Problem with running
Discussion in 'Generation 1 Prius Discussion' started by william shropshire, Apr 17, 2015.
  1. william shropshire
    william shropshire New Member
    denton texas
    2001 Prius
    I
    I have a 2001 toyota prius. When I start the car and press on the gas pedal the engine rev's but nothing moves and there is some clatter from the engine. I can put it in B mode and drive it a short distance, but that's it... Please help. The engine light has been coming off and on for a week now. It makes a loud audible tone and then I turn it off and back on and then it stops. Any ideas
  2. kutcht1
    kutcht1 Member
    295
    81
    Andover, Minnesota
    Sounds like your MG2 motor is toast, meaning your transmission will need a replacement. The MG2 can be replaced without removing the transmission. The problem is finding a good MG2 at a reasonable cost, best bet would be is to find a GEN 1 that has been in an accident as a donor.
    TomK
  3. Patrick Wong
    18,200
    6,464
    Get Mini VCI so you can retrieve the diagnostic trouble codes logged by the various ECUs in your car and therefore have a clue about the root cause. You don't want to be replacing a transaxle on a guess - although it is reasonable that the transaxle may be the root cause of your car's problem.
    bwilson4web likes this.
  4. C Clay
    C Clay Member
    284
    52
    Lexington, KY
    Patrick,
    Id like to insert a question here for myself and Mr. Shropshire. I've had similar problems and on my 100 post thread I think many have suggested the same thing. I bought a scanguage and didn't take your advice on the MCI VCI (primarily because I needed a scanning tool for the next day.) I think you've indicate the Mini VCI is more accurate; that's with the techstream software we'll have to download?
  5. BigVanMan
    BigVanMan Junior Member
    27
    26
    Manchester, NH
    Sorry to hear your 2001 is experiencing problems. If your issue does end up being a bad MG2 stator, Dorman now sells "new" MG2 replacement stators for the 1st gen Prius's. In my opinion, this is a much better option than rolling the dice and going for a used junkyard/ebay stator. I don't work for them, but I am ordering one myself to replace an apparent bad one on my 2001. A quick web search will show that one company is selling these for about $550 shipped. Look up part number Dorman 587-990.
    EddieAtl likes this.
  6. Patrick Wong
    18,200
    6,464
    When you purchase Mini VCI, the required Techstream and other software will be included on a CD. Assuming you are successful in installing that software on a Windows XP or Windows 7, 32 bit OS laptop, you will then enjoy essentially the same diagnostic power as a Toyota dealer technician.
    C Clay likes this.
