Prius sound proofing
Discussion in 'Gen 3 Prius Accessories and Modifications' started by bear4, Feb 7, 2012.
  1. bear4
    bear4 Junior Member
    68
    FL
    I am considering installing additional sound proofing for my Prius. Has anyone done this before? I love Prius, but I feel that road noise could be a lot better. When I was on the market for a new car few months ago, I seriously considered 2012 Camry that I test drove, and the interior noise, especially on the highway was way better than in Prius. I ended up going with 2011 prius anyway due to technology and fuel economy, but 2012 Camry was definitely very quiet... I even considered Camry Hybrid, but fuel economy was not as good, also Prius has more cargo space...
    Anyway, do you have any tips on soundproofing a prius? I've done Toyota echo before and had many great results with Dynamat and Dynapad placed in the door panels and under the carpet.
    Thanks!
  2. phoenixgreg
    phoenixgreg Senior member
    1,157
    288
    66
    Phoenix
    I'd be interested in how you do this as I'd sacrifice some MPGs for better sound-proofing too. Some here have suggested starting with the wheel wells. Maybe putting foam rubber behind the front wells to prevent sound-transfer from the road into the body. Also, how about some foam rubber along the firewall? The door panels can be easily removed and you could add foam or other sound-proofing material inside them.
    When I had my dash plate out about a year ago, I should have considered putting foam rubber as far down the inner fire-wall to mitigate noise transfer from the engine compartment.
  3. fotomoto
    fotomoto Senior Member
    5,597
    3,771
    So. Texas
    Yes, there have been some folks who went the dyna-mat route so search. I've been kicking the idea around but if I do it will be with much less costly carpet padding and added to easier to get spots (lower hatch, front foot wells) first. Next will be replacing the stock tires when they wear out with something quieter; possibly continental ecotec's.
  4. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    Search Dynamat - many here have done it - it makes sense to do when you swap the door speakers.
    Sonically it helps a bit (not a lot - but it is noticeable) - I think the biggest improvement is the door/skin 'feel/sound'. Much more like a Lexus door closing (thud).
    I don't think carpet foam will do much - but there are makers of knock off Dynamat that should be fine...
    I did doors, under rear seats, back side panels, below tire etc. Tap on the outside skin of the car, and it sounds solid.
    Did it make much of a difference with my premium sound system - not really.........................
    kenoarto likes this.
  5. bisco
    48,995
    i am thinking of spraying foam insulation in all the cracks and crevices. that seems to be where most of the noise is coming from.
  6. danvee
    danvee Blizzard Brigadier
    326
    53
    38
    New Jersey
    Outside of the possible toxic effects, I'd be worried about it trapping any moisture and accellerating rusting...
  7. bisco
    48,995
    hmm, hadn't thought of that. maybe if i did it when the weather is really dry. i don't think it's toxic, you use it for home insulation.
  8. bear4
    bear4 Junior Member
    68
    FL
    I did my 2003 Toyota Echo with dynamat and dynapad, and although there was some improvement in road noise and engine noise, it was not a lot... And I spent over $400 on materials alone - I did the doors, floor, trunk and the hood. Took about 3 weeks also... The results were not nearly as the higher-end vehicles as they come from the factory - such as a new Camry I just test-drove before I bought my Prius. Almost bought the Camry for the ride quality...
    So, perhaps I will look to have my Prius done professionally with better results. I am not sure if there is a shop in my area that can do it. Has anybody done their vehicles professionally? Would this work affect the warranty? I wonder if Toyota dealer can do something like this with good results.
    I believe Prius can be extremely quiet with better insulation and better tires, but the insulation needs to be professionally done by somebody who knows what areas need to be addressed to get the best results.
    Sbceezie likes this.
  9. Felt
    Felt Senior Member
    1,624
    603
    Mountain West
    Personally, I think most of the noise issues can be corrected with different tires. My Michelin Energy Saver tires have rendered noise a non-issue.
  10. HaveNoCents
    HaveNoCents Conservative Tree Hugger
    299
    46
    Crystal Beach, Texas
    I doubt it's the tires. I know when I drive mine it sounds like a window is slightly cracked, but of course none are open.
    iPad ?
  11. bear4
    bear4 Junior Member
    68
    FL
    What were your OEM tires? I got Yokohama, they are pretty quiet on the smooth pavement, but loud on the rough surfaces. The other noise is from engine hum/exhaust
  12. Felt
    Felt Senior Member
    1,624
    603
    Mountain West
    I do not recall the OEM tires, but I seem to recall they were Yokohama's. I now have Michlin Energy Saver A/S. I have read they are not too good in snow, but I have a second vehicle for those situations. I am very pleased how queit they are ... and LRR too.
    Unfortunately, I read elsewhere that they are hard to find now.
  13. BUFFALO PRIUS
    BUFFALO PRIUS New Member
    BUFFALO, NY
    Regarding noise levels in the Prius gen 3, when I bought my 2010 the interior noise was so bad that you could not carry on a conversation above 45 mph. I might not have known the cure except that I had exactly the same problem with my 93 Camry which I just got rid of (nearly 20 years of trouble free operation). I bought new tires for the Camry from Tire Rack after reading their very detailed tests and thought I was driving a new car. Same thing this time. Original tires were Bridgestone Ecopia ep20, all season, optimized for low rolling resistance, ie high mileage. I bought new rims (used toyota) and Bridgestone Ecopia ep100, a summer tire. Same result, talk at normal levels at 70mph and enjoyable driving for the first time. I put the all season back on in the winter.
    LLM2 likes this.
  14. fumbling
    fumbling Junior Member
    17
    irvine
    So the new tires you bought for the Camry that were quiet and cured the noise were the Ecopia ep20?
  15. bisco
    48,995
    i think he was saying the prius came with the ep20's and he changed to the ep100's.
  16. Tinted08
    Tinted08 New Member
    Dynamat won't block road noise. Dampening metal vibration is only the first step to sound deadening. To block the exterior sound, in addition to a layer of Dynamat, you will need a layer of closed cell foam and then a third layer of Mass Loaded Vinyl. The closed cell foam creates an air barrier by decoupling the MLV. The MLV, which has a mass of 1lbs per square foot, does all of the sound blocking. For the doors you could add a fourth layer of 3M Thinsulate.
    After my sound deadening project, I lost a couple MPG with an extra 100lbs of weight. I can live with that. I've done this to the entire floor and all four doors of my 08. The last step will be the firewall and rear hatch door.
  17. phoenixgreg
    1,157
    288
    66
    Phoenix
    Dynamat helps, but I agree it's not the total answer. I did it a few weeks ago and it has dampened most of the road noise.
    I still think adding more dampening to the wheel wells will help too:
    Dynamat 2.0 | PriusChat
  18. davep3913
    davep3913 Junior Member
    oregon
    Carpet padding is the answer for floor and firewall noise...That is what lexus uses...has been used for decades in the upper end cars..
  19. Solarman44
    Solarman44 Junior Member
    78
    Largo, FL
    I've owned two Prius, 04 and our 10 and the cabin noise is my biggest complaint. I wonder where I would start to find a RELIABLE shop to do this work for me. I would hate to go thru all of this and end up with a car full of rattles, any ideas?
  20. ursle
    ursle Gas miser
    1,049
    192
    NH
    I was hoping someone would mention the type of foam( and where to get it) one uses to seal the doors, a layer (1"x 1/2")? applied correctly would stop all the dirt and water from entering(I always have dirt after it rains coming up from the sills), I'd think the noise would also go away
    Dynamat on the inner door panels will change the vibration frequency, changing the sound, it'll be a lower frequency, some of it will be there but it "works". Everything vibrates, (metal echos more then carpet and sound deaden-er), dynamat absorbs vibration lowering the frequency of vibration, and the sound level.
