Prius shut-down problems
Discussion in 'Gen 2 Prius Technical Discussion' started by Fixmyprius, Aug 14, 2008.
  1. Fixmyprius
    Fixmyprius New Member
    Prescott,Az.
    Hey All,
    I have a Prius(06) and a Highlander(07),both were wrecked and exhibit the same problem. They will start and run for just a few seconds. They will restart and run again after disconnecting the battery and removing main battery key for a few minutes. However,this procedure will again only buy you a few seconds of run time.
    Thanks All
  2. mingoglia
    mingoglia Member
    846
    Gilbert, AZ
    So by run do you mean the engine will kick on, then off? Or are you saying it appears as if they completely shut off? When it exhibits this behavior are there any lights on the dash? Is the speedometer on displaying 0 and the ready light on?
  3. Fixmyprius
    Prescott,Az.
    Mingoglia,
    Thanks for the quick reply. I will try to better explain the problem,althought I wasn't driving it myself.
    The gasoline engine shuts down and the main battery is not charger up enough to power the car.
    Lights remain 'ON' on the dash and not sure of speedo reading.
    Does this car(s) shut itself down if there are problems present ?
    Thanks again,
  4. Patrick Wong
    18,200
    6,464
    I suggest that you will need to plug an OBD-II code reader (which is compatible with the Toyota CAN protocol) into both vehicles, and see what DTC are logged.
    Regarding the "main battery key", if you mean the orange interlock switch on the driver's side of the traction battery, note that on 2G Prius the switch must be put into a vertical position, then it needs to slide to lock into place. If you do not slide the switch, then it will cause error codes to be stored and the hybrid system will not work.
  5. richard schumacher
    7,663
    1,038
    United States
    Does the "Ready" light appear on the dash?
    You do know that the engines are not supposed to run continuously, right?
  6. Fixmyprius
    Prescott,Az.
    Richard,
    As I mentioned on the earlier post ........there was another guy driving it this morning,so we are not sure if the ready light was on or not. Again, as I mentioned before both of these cars were wrecked. They are both in simular stages of re-construction. Also, both of them had frontend damage.
    I ran some codes on it and there are ABS codes shown on the Prius and AIRBAG codes shown on the Highlander.........and they both have the same problem. They start gas motor and runs and shows a charge going to the battery. The gas motor only runs for 5-7 seconds and I don't think there is not enough charge left in the big battery to run the car.
    Does the car run a system scan upon starting and if it finds serious problems ........does it shut down all systems ?
    Thanks again..........
  7. richard schumacher
    7,663
    1,038
    United States
    All I can say is, good luck. A salvage Prius is not a hobbyist car except for people who have a lot of time, money, and the complete shop manual.
  8. khooper
    khooper New Member
    2001 Prius
    Could be the fuel pump. To check for sure take the air cleaner off (or the "neck" that goes to the air cleaner) and spray some carb cleaner or starter fluid in it pointing toward the motor. If it runs for a second that tells you there is a fuel delivery problem. You might want to start by checking the fuse to your fuel pump. Sometimes the obvious can be overlooked.
    _______________________
    A Real Auto Dude Drives Safely
  9. Fixmyprius
    Prescott,Az.
    Hi again,
    Let me get back to the question of what I would like to find out. Both of the cars Prius and the Highlander were wrecked front end damage. Both of them have been repaired/painted. Scans have been run on both of them. The Prius has ABS codes and the Highlander has Airbag codes. ALSO, both have spongy brakes at this time.
    Do Gen 2 Toyota's run a system scan upon starting ? If it finds serious codes does it shut down the gasoline engine and block the car/cars from switching to the battery mode ? Both of these cars start immediately after dropping all power to them for a few minutes......However the gas engine will only run for 6-8 seconds and it will not switch to electric motor. I am sure both of these have the same problem as they behave exactly the same. Although both batteries for the electric mode are low....how many 'bars' does it take for the car to run in electric for even a short time ?
    Thanks all for any help.
    Mike
  10. Tchou
    Tchou Member
    161
    I know that there is an AC charger designed to give the traction battery enough charge to let the car operate by itself, I'm not sure of what happens if the battery is not charged enough but the behaviour you describe might be it...
    1 purple bar should be enough to start the car, it will then not stop the engine until the battery is charged enough to at least 2 purple bars...
  11. Patrick Wong
    18,200
    6,464
    Hi Mike,
    My guess is that both of your vehicles have logged DTC codes that go beyond ABS and airbag issues. One clue is that you say both vehicles have spongy brakes. In that case, the skid control ECU should have logged a DTC. Your vehicles may also have traction battery ECU and/or hybrid vehicle ECU codes that your scanner has not picked up.
    What warning lights appear on the dashboard? Do the cars become READY?
    If the issues were limited just to ABS or airbag, the cars should run. If your scanner does not allow retrieval of the other codes, you may need to have the vehicles towed to a Toyota dealer.
    To answer your question, both Prius and Highlander Hybrid have a feature where serious fault codes will prevent the car from running. A fail-safe chart is provided in the diagnostics portion of the repair manual for each drivetrain-related ECU. That chart shows how the car will respond, given a particular DTC.
    When you say that the traction battery SOC is low, how many bars are appearing? Please note that it will not be easy to have the traction battery recharged - I understand there may only be one charger available per Toyota sales region.
  12. galaxee
    galaxee mostly benevolent
    9,810
    464
    MD
    well, this is a shot in the dark here (as are any other guesses made without the actual diagnostic codes) but the engine room wiring harness is susceptible to damage in front end collisions. my husband replaced 1 in each toyota hybrid model one week due to front end collisions.
    i really hope that's not the case here, because it's an expensive part and a major pain in the nice person to replace.
    re: the HV charger, the likelihood of getting a regional rep out to recharge an out-of-warranty battery is nil, cost is about the same as a new battery pack but with about 1000x the hassle.
  13. Patrick Wong
    18,200
    6,464
    Hi Galaxee,
    Amazing photos...how much time does that job take, and can you pls estimate the cost of the wiring harness?
  14. statultra
    statultra uber-Senior Member
    796
    30
    Edison,NJ
    2001 Prius
    where did these cars get hit? its most likely the hybrid vehicle control ECU triggering codes. If it got hit in front the harness plugs by the electric motor may have been damaged, these can be purchased as connectors and using electrical wiring diagram can be repaired.
    do not run the vehicle if it does not charge the HV battery, this can result in low SOC and the vehicle would never start after that unless you get one of those rare "toyota chargers"
    this happened to me on my 01 prius, i ended up having to create a charger for the HV battery and charged it up, most likely the problem you describe is a issue with the high voltage system.
    if you could provide more info on where the cars were hit, and the pictures if possible.
    i have worked on the 2001 and 2005 prius both crashed, pretty severe.
    and both are now on the road fine.
  15. Bob64
    1,540
    92
    Virginia
    Out of curiosity... Wouldn't it be possible to use another prius as a "charger?"
    I mean, perhaps someone would be willing to temporarily connect the troubled battery to their own prius to allow it to charge up? Bam, no regional rep required.
  16. Danny Hamilton
    Danny Hamilton Active Member
    926
    94
    Greater Chicagoland Area
    Um? If his car won't work with that battery, why would someone else's?
    Or are you suggesting finding a way to connect jumper cables between the two high voltage batteries? Unfortunately the car with the good battery would have no way of monitoring the temperature or the charge on the individual cells of the bad battery while charging it. Seems risky.
  17. Bob64
    1,540
    92
    Virginia
    Im talking about if his HV battery gets really low such that it needs to be charged ASAP. Which is impossible without the toyota special charger, which has a nearly impossible likelihood of helping him out.
    Theres nothing in this topic that suggests that the battery itself is bad. I think the problem is that the engine fails to start, although it sounds like its started due to the battery spinning the engine. Does your tailpipe smell like exhaust?
  18. Danny Hamilton
    926
    94
    You know it frequently frustrates me when someone throws their opinion into a topic without first making sure they know what has been discussed. It frustrates me even more when I'm that someone. :bolt:
  19. galaxee
    9,810
    464
    MD
    sorry for the delay.
    the wiring harness was ~$2500. DH billed 14 hours for the r&r. his first time doing the one on the prius, it took about 10 hours. the other 2, he wasn't as familiar with and took closer to the 14 hour flat rate time. the hihy had a lot more damage than just the wiring harness.
