Problem flashes on screen when I turn sharply
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by PDWadler, Nov 17, 2014.
  1. PDWadler
    PDWadler Prius (and Cubs) fanatic
    Chicago
    I have a 2006 Gen II Prius with 105K miles. My touchscreen stopped working a couple of months ago, and I've managed to live without it. But now sometimes when I turn sharply (mostly right but sometimes left) the word PROBLEM appears on the screen, all the dashboard lights come on, the dome light comes on -- all for just a second or two-- then things go back to normal. Are the two related? Does somebody have any ideas?
    49,798
    don't turn sharply.:cool:
    Mr. Bubbles likes this.
  3. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    749
    Delaware
    if your oil is low it might set a warning light. I'd check that first.
  4. xliderider
    xliderider Senior Member
    7,901
    3,130
    Honolulu, HI
    Definitely get your codes read, is your check engine light on?
    SCH-I535
  5. JC91006
    16,498
    8,408
    I also think you have low oil.
  6. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    Low oil could be a problem, but the dome light coming on? Very strange. It sounds to me like there is a rub or intermittent in the wiring harness. Was there ever any accident or repairs done to the car?
  7. drewtx
    drewtx Junior Member
    Houston, TX
    I had similar symptoms. Mine was low oil.
    Sorry Prius! Gave it a good drink of Mobil1 :)
  8. usnavystgc
    3,159
    989
    Tucson, AZ
    Definitely low oil
  9. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Low oil is the general cause...
    However, with the dome light turning on, that sounds like a door is coming open. If the car is in drive and moving and a door opens, you get that warning. A sharp turn could possible unseat a door. It could be as simple that over 10 years one of the door switches has become slightly misaligned or something. That's what I would check...
    usnavystgc likes this.
  10. clickchick
    clickchick New Member
    The oil is low. Chances are the gaskets are leaking oil. More often than not the gaskets are made of paper. It's cheaper and easier to keep feeding your car extra oil than it is to have the engine rebuilt. Keep an eye on your levels so you don't completely blow your engine.
  11. Skibob
    Skibob Senior Member
    2,912
    1,497
    Northern California
    Two things:
    1) 5 year old thread
    2) gen2’s have a problem with the oil ring that causes them to burn oil. It’s generally not gaskets.
    Raytheeagle likes this.
