Prius Stages of Operation & Operating Mode Availability -A Reference Aid
Discussion in 'Knowledge Base Articles Discussion' started by ksstathead, Feb 26, 2008.
  1. ksstathead
    ksstathead Active Member
    1,244
    244
    Kansas
    See attached pdf from Excel for a 1-page reference to the warm-up stages and resulting operating mode availability.
    This should be especially helpful for those with short commutes for whom the warm-up penalty in fuel economy is so severe to overall mileage.
    Please provide corrections and refinements and I'll try to incorporate when there is consensus. I have no Prius yet, so you cannot offend me, I'm just trying to summarize the existing 'literature.'
    ksstathead
    Ken@Japan's review is pending, but he provided the following history of the "Stages" work which came to us from Japan. It was lost when PriusChat emerged from Yahoo, as I understand it, and Daniel wrote his article as a way to preserve and advance our knowledge. I certainly want to credit not only Daniel, but also Ken@Japan, Master White-EPV, and others with Estima Hybrid Forum in Japan who have given us this information derived from dedicated experimentation and observation.
    Keywords for searches: pulse glide warp stealth stages warm-up modes
    2 people like this.
  2. Doc Willie
    1,717
    144
    Out there, somewhere
    Most cool and worthy of intense study.
    Edward Tufte would approve. (High information density)
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,193
    Nixa, MO
    Pretty nicely done.
    I'd just add that in stage 3 a no arrows glide is possible, but you must be above 35mph (but below 42mph) to enter it.
  4. ksstathead
    1,244
    244
    Kansas
    thanks gentlemen.
    I will continue to enhance the presentation. Information density will remain high.:cool: I added links to leading threads on the modes and other subjects addressed.
    Keep those suggestions coming, folks.
  5. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Nice. Is there room to add ", audible change in running"
    after the ignition timing line for getting out of 1a? There
    is one, that the non-scangauge-enabled can probably use to
    discern that change esp. in warm weather with the windows open.
    You probably want to fix "site's of members" to read properly,
    "sites of members" or "members' sites".
    You should likely give credit to Daniel's original writeup about
    all this, which is mirrored at my site but NOT authored by me
    other than a couple of minor additions at the bottom.
    I *still* think it's very odd that one has to come to enough
    of a stop or slowdown for that "idle check" to happen and
    finally allow getting into stage 4. There are plenty of times
    I've had to do a whole trip with no opportunity to stop and
    let it happen, bangin' the EV switch for all the low speed glides.
    I wonder if all this could be done in a graphical fashion that's
    more visually immediate, such that Tufte would approve even more?
    I'm not being able to come up with a good way right now..
    _H*
  6. ksstathead
    1,244
    244
    Kansas
    Done, thanks. See the 2nd upload revision of today.
    Doc Willie: You should see the napkin this project started on... We had a gubernatorial candidate a while back here in kansas whose mantra was learned on the family farm (re hay bales): 'stack 'em high and tight.' For now, I'm trying to keep this to a page more than trying to replace the stuff already out there.
    Edit: Farm/hay bales was MY Dad. His deal was a family moving van service IRRC.
  7. Tideland Prius
    16,206
    Thank you for the upload!
  8. efusco
    19,891
    1,193
    Nixa, MO
    I nominate you for the Oscar for "Best Prius Article by a non-owner" award!
    Really nice concise readable summary article there.
  9. ken1784
    ken1784 SuperMID designer
    2,943
    1,373
    67
    Yokohama, JAPAN
    Hello ksstathead et al,
    Very nice article!
    Would like to comment some, but I'm busy now. Let me do it later.
    Anyway, let me tell the history now...
    In Japan, the first introduction of Toyota hybrid warming up stages was done sometime in 2003 by Estima Hybrid forum members led by Master White-EPV(his handle).
    Æ’GÆ’XÆ’eÆ’BÆ’}Æ’nÆ’CÆ’uÆ’Å Æ’bÆ’hâ€Râ€Ã¯Æ’oÆ’CÆ’uƒ‹
    Master White-EPV got his 2004 Prius and he found Prius does the same thing.
    He wrote his article...
    â€â€™â€šÃŒEPV‚³‚ñ‚̃vÆ’ÂÆ’tÆ’BÂ[ƒ‹ / Æ’vÆ’Å Æ’EÆ’X Æ’IÂ[Æ’iÂ[Æ’Y Æ’Å Æ’XÆ’g
    I introduced the stages to Prius-2G Yahoo group in April 2004 in English...
    Yahoo! Groups
    Regards,
    Ken@Japan
  10. ronhowell
    ronhowell Active Member
    681
    32
    Cypress, CA.
    Hi ksstathead and all,
    Excellent piece of work; especially in following Winston Churchill's dictum "Pray may I have, on one sheet of paper" - your summary of the details.
    The knowledge base on this site is incredible. I have learned more about my Prius in the 5 months I've had it than any other car I have ever owned.
    Just one comment with respect to the Hybrid Paradox. While its true that all the car's energy originates from what's in the gas tank, the regenerative electrical energy does re-capture some of the kinetic energy that the gas provides, although with some inherent inefficiency, it is true. To the extent that it is not lost as heat in the brakes, that at least is a net gain.
    Time to start implementing your work, no?!
  11. ksstathead
    1,244
    244
    Kansas
    Thanks, Ron!
    I concur with your comment; regen is far better than waste heat & brake wear.
    Yes, it is high time I purchased. Getting close.
  12. douglas001001
    douglas001001 smug doug
    222
    Chicago
    You can remove the ? in the shm line under stage 2, it is available but not as effective (in terms of holding speed) until s4 temps with a few miles of at speed transaxle warmup.
    Nice work on the writeup!
  13. Prius 07
    Prius 07 Member
    715
    Toronto, Canada
    Very nice write-up ... now buy the car and put it into practice ;)
  14. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi All,
    Just found this thread.
    Are we sure about 73 C for Stage 3 entry? My car seems to do that at 70C, but it has to have both engine/coolant temp gauges at at-least 70 C.
    Also, stage 1a end is easily detectable by shallow throttle manipulation. Push just a little, and one gets battery assist. A few seconds later after 1a is complete and one gets battery charge.
    There seems to be a more to Stage 3. Maybe an a and b. Stage 3a starts at 70c. If you can keep the car below 75 C (?) it will stay there. Go above 75 and one looses stealth. Then it comes back around 78 C sometimes, 80 C others. Which I take to mean transistion into Stage 4.
    I am no expert on these things, and get confused about it allot. But I though I would put in my comments anyway.
    A suggestion as to a more concise way to describe these things is a "State Diagram". This would have been how the engineers at Toyota would have mapped it out, most likely. A state diagram would allow multiple methods of stage entry, and even falling out of a stage, to be mapped.
    Ambient temp completely changes how these things work. Above 90 F indicated on the Prius outside temp gauge will require a warmer coolant/engine temp for stage 3 entry. Maybe this is where the 73 C comes from? Or maybe its the cat temps that are having an influence too. Had a very confusing drive over to a restraunt this weekend during a hot late morning. Could not get the car to go into stage 3 forever. Engine/coolant temps were up to 80C plus before it would glide. Like it decided to stay in stage 2 until Stage 4 requirements were met. This knocked me down from 67.5 mpg to 66.2 at mid tank, even after a warp neutral 2 mile glide (up to 45 mph), after finally getting into stage 4.
    Here is a comment about SHM (super highway mode). I found I need to be above 50 mph, 53 is ideal, and below 55 to get a good SHM going. At that speed, one can get the car going along almost indefinately at 1248 or 1280 rpm on level terrain (although this experiece is possible with the aerodynamic aid of 65 mph cars going by in the middle lane). Downhill decreases the sensitivty of the peddle manipulation to getting into the SHM. The mileage on the Prius display will be in the high 70's to mid 80's when you got it going good. A matching speed side draft with a 45 degree following wind over the draftee will let the rpm drop to as low as 1180 (not sure on those last two numbers) - about as slow as the engine will turn before droping into warp stealth.
    I find that 40 to 49 mph is no-man's land for great mileage. Pulse and Warp Stealth is probably the mode of operation there. When I am doing 45 mph in the construction zones, I usually am recharging batteries after running them down from from long uphill pulse and glides in slow and go traffic.
    Recent trips have resulted in 3/4's of the 5 minute bars screen being green. Kinda like a good score on that video game with the falling shapes. Ha!
  15. douglas001001
    222
    Chicago
    donee: I think it might be battery temp which could be causing your weird over 70C experience.
    I've been having the same issue lately and hear what I believe to be the battery fan spinning. Opening the window for a block or two and everything is back to normal and the noise I believe to be the battery fan goes away and glides are available.
  16. kellgy
    kellgy New Member
    Southern California
    Thank you for your solid work. The PDF will be printed and stored in my lower glovebox, he he. This post has influenced my decision to add the EV mod. Great work!
  17. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi Douglas,
    I am not hearing the battery fan going. I keep the inside of the car cool with a sun shade, and cracked windows when parked. Which has worked, except one day that was on-and-off rain and sun recently. The mycanscan says the battery temp is under 40C at the end of the drive home. The battery usually starts the morning less than 23 C. I have only used the AC once so far and that was about 3 weeks ago.
    I have seen that too-hot battery problem. But usually later in the year, when its over 90 F, when taking the highway route, and not using the AC and during the glides at the end of my evening commutes. I usually use the AC above 90 F, but when its on the edge, I have tried to do without it. Lately its been so windy into my car on the drive home, I have stayed off the highway. Airspeeds of above 90 mph are not conducive to good mileage. The side road is shaded on my nightime commute, and this also baffles the wind a bit.
    Engine temps are not going over 92 C, and usaully right around 90 C at the hotest point of the drive home, just before long glides and traffic lights into my neighborhood. After which, the engine temp is down around 86C.
    Recently, the 70 C glide oportunity has been very fleeting. The car gets up and through the 70 C glide temp range within a mile from start up, and I do not have glide oportunities that close to my home and work. Uphill in the morning, and stuck in traffic in the evening.
  18. nyty-nyt
    nyty-nyt Member
    139
    Ontario
    I have resisted getting a Scangauge, but I try and get the best mileage I can, applying the idea that if I use the brake, I've burned luxury fuel. So far, so good, as I am using only 3.7 liters per hundred K, and nobody following me has given me the finger, or used their horn. Where can I find out about SHM for those of us without the gauge?
    Additionally, I find that my car refuses to quench the ICE even though I have six bars, and I am 15 minutes into my commute, unless I accelerate hard (that luxury fuel again) before gliding. Sometimes even that doesn't result in ICE shut-down, until I come to a complete stop at a light, then I'm OK from then on.
    Looks like I need that ScanGuage, right? I would like someone to take a stab at why my nice P&G is interrupted that way.
  19. JimboK
    JimboK One owner, low mileage
    2,817
    187
    49
    Chesterfield, VA
    Unfortunately, to nail SHM consistently requires monitoring ignition timing and/or RPM and keeping them within a very narrow range. Without added instrumentation you could try to maintain just enough go-pedal pressure to keep the ICE on. But I have no sense of whether you'll approach the results of those who have the instruments. Here's the full writeup on SHM if you haven't already seen it.
    For your ICE non-shutdown issue, sounds like you're still in S3. To move to S4 the car needs to be at a complete stop with the ICE running and sit long enough (generally about 7 seconds) for the ICE to shut off on its own. For that you don't need a ScanGauge. See this for a full description of the warmup stages.
    The ScanGauge still is a useful tool for many purposes beyond these.
  20. ksstathead
    1,244
    244
    Kansas
    anyone else having trouble opening the pdf attachment in the OP?
    I (the OP) get a file does not exist error when trying to open...
