 7 years, $13k resale might be pretty close. That would make the purchase cost ...
    $15.5k loss / 42k miles = 37 cents / mile
    which means the total cost at 6k miles driven /year would be 76 cents/mile ! Can you imagine, every mile driven, ka-ching, 76 cents goes away, wow! A 20 miles round trip to the mall costs $15 !
    But, if you resold a Prius III in high demand times after 7 years, you might lose only
    (($24.2k purchase x 1.1 OTD) - $16K (high resale)) / 42k = 25.3 c/mi for total cost of ....
    Prius III = 55 cents / mile total w/ high resale @7yrs that's a 27% savings !
    So, it seems a moral to the story would be, if you don't drive very much, maybe buy a cheaper car. And if you do drive a lot, go ahead, buy a pricier car, but keep it for 100k miles or more :)
    Coupe w/ 6k per year insurance coverage, $3.40/gallon
    Gas: 26 MPG = $.13 / mile
    Insurance: $1,058/6k = $.176/mi
    Reg: $350/6k = $.06/mi
    Maint: $150/yr = $.025/mi
    = 39 cents / mile
    Prius III
    Gas = $.068
    Ins: $950/6k = $.158/mi
    Reg: $300/6k = $.05
    Maint: $150 / 6k = $.025
    = 30 cents / mile
    Note - registration costs go down, but low maintenance figures likely balance that out.
  2. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    Why do you show lower maintenance cost/mile for the Coupe than the Prius?
    Based on your input data it should be the same
    I would actually expect the Prius to cost somewhat less
  3. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Good catch, that's a mistake. It would take more work to amortize the 7 year maintenance cost. Also, first 2 years of Prius maintenance is free!
  4. fuzzy1
    10,279
    My calculations are always based on the risk of having to scrap the car prematurely at 150k miles.
  5. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    That could be looked at too. Can really start saving if keep car 'til its old, then drop comp and collision coverage.
  6. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,999
    Fort Lee, NJ
    I did my own calculation before too. Owning a midsize Prius cost less than a compact non-hybrid.
  7. Tideland Prius
    16,211
    But why compare it to a compact and not a midsize? Granted, the difference would be larger since a midsize would more likely have a larger engine and larger fuel bill as well as potentially higher insurance costs.
  8. usbseawolf2000
    14,487
    2,999
    Fort Lee, NJ
    Just pointing out how low it is.
    You knew this is coming... here we go...
    Certain compact plugin hybrid cost more to operate than a midsize Prius.
  9. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Aha, so are you saying a certain car (a plug-in) is not a hybrid?
    hehehehe .....
    Ohhh wait, you just called it a hybrid above .......
    nevermind! :)
  10. Tideland Prius
    16,211
    lol
  11. SmogSlide
    SmogSlide Member
    128
    17
    Melbourne
    lol
    I would still not want to bag GM for what they have done with the Volt, given their historical track records. Only if Holden (GM Australia) brings it here and cheap, then there is a mighty competition to the Prius. A fair bit of people at work have been asking about it but when I told them the price, the interest just fall away... they would be better off getting a locally produced petrol guzzlers instead.
  12. mickey513
    mickey513 Member
    127
    Cali
    Shouldn't the main battery be factor in also? Sure it's going to last about 100k - 150k miles but it's like a $3k-$4k part (2nd generation) before labor cost. Non hybrids don't have to worry about this.
  13. SageBrush
    SageBrush Senior Member
    11,627
    2,531
    Southwest Colorado
    ^^ if the failure rate was 100% at that mileage range, then sure. But it is much less than 0.1%, so the average cost for that ownership interval is $3 assuming no warranty.
  14. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Since most Prius do not experience battery failures, this would not be included in the calculation. If you wanted to add it then you would need to add in either engine or trans failures for the non-hybrid. Because of lack of failures for any of the above items in a Prius, I would suggest not even considering them in this exercise. :)
    R epairson the Prius battery are if little concern to anyone who does a bit of research to find that batteries can be replaced for less than $1000 or up to $2000 if you can't do it yourself.
  15. ETC(SS)
    6,588
    Actually, ALL Priuses will experience battery failure eventually...but they will also experience engine failure as well, IF they 'live' long enough. You're right though. Battery failures are no more a factor in determining the TCO for hybrids than ICE failures are for non hybrids, since you usually presume a service life of between 100,000 miles and 200,000---depending on who is bending the numbers. Batteries on Priuses with less than 100,000 miles on the clock are still under warranty, and Priuses with over 100,000 miles (mostly G2s) aren't reporting large battery failure rates. Also, if you live in a CARB state, the battery warranty is extended to like, 150K if my memory serves. So.....battery life in a non-issue in TCO calcuguessing. Initial battery (and other Hybrid component) costs are a factor, but you can usually glean a fairly rapid return for that 'premium' even with gas at (this morning’s price of) $2.75.
    There are just too many factors out there that will change the TCO for a mid-sized car---if you're one of those selfish, earth-killing people that "have" to have a mid-sized car, when a small car will do. My personal opinion (current value < $0.02) is that the Prius is probably one of the cheaper mid-sized cars out there to operate for 100,000 miles...and you get the added features of being able look down your nose at people who "have" to have an even larger vehicle to meet their needs....and you can also look down upon those who can't swing the initial $24,000 for a new G3 and have to settle for a $15,000 Yaris or Aveo, since the G3 is more "earth friendly". :D
    Most people use more than just the TCO (Total Cost of Ownership) and the EKF (Earth Killing Facor) and the CCO (Creature Comfort Options) and the all-important KCF (Kid 'Coolness' Factor) for deciding on which car that they drive, and that's just fine with me! If there were just one "best car" out there.....the morning commute would be a lot more boring!
    Like they say in the Motorcycle Safety Classes....YOU have to ride YOUR ride. :cool:
  16. Tideland Prius
    16,211
    Well a Vancouver Prius cab that has done 1,000,000km (2005 model) said that they replaced the battery at 700,000km (no mention of cost). Most people won't reach 700,000km until the car is 20 years old. Most 10-15 year old Toyotas are between 300,000 and 500,000km if at all. (In my city, 10 year old cars are usually in the 200,000km range as we don't have massively long commutes or need to drive 2 hours to get to hockey practice like other parts of Canada).
    Oh and the battery is US$2,100 before labour costs.
  17. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,156
    333
    nj
    no brake jobs on a prius for 150,000 miles
    you would do 4, 30,000 mile front brake jobs (not the 5th because it's being scrapped at 150,000) and 3 rear brake jobs on the accord.
    how much is that worth?
  18. evnow
    evnow Active Member
    816
    155
    Seattle, WA
    2013 Nissan LEAF
    Here is some rough calculation I did sometime back ...
  19. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Another thing the Prius or any full hybrid saves you is some ....
    >> time
    There is no waiting for the oil to circulate after powering up, just ready it, flip it in gear and go.
    Conventional cars - start it up, wait 20 seconds or so for oil to circulate, then put in gear.
    If you're just backing out into the driveway to vacuum it out or whatever, you save some time with a Prius.
  20. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    It's a well known fact that Camrys still outsell Prius' by a wide margin. It's due to apparent cost.
    Toyo Sunnyvale's ad for Prius II shows $22,988 where Camry LE $19,788 which I think Avg FE is ~ 26 MPG.
    So, to make up that $3,500 difference w/ tax @ 6.2 c/mi difference, it will take 56k miles, but for those that drive a lot, it's very doable.
    But the average person doesn't know that Prius brakes last much longer than conventionals, they are often looking at purchase cost (just get us home with the car and we'lll deal with the rest later).
    If you must seat 3 adults or big children across the back, Camrys got the edge at 4" wider.
