Prius v: 200,000 miles club
Discussion in 'Prius v Main Forum' started by usbseawolf2000, Jun 16, 2013.
  1. benkhanobi
    benkhanobi Member
    123
    50
    SW Florida
    I'm impressed! I made extra money from my last job from mobilization/demobilization pay= $0.565 a mile - I drove about 3000 miles in my 2007 Prius to the jobsite and back. It's too bad that courier jobs pay so poorly as a Prius V with a slide out roller platform could haul a lot of stuff and do it cheaply.
  2. 2 fas 4 u
    2 fas 4 u Active Member
    320
    350
    florida
    Update: 265000
    Everything is good, I treated her to 4 quarts of royal purple, wanted to see if it could reduce my 5 ounces of oil burn.
    Also I just put some new tires on her continental ecos, only put 500 miles on them other than that no complaints.
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,994
    Fort Lee, NJ
    Wow approaching 300k. Will need a new thread soon!
    That_Prius_Car and stephensprius like this.
  4. 2 fas 4 u
    320
    350
    florida
    Here is something for ya. Not related to me. My co worker has a prius I believe 2011 or 2010 has 300000 plus has never changed transaxle fluid. He told me the dealer said to change when he does the brakes, because they work together. I told him to change because he is threading on dangerous grounds. I was even going to change it myself but dont want to be responsible. Anyways whatever.
  5. telmo744
    telmo744 HSD fanatic
    2,170
    764
    Portugal
    Did you went well with the Nexen tyres?
  6. stephensprius
    stephensprius Active Member
    670
    226
    Minneapolis, Minnesota
    This is just so cool to follow. Are you going to start up the 300k soon?
  7. stephensprius
    670
    226
    What will you get to replace the Prius V? Would you consider going back to the standard hatchback Prius?
  8. usbseawolf2000
    14,487
    2,994
    Fort Lee, NJ
    Yes, when he reaches 300k (or anyone else) and have a screenshot.
    markabele likes this.
  9. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    Avoid that dealer. Your advice to change the fluid is spot on.
  10. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    2 fas, hope you had a great xmas and new years and looking forward to another update. You must be getting close to 285,000 now!
  11. Priuswagon
    Priuswagon I love my Prius
    112
    Kingston Washington
    Thanks for posting your results I was afraid I'd need a new battery after 100,000 miles.
  12. 2 fas 4 u
    320
    350
    florida
    Update: 285000
    No problems just changed spark plugs and pcv valve.
    Tony D, cwerdna, ewxlt66 and 2 others like this.
  13. JBumps
    JBumps Member
    167
    57
    Morgantown, WV
    2013 Prius Plug-in
    Unbelievable! Clearly time is the larger enemy of the hybrid drivetrain, rather than miles. I sure hope that this one continues to treat you well enough that I get to read a post about you hitting 500k sometime in late 2015 or early 2016. Congratulations 2 Fas 4 U and safe travels.
  14. SageBrush
    11,627
    2,530
    Southwest Colorado
    No doubt time matters, but keep in mind that 2Fas overwhelmingly drives flat highway miles at fairly constant speeds. That is the easy life for a Prius traction battery. The more reassuring data comes from taxi drivers who also go beyond 300k miles despite stressing the traction battery without mercy.
  15. 2 fas 4 u
    320
    350
    florida
    Nothing to report. Just another mile driven. Another night away from home.
  16. usbseawolf2000
    14,487
    2,994
    Fort Lee, NJ
  17. jlim888
    jlim888 Member
    78
    36
    My original prediction for 2fas to cross 300K on March 16th 2014 is off... It looks like he will cross 300K this month!
    My March 16th prediction included 2 weeks time off. Apparently 2fas didn't take any time off. His courier business must be very good ;)
    Date Miles
    2/7/2014 294000
    1/15/2014 285000
    11/23/2013 265000
    10/17/2013 250022
    9/6/2013 235000
    8/2/2013 220100
    7/13/2013 211019
    6/18/2013 201019
    6/16/2013 199200
    6/2/2013 193750
    5/14/2013 185000
    3/23/2013 165800
    2/19/2013 154510
    2/7/2013 150000
    1/18/2013 145000
    11/22/2012 122000
    10/5/2012 104000
    9/28/2012 100300
    9/27/2012 99999
    9/24/2012 99500
    9/19/2012 97500
    9/13/2012 95000
    9/9/2012 94000
    8/10/2012 87000
    6/23/2012 73000
    5/4/2012 50000
    3/27/2012 30000
    3/13/2012 20000
    2/13/2012 10000
    1/30/2012 3100
    1/23/2012 0
  18. usbseawolf2000
    14,487
    2,994
    Fort Lee, NJ
    That's too fast.
    milkman44 likes this.
  19. 2 fas 4 u
    320
    350
    florida
    cwerdna and ewxlt66 like this.
  20. ewxlt66
    ewxlt66 Active Member
    535
    186
    Dana Point, CA
    He needs an award. This is fantastic and unbelievable. Amazing!
