Prius Rear Bumper Cover loose and gap?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by prius_speed, Jun 29, 2013.
  1. saulbassfan
    saulbassfan Senior Member
    979
    3,108
    Southern California
    I have a few kenstyle plates coming in. PM me if you want to buy. Thanks.
    See my bumper
    ES44AC, sfv41901 and Bagito like this.
  2. Bagito
    Bagito Junior Member
    32
    Los angeles
    How much? I'm interested.
  3. StarCaller
    StarCaller Senior Member
    1,275
    726
    Cedar Crest, NM, USA
  4. Christian_cool
    Christian_cool Junior Member
    92
    17
    Germany
    i also have the issue on my 2010 Prius, and my dads 2012 plug in also have the gap at the bumper but we haven't applied any pressure to the bumper. Maybe this issue is common on the Prius model. I know there shouldn't be this kind of issue, but i am keeping away from the rip off dealer avoiding getting any stupid excuse they would provide me "that its my fault".
    I will later when i get time take of the bumper and find out how it can be fixed!
    Greetings
    Christian
  5. alexendra
    alexendra Junior Member
    17
    17
    Kaohsiung,Tawain
  6. alexendra
    17
    17
    Kaohsiung,Tawain
    00:05 release the screw.
    00:20 release the screw.
    00:40 Bend the clip(P3 MC Only).
    01:00 Pull the bumper cover.
    01:25 Clean the retainer position corresponding to the first and the third clip of bumper cover.
    02:16 Prepare the PVC pads. Clean them and paste double coated tape on one side of each of them.
    04:05 Paste one PVC pads onto the retainer position corresponding to the first and the third clip of bumper cover.
    05:25 push the bumper cover into the retainer.
    06:00 reinstall the two screw slightly.
    The bumper's gap problem is solved.
  7. Xterra72
    Xterra72 Senior Member
    1,432
    1,679
    @saulbassfan, can you please post the install instruction diagram on the bracket gap reducer.
    I'm trying to understand how it is installed on the rear bumper.
    I think a visual on the install diagram will help
    I am referring to the install diagram shown on your pictures the brackets are on top of.
    Thanks
  8. alexendra
    17
    17
    Kaohsiung,Tawain
    Kenstyle plates are designed for Kenstyle's body kit. Cause the bumper cover set of Kenstyle's aero kit is heavier than original. It needs something to support the bumper cover.
    The installation is phase the plates to inner side of the bumper cover.
    The install instruction diagram as shown below.
    #48 alexendra, Jan 18, 2016
    saulbassfan and Xterra72 like this.
  9. Xterra72
    1,432
    1,679
    M,
    Thank you. It makes sense now.
    saulbassfan likes this.
  10. Xterra72
    1,432
    1,679
    @saulbassfan or @alexendra,
    Just to make sure I'm looking at the diagram correctly can you please confirm.
    The brackets are installed inside of the actual bumper shell (with 3m tape) and the notch on the bracket lines up with the bumper lip notch.
    When this is all done, then the actual bumper shell slips right back into the body plastic panel.
    Does that make sense??
  11. xliderider
    xliderider Senior Member
    8,138
    3,274
    Honolulu, HI
    It would seem to be easy to fabricate these brackets if the proper measurements were obtained. Wasn't someone going to do some CAD, as in cardboard aided design? :D
    kenichols29 and Burna J like this.
  12. saulbassfan
    979
    3,108
    Southern California
    Correct. It is pretty much a shim.
    Xterra72 likes this.
  13. torparts
    torparts Senior Member
    417
    643
    Compton
    agreed....it should cost no more than $10 bucks to do.....in china less than $3 bucks....
  14. Mendel Leisk
    41,043
    Is the shim gonna work long term, or would the gap re-open over time, shim and all? Who knows.
    If someone can supply numbers I'll draft and post a pdf.
  15. Mendel Leisk
    41,043
  16. xliderider
    8,138
    3,274
    Honolulu, HI
    As long as the mounting tape/adhesive holds, it should be permanent. If the adhesive fails, it can be removed and new mounting tape applied.
  17. alexendra
    17
    17
    Kaohsiung,Tawain
    The kenstyle brackets really can reduce the gap. But brackets have 1mm to 2mm thickness ,and the tape thickness is about 2mm. When installing the kenstyle brackets, the bumper cover will be a little protruding.
    #57 alexendra, Jan 21, 2016
  18. alexendra
    17
    17
    Kaohsiung,Tawain
  19. mindfk
    mindfk Junior Member
    16
    United States
    Since no one is willing to post dimensions of these plates I did a quick scaling in CAD assuming that the instructions are printed on an A4 paper. Below is what I came up with: Plates.JPG
    Someone, please confirm this...dims in metric.
    kc410 and mrstop like this.
  20. Mendel Leisk
    41,043
    I used to have to resort to this crap all the time, looking at partially undimensioned vendors drawings, laying a scale on the screen, entering values into a ratio equation to extrapolate, PRAYING that it was to scale, lol. Here's my take, similar to yours. Can't see how to get that upstanding lip dimension, just eyeballed it. probably close enuf for government work:
    kc410, Mr. F and mrstop like this.
