Rear Hatch opens too high - wife cannot reach
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Wise, Jul 15, 2014.
  1. Wise
    Wise New Member
    Sarasota
    Any ideas anyone? I need to find a way to limit the rear hatch opening ... or find a taller wife : )
    48,999
    welcome to priuschat! some have installed bungees to keep it from opening all the way. some have attached grab straps to the inner surface where the grab handles are and some have installed shorter pistons which are available on line. all the best!(y)
    James Powers and Robert Holt like this.
  3. orenji
    orenji Senior Member
    5,884
    3,486
    Install a strap or rope to the grab handle, easy and cheap.
    James Powers likes this.
  4. JC91006
    16,470
    8,383
    Find a plastic hook of some kind to use as an arm extender. It can hook onto the tailgate latch or the inside handle, just pull down.
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,796
    Undisclosed Location
    Of course the easiest and simplest answer is to have your wifes arms surgically lengthened through bone and skin grafts. Perhaps using the arm bones of a cadaver and/or a gorilla.
    A quick online search should find you a surgeon in South America willing to attempt the procedure.
    Best of luck.
    #5 The Electric Me, Jul 15, 2014
    MainahInFL, Tony D and NuttyKat like this.
  6. xliderider
    xliderider Senior Member
    7,849
    3,103
    Honolulu, HI
    Hatchback hitting garage door solution! | PriusChat
    Not suggested yet. Put a small stool or sturdy box in the back of the Prius for your wife to stand on. :D
  7. JC91006
    16,470
    8,383
    that will end up on youtube....
  8. WA///M
    WA///M New Member
    Chicago, IL
  9. jdenenberg
    jdenenberg EE Professor
    3,837
    1,828
    Trumbull, CT
    2020 Prius
    LE AWD-e
    You can also replace the hydraulic lifters with shorter ones.
    JeffD
    Wise likes this.
  10. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    You could "dump" your car on coilovers. (y)
  11. WA///M
    WA///M New Member
    Chicago, IL
    Yes, now this is a good idea!
  12. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    Sweet ride, but I can't help wondering what it's like to drive every day over some of our roads. :)
  13. qdllc
    qdllc Senior Member
    1,358
    396
    Sounds like the OP married Bernadette from Big Bang Theory. :rolleyes:
  14. orenji
    5,884
    3,486
    Did you get permission to post this ride! LOL :D:D
    #14 orenji, Jul 16, 2014
  15. Wise
    Wise New Member
    Sarasota
    Thanks everyone ... after reading ideas, I looked to see if there was anthing to attach a bungee cord to - none on my 2014 Prius ... no handles ... just grab indentations. Decided to replace hydraulic lifters ... any ideas on size and where to buy???
  16. xliderider
    7,849
    3,103
    Honolulu, HI
    There's part numbers and such in the thread linked to in post #6 in this thread.
    SCH-I535
  17. Tony D
    Tony D Active Member
    468
    132
    Dublin, Ireland
    I'd just go for a taller wife, save worrying about part numbers, will it fit etc? If you're going taller, you're probably best going younger too
    Good luck
  18. MainahInFL
    MainahInFL New Member
    Jax, FL
    There is a simpler solution...tie a small(ish) piece of rope to the hatch where the piston is. Then tie it off at the base of the piston the desired open height. I noticed that the previous owner did that to mine when I was surprised that it didn't hit my garage door when I opened the hatch.
    KennyGS likes this.
  19. orenji
    5,884
    3,486
    Buy her a pair of high heels.
  20. Seattle911
    Seattle911 New Member
    Denver
    I know this is an old thread but there is a no-cost way to fix this problem.
    In the spare tire compartment is the handle that’s used to lift the jack that comes with the car... it’s an l shaped piece of metal with a hook at the end..... take this out and put it under the mat in the trunk.
    When it’s time to close the hatch, grab this tool and hook on to the latch u-bolt in the middle of hatch... the same u-bolt that is used to hold the hatch in place when closed to the locking mechanism. Pull down on the hatch using the tool until the hatch reaches eye level, then slide the tool off, slide it under the mat for next time, and then finish the closing of the hatch.
