PWR mode + B mode = Hidden Sport Mode
Discussion in 'Gen 3 Prius Main Forum' started by A617, May 2, 2015.
  1. A617
    A617 Member
    213
    95
    OKC, OK
    So what defines sport mode in cars, all it does is, transmission hold its gear longer for better response and increased engine braking and engine management enhances the throttle response, How does one translate to our prius, Put Transmission in B mode and Turn on Power mode.
    So I'd discover this when i was at my defence driving course (my school was offering for free) after the course we get to use their track to run some laps around it, What i found is that in power mode the engine mapping changes so power comes on with less throttle however when you have in B mode (w/PWR mode) as soon as you let the gas off it immediately switches over to engine braking at what ever rpm up to 3500 rpm example so say you rev your engine to 3500 4000 rpm and you take your foot off the gas the engine switches over to engine brake at 3500 rpm, its pretty nice effect, it did help that i didn't really have to use my physical brakes that much and it slowed the car quite effectively thus leading it to an pseudo-sport mode and all other automotive has.Also the engine does not shut off in B mode even when you come to a complete stop ( while still in B mode)
    #1 A617, May 2, 2015
  2. StarCaller
    StarCaller Senior Member
    1,240
    692
    Cedar Crest, NM, USA
    lets say it this way, probably this car was never meant to be run in a 'sport mode' //
  3. mrbigh
    3,686
    699
    Long Island, NY
    Sport mode in a Prius, IMPOSSIBLE, it is against the physics law...:cry:............
  4. A617
    A617 Member
    213
    95
    OKC, OK
    Oh i know that but putting those 2 modes together = psudosport mode.
    It's psudo-sport mode.
  5. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    PWR mode + B mode = Hidden Gas Guzzler
    At any speed over 24 MPH (this will vary by model, but not by much) B mode causes the engine to rotate while decelerating, diverting energy from the battery to rotating the engine as an air pump.
    PWR mode makes the throttle less sensitive, getting you to very open positions with out much fine adjustments.
    Neither improves handling at all.
  6. bisco
    49,079
    combine it with one of those japanese aero kits, and you're off and running.:cool:
  7. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    I'll give you points for experimentation.
    But I don't really understand anyone who buys and operates a Prius looking for a sports mode.
    The whole vehicle is HSD. Hybrid Synergy Drive and it's main aim, is to reduce emissions and be efficient from a fuel usage POV.
    You can put it in "B" and Press Power and change attributes but it's going against the overall design of the vehicle and system.
    I guess I'm just a right tool for the job guy. And my thinking is if you want a sports car, buy a sports car. If you want efficiency and great gas mileage? Buy a Prius.
  8. A617
    A617 Member
    213
    95
    OKC, OK
    I know the prius is no a sports car, everyone knows that, but it does improve in power delivery when coming out of a corner or slowing at a corner the engine does not turn off which means less delay in engine to be spooled up by MG1 to get the engine to run, and lessen the need in using the brakes by using engine brake instead and prevents the brakes from cooking, however battery will deplete faster, I've seen prius owners has taken their prius in autocross some even go bold and activate maintenance mode and drive it around, and besides who drives slow/efficiently at a close track? Every car has a potential just because it a prius doesn't mean is a efficient squishy lame duck you'll be surprised on what it can take on in a corner (granted after a suspension and wheels upgrade)
    offib, Burna J and RightOnTime like this.
  9. Fireboy
    Fireboy New Member
    29
    South Carolina
    I see what you're saying. He's not saying it's a sports car, just that it performed better around a track in PWR + B. I'm certain he still wants his 50 mpg.
    DevinP likes this.
  10. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    If you can get 50mpg while autocrossing let me know how. I got 17.1mpg over the 3.2 miles I ran last weekend. I will have to remember PWR & B for next year. The Prius was 5 seconds slower than a Corvette but can hold its own against a Beetle on slicks or a Jetta.
    m.wynn likes this.
  11. nodrogkam
    nodrogkam Junior Member
    51
    San Francisco
    This is the best way to go up and down hills without frying the brakes, which are super mushy when the battery fills anyways. Glad someone else is doing it. MPG isn't much worse than running in other modes (but it is worse), however, to me it is much easier for me to drive through.
  12. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    CERTAINLY less expensive than buying an additional "sports car" or "sport sedan".
  13. co_prius_3
    co_prius_3 Member
    174
    32
    Colorado, USA
    I've noticed that in 'B' mode, the ICE never shuts off, even when the car is stopped at a light. Not sure why it that is. The purpose of B mode is to provide engine braking, which is not needed when stopped.
  14. The Electric Me
    9,083
    5,798
    You say that, but then it seems your aim is to make it as much something it is NOT as possible. Which is a viable hobby I suppose, I just don't get wasting the time.
    If you redesign something enough, you can change it significantly, but for the VAST vast majority of people we aren't buying Prius to run at a closed track or in autocross.
    I don't deny your curiosity or even I guess your willingness to make the Prius as sporty as possible. If you want to do it? Spend the money on wheels and suspension upgrades? Go ahead.
    It just seems to me a weird propensity to try to change something designed beautifully to function in one manner into something it is clearly NOT designed or meant to be. Why not just pass go, and START with a vehicle more suited to closed track racing or autocross?
    Maybe I'm just getting old. When I had my Honda Fit, I noticed a whole sub-culture of owners who would buy a "Regular North American" Model Honda Fit then spend loads of money buying parts from Japan to make it as much like a Japanese Domestic Market Honda Fit.
    The thrill seemed to be just making it something "different". Sometimes the differences were so minute that I really didn't understand the reasoning why someone would spend so much money and time just to make what they originally purchased into something it was not.
    But I suppose making a Prius as "Sporty" as possible is a viable hobby.
    But personally? I bought my Prius to be that wonderful nearly 50 mpg squishy duck, and I think being the best HYBRID vehicle it can be IS living up to it's best potential.
  15. A617
    A617 Member
    213
    95
    OKC, OK
    Sporty or 50 mpg?
    JeremyB likes this.
  16. The Electric Me
    9,083
    5,798
    But I'm responding to THE REALITY of this thread. Which is your contention that Power Mode coupled with B Mode equals a hidden "Sports Mode".
    That isn't going to be "BOTH"...As pointed out above, that's going to make your MPG's PLUMMET.
    I don't have anything against improvement or sporty. But what you suggest in your original post ISN'T a situation that will make the Prius both sporty and remain fuel efficient. You press Power, put it in B and your gas mileage is going to get about as bad as you could possibly make it with a Prius.
  17. RightOnTime
    RightOnTime Senior Member
    745
    1,614
    183
    Kidnapped in OC, CA
    Guess I am a little late to the party.........let me chime in which is based on Experience
    Good for you @A617 for your observations and putting that to the Keyboard for other Prius Chat members to note.
    Respectfully most of the comments on your post come from members that have been on this forum for quite a while and in return you get a certain Vibe that the Prius was only meant for MPG. Take a trip to Japan, you will encounter hundreds of Mods that will enable the Prius to handle like a Sports car and still maintain a reasonable MPG. Unfortunately the demand is not here in the States which is due to the Old School thinking from the comments above.
    I say this in Respect because without these Members supporting this site, Prius Chat would be a thing of the past.
    As per PWR mode + B mode = Hidden Sport Mode it does exist and by experience can help entering a turn and coming out hot out of the exit.
    Hopefully i did not leave a Bitter taste from my comments - Cheers!
  18. katiesdad7
    katiesdad7 Member
    172
    25
    Stuart, FL
    The only thing that will increase your traction are the flashers. You get better traction with the flashers on. Or so it seems. I see folks with them on in the rain all the time. I'm guessing they want better traction. :)
    #18 katiesdad7, May 18, 2015
