Prius out to race track, 15mpg
Discussion in 'Gen 3 Prius Fuel Economy' started by Bellwilliam, Nov 8, 2010.
  1. Bellwilliam
    Bellwilliam New Member
    LA
    I own 2 races cars. I knew I had a ton of students. didn't want to tow race car there, taking students out (need to add a passenger seat, harness), car is loud (can't talk to passenger), just too much hassle. cost is much less in a Prius.
    like you said, it is always more convincing if you do it in a Prius than a race car (then it is the power, tires, suspension, or whatever they can think of).
    I will probably get a set of cheapo, but better tires next time. probably XS or something similar. should be able to dip below 1:40s with it.
    for those of you taking it to track. trick with Prius is brake release and trail brake
  2. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    So you disable the traction control for your track runs?
  3. Bellwilliam
    LA
    didn't know how. and I am 90% sure you can't.
    let me know if I am wrong.
  4. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    I am 100% sure you can. :)
    Keep in mind Prius traction control is not to help or provide traction but to ease the load step on the MG's with sudden wheel spin. Therefore it is more dangerous than in a normal car for different reasons.
    I did it thismorning to get out of my street (8-10 inches of fresh powder ontop of a nice layer of thick ice up a steep grade to the access road). Wheel spin in necessary!
    As for how:
    1) Car off
    2) If not on flat surface, apply parking brake
    3) Turn on, (Not READY) -- Press Power button twice, with no foot on brake
    4) Pump gas pedal, pedal to the metal, 3 times
    5) Shift to neutral (note: this requires you to press down the brake pedal then hold the shifter over for a second or two. Release brake pedal after in neutral)
    6) Pump the gas pedal, pedal to the metal, 3 times
    7) Face towards Japan and sacrifice a small woodland creature to the Toyoda empire
    8) Put back in park
    9) Pump gas pedal 3 times again, same deal
    10) Car will beep, MFD will display "Problem!" and have a car with an '!' in it.
    11) Step on the brake, press the power button.
    Car will now be READY with the "Problem!" error. The engine will always run and not shut off regardless of stage. Traction control and stability control is disabled.
    If your wheel spins and then suddenly gets traction, all that excess energy is funneled through MG2 (I think MG2). That means lots of current, so overheating of the motor windings, perhaps other bads. Toyota explicitly states to never ever ever ever drive in this mode.
    And step 7 is merely a suggestion, it could be skipped if you are in a rush. :)
  5. Bellwilliam
    LA
    wow, that's great to hear. I am sure I can drop another 2 seconds with that.
    I actually had a student that was a Toyota car designer, asked him about it, he said no. :rolleyes:
  6. Grumpy
    Grumpy Function > Form
    H-town to SoCal
    Keep us posted on the result of further testing. At poor mileage of 14mpg, the smile per mile is through the roof. Tires screams and hanging on for dear life make me lol
  7. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Does that also turn off the stability control? On my other car I can turn off the traction control but the stability control remains on unless I turn that off too.
  8. Zythryn
    Zythryn Senior Member
    6,173
    4,168
    Awesome, thanks for the video!
    Looks like a fun track, would love to see how high you could get the Kwh/mile in a Tesla Sport Roadster.
    Would need to adjust the suspension a bit to help with the understeer but with all the turns the 100% torque from zero should help immensly:)
  9. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    It disables everything. Don't be using this unless you know what you are doing. :cool:
  10. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Thanks for the info. I wouldn't disable it unless I was doing a track day. I'm already slow enough in my Corvette that I don't need to drive a slower car:D
    It would be a good excuse though:thumb:
  11. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    I bet it is A LOT faster than mine was... Stock run flat tires and fast shifting after ECU programing made for a rather frustrating day at the track lol. Not to mention your car is just way faster period. :)
    [ame="http://www.youtube.com/watch?v=WWOpQeq9r-E"]YouTube - F8L C5 Spin.wmv[/ame]
    http://www.youtube.com/watch?v=6YU67Y1bYH8
  12. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Don't underestimate my slowness:D
  13. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Very cool--thanks for sharing.
    I agree--the handling and braking of my Prius V is surprisingly good as well (though I've never taken it to a track).
  14. sfadchi
    sfadchi Junior Member
    17
    Boynton Beach, FL
    WOW! Not a bad lap time at all!
  15. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    I think this probably is the best way to get people to realize that the driver element is more important than the car. When the average Joe sees a Prius whipping around a track they might get a cognitive "does not compute" error forcing them to reevaluate what they thought about anybody in a fast car can go fast.
  16. flareak
    flareak Fleet Captain
    1,016
    St Louis, MO
    Dang. I need to move to LA and take some of these classes. I really wanna learn on a track, but it's kind of embarrassing going to a class with a Prius :p
  17. Chad's Dad
    Chad's Dad Junior Member
    35
    Austintown, OH
    Thanks for posting that. But why did you let the Vette pass you? :)
    I always thought it would be interesting to try and run a Daytona 500 with a Prius fleet, with no stops for fuel.
  18. cossie1600
    cossie1600 Active Member
    898
    92
    CT
    glad I am not the only one that's been on the race track. I do have these things sitting at home, but I think the Prius is retired from competition as the traction control is no fun
    Shot at 2010-10-16
