Proposal to cover California Aquaduct channels with solar panels to prevent evaporation and algae
Discussion in 'Environmental Discussion' started by Rybold, May 8, 2011.
  1. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
    Solar panels, a roof staple, take to the water - San Jose Mercury News
  2. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Re: Proposal to cover California Aquaduct channels with solar panels to prevent evaporation and alga
    Sounds like a great location to maximize every kind of problem you can think of and a great many unthought of problems.
  3. dogfriend
    7,512
    1,188
    Carmichael, CA
    How about placing the solar panels in the right of way next to the canal? I think that would be a great location.
  4. donee
    donee New Member
    2,956
    197
    Chicagoland
    What a good idea! I am sure when it hits 100 F there, that they are loosing half the water to evaporation....
  5. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    The canal is not that wide or deep. It should be easy to achieve what is described.
    Placing the panels next to the canal won't prevent evaporation or algae.
    Is this a win/win (except for the cost)? I don't see too many negatives.
  6. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    Flash flooding?
  7. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi All,
    Even for the movies it would be neet. Put circular rain drain holes in the panels. Then when a car goes through a puddle underneath the panel, you get a shot of water up through the holes...!...
  8. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    They control the flow at each reservoir, to limit how much we steal, err.. take from Nor Cal.
  9. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    During the last go round on moving more water to SoCal I saw a bumper sticker in San Jose that said, "Flush twice, LA needs the water.":D
  10. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    Understand. However, there are flow controls on the Mississippi River as well......
  11. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    Flood water and aqueduct water don't mix.
    By design the aqueducts don't flow in low lying areas where flood and storm water would congregate. This would contaminate our drinking water.
    The aqueducts are located on high ground to take advantage of gravity. You let them follow a high terrain as long as possible. This uses the least amount of energy.
    When it comes time it can not flow due to gravity anymore, we have these huge pumping stations, with huge power stations and/or substations, located at a foothill to pump it to the top of a hilltop or mountain, where we can let gravity take over again. It's design to be pumped back to high ground.
    While it is pumped, it runs in multiple giant sealed pipes so the head pressure can push the water up.
    It's very akin to pulse & glide.
    Some stations even try to recover the energy of the water coming back down, like regenerative braking.
  12. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    What a great idea......create a home for the homeless.......even comes with heat. !!!!!!!!!!
  13. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    Thanks for taking the time to cover that aspect. Still think water based solar panels have limitations, but can see where that is not the problem I thought it might be.
  14. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    Your thought still makes sense in that floating panels can still be easily damaged.
    It would be better just put tarps over the waterway to limit evap and algea, and put solar panels in the right of way where it is easier to maintain.
  15. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    if you put them on a floating dock like structure, it'd probably be fine. Esp you you then moored the floating platforms so that they couldn't move very much. What are the typical flow velocities in the aqueducts I wonder?
  16. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    That was an interesting question so I looked it up. I do remember seeing a couple of aqueducts up close and the water appeared to be moving at about walking speed.
    3 mph
    water.ca.gov/recreation/brochures/pdf/50swp.pdf
