Prius v CVT transmission "memory'
Discussion in 'Prius v Main Forum' started by Eric "v", Dec 16, 2014.
  1. Eric "v"
    Eric "v" Member
    229
    44
    'Vegas, NV, Baby
    2013 Prius v wagon
    Does the Prius v CVT tranny have a "memory" that recognizes your driving style and then gives you the CV step you want for lower "gearing".
    I ask because my car used to accelerate rather "languidly" regardless of the throttle being at WOT and a harsh use of my buggy whip. And this was even after I installed an INJEN cold air intake.
    But lately (past few weeks) it seems to take off noticeably quicker. Maybe it's the cold weather and denser air coming in that bad boy intake... or not.
    In any case, in any setting I get brisker acceleration. and in PWR mode it's nicely quick - for a Prius, that is.
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,656
    4,493
    Texas Hill Country
    You may be using better gas, eg higher octane. Major refiners do change their quality from time to time, especially if they are running a big ad campaign. Shell was famous for this at one time.
  3. Robert Ciambrone
    Robert Ciambrone Junior Member
    23
    I think the car's computer is giving you a richer gas/air mixture due to the cold weather. Back in the day when cars had carburetors the choke would kick in during cold weather starts and that always felt like the car had more power from the starting line.
  4. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    Higher octane is ***NOT*** automatically "better".
  5. rjparker
    7,656
    4,493
    Texas Hill Country
    It is when the engine's timing automatically adjusts to it.
  6. mikefocke
    3,654
    1,630
    Sanford, NC
    Gas is reformulated for the winter and summer in some areas. Pollution control is the reason.
    Are you really getting air from outside the car now or just using an air filter that is more porous (and which allows more and bigger dirt particles into the engine)? The stock intake on my '12 v took air from outside the right side of the radiator. Short of using larger passageways from the outside of the car to the throttle body which would fool the Mass Airflow Sensor and the engine control unit because it isn't calibrated for those sizes, I can't see much point besides a louder air intake and the last thing a v needs is more noise.
  7. Easy Rider 2
    1,584
    257
    Ocala, FL
    Nope. Still wrong.
    Any engine that will indeed "adjust" to run better on high octane "premium" will state something like that in the documentation and "recommend" that you use "premium" for best perfoamance.
    OTOH, any engine that recommends regular with no mention of what happens with higher octane levels is NOT designed to advance the ignition or valve timing to benefit from a higher achieved compression. It just isn't.
    If knock is detected, it will adjust DOWN but unless designed specifically to run with higher octane fuel, it will NOT adjust up.
  8. ems2158
    ems2158 Active Member
    221
    162
    Bucks County, PA
    If the "regular" fuel you are normally using is not the best quality, the engine is adjusting down and performance will be reduced and will adjust up if a higher quality regular or premium fuel is used. Your engine MAY perform better with the next grade of fuel. Hard to know what you are getting when you fill up.
  9. Easy Rider 2
    1,584
    257
    Ocala, FL
    While that MIGHT BE true, I think it is a stretch.
    I'm pretty sure that the engine does not operate right on the threshold of spark knock when using good quality recommended gas.
    Anyway, saying or implying that the engine always will adjust up to meet a higher level of octane is just simply NOT true.
