Quick - What's your MPG read right now?
Discussion in 'Gen 2 Prius Main Forum' started by vintagebob, Jun 25, 2004.
  1. Danny
    Danny Admin/Founder
    7,094
    2,115
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Moved it so the whole board could participate :)
  2. m6scott
    m6scott Junior Member
    64
    Orlando Fl
    I have had my car a week and filled it just to see real milage .. I put 9.6 gal in at 370miles which gave me 38.8 on my calulator. The screen told me avg MPG is 43.3.. Now I have reset screen and now it says I am getting 53 MPG with about 27 miles since fill up !.. Is this true ? Am i dreaming or doing something wrong?
  3. shocker
    shocker Junior Member
    89
    Northeast
    51.8mpg/ 348miles
  4. randalla
    randalla Member
    370
    Lexington, SC
    Nope, you're not doing anything wrong. What you're currently seeing is a real-time cummulative readout of your MPGs as measured against 27 miles driven. As you drive and accummulate miles, the MPG will vary right up to your next fill-up. Enjoy your new car!!
  5. joanclare
    joanclare New Member
    northern virginia
    52.4/49 miles
  6. Frank Hudon
    Frank Hudon Senior Member
    4,147
    My 2k3 5.3 liters per hundred k for the last 4983K
    Wife's 2k4 5.7 for the last 253K
  7. wwblues
    wwblues New Member
    Andover, MN
    58.4 @360 miles on this tank
    54.7 lifetime @ 8100 miles
  8. ifftster
    ifftster New Member
    77
    St. Petersburg, FL
    52.2mpg with 5400 miles. :)
  9. rflagg
    rflagg Member
    947
    Springfield, VA
    Well, it's quite possible that the tank wasn't *completely* filled up (see any of the threads relating to the internal bladder in the gas tank) - if you take the 370miles/43.3mpg, that's 8.55 gallons. It's quite possible that you only used 8.55 gallons (or more or less than 9.6), but still filled 9.6 gallons, giving you an 'incorrect' calculated mpg.
    However, all is not lost. Continue yourself to calculate mileage the 'simple' way, and track it along with tracking the computer mpg each time you fill up. My first tank 'calculated' was off from the screen MPG by 4+ miles, while now after 20 tanks it's less than 2MPG off cumulatively.
    Hope this helps!
    -m.
  10. vintagebob
    vintagebob Junior Member
    98
    San Jose CA
    WOW! I was just hoping to get a snapshot of Bay Area MPGs, but this is even better. I'm really impressed with the numbers that are being posted all across the country (actually across the world!). Thanks for taking the time to share...
  11. ezongas
    ezongas Junior Member
    Northern Virginia
    410 miles, 60.2 mpg...mostly highway driven at published speed limits with and without air conditioning. Drive it like you have an egg in your shoe! Tires inflated to 43/41lbs, mobil 1 since 300 miles.
  12. efusco
    efusco Moderator Emeritus
    19,891
    1,193
    Nixa, MO
    59.5--mileage only shows about 35 so it's a little bit of a cheat. I accidently reset my mileage yesterday while cleaning the MFD screen--dumb, huh. Anyway, I only had about 30 miles on the tank when I reset and the mileage was about 57.4 at that time.
  13. Ray Moore
    Ray Moore Active Member
    857
    52
    Texas Hill Country
    53.1@ 587 miles on tank. I try to fill up at 600 each time.
  14. DonDNH
    DonDNH Senior Member
    1,711
    654
    Nashua, NH
    Four Touring
    106 miles & 52.3MPG
  15. twenty8moons
    twenty8moons New Member
    26
    Sunnyvale, CA
    52.7 at 126 miles (1760 miles total) going for my best tank so far!
  16. CHART
    CHART Member
    184
    Mount Airy Maryland, USA
    240 Miles this tank / 53.3 MPG
    13,500 miles total / 49 MPG lifetime
  17. mdacmeis
    mdacmeis Member
    133
    Michigan
    2018 Prius Prime
    current tank: 48.4 mpg over 286.1 miles.
    lifetime: 46.9 calculated mpg over 2213 miles.
    95% of driving is 70 - 75 mph highway.
  18. efusco
    19,891
    1,193
    Nixa, MO
    That's REALLY pushing your luck, Ray, by my math. Assuming a maximum 11.5 gallons usable (probably high estimate) and assuming your mileage computer is accurate (mine tends to give higher estimates than reality the highe mileage I get) then you will be able to go 610 miles before the tank is completely exhausted.
    It's your funeral, but that's cutting things darn close in my book...why risk damage to the hybrid system by cutting it so close? Geez, if you're really only getting 52.1mpg you won't make it to 600. Likewise, if you don't really have a full 11.5 gallons you won't make it even if you're really getting 53.1.
  19. Ray Moore
    857
    52
    Texas Hill Country
    Hi Evan
    Not to worry. Been here several times. My tank holds 12 gallons with these warm temperatures and my computer does an excellent job with the mileage calculations. I've checked it on every tank and it's always very close and under as often as over due to fillup variance. After 8000 miles, I'm comfortable with how the car works. 12x53=636. I'll fill up on my way into town at about 600. I could have stopped on the way home in the rain. I ran it out of gas once and put in 12.4 gallons and no damage that I can tell. I haven't gotten less than 50 mpg since and that low number was straight highway cruising at 75. The car is fine as far as I can tell. I haven't read about anyone experiencing the warned of damage to the hybrid system from running out of fuel, have you? I guess I'm living on the edge, but I like putting 600 miles on a tank of gas. I wonder about people who report only being able to put in 8 or 9 gallons. That's just so different from what I see. Thanks for the concern and all your great posts that I've been enjoying for months now.
    Ray
  20. efusco
    19,891
    1,193
    Nixa, MO
    Like I said, it's your baby, and I don't mean to tell you how to live. I wouldn't, personally, push that far. But no, I haven't heard of any actual damage to the hybrid system from just running out of gas...I think it's part myth and part concern about deeply discharging the Traction Batt.
    If you'll tolerate a few more somewhat critical comments, read on, if not then this will just be for the archives and so that others don't try to reproduce your style.
    1)12 gallons is clearly more than the stated capacity of the '04. This means you're filling an essentially empty tank and the neck and you're probably having some spill over into the charcoal canister that captures overflow. Filling into the neck that far risks spill out, evaporative emissions, and potentially worse (fire being the biggest).
    2)you seem to be very luck to have the tank capacity that you do. I'm a guy that has gotten 9.8 gallons in, once. Second highest is 9.5. And that's going 60 miles after the last bar started flashing getting about 57-58mpg on the display. And I was nervous at that.
    3)It sounds like you have lots of gas stations nearby you that make stopping to fill easy...I have several areas where I drive that there are 3-5 miles b/w gas stations, the electric mode just won't get me that far if I have the bad luck to run out that far from help.
