Rear Shock Replacement - Tips and Notes
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by The Critic, Jan 21, 2013.
  1. The Critic
    The Critic Resident Critic
    3,193
    2,319
    CA
    Today, I replaced the rear shocks on my Prius. The rear shocks had 54,000 miles on them and were displaying symptoms of failure. The symptoms were excessive body lean (during turns), instability on the highway (wandering, it felt as though it was coming the rear of the car was wandering), as well as a rougher-than-expected ride.
    After 75 miles of driving post-shock replacement, I can confirm that replacing the worn rear shocks has resolved all of my complaints. The ride has improved, the excessive body lean is gone, and the instability on the highway is greatly improved. My front shocks do seem to be borderline marginal, but are in much better condition than the worn rear shocks that I removed.
    Note: the worn rear shocks showed no leaks, however, the L/R shock rod was more easily compressed than the R/R. Perhaps this explains the slight pull I was getting from the L/R side?
    I used new shocks from the dealer, which were under $40/unit shipped from Camelback Toyota. FWIW, KYB was the manufacturer of the original shocks.
    For this job, you will need loctite blue (or equivalent), a 6mm allen key socket and a 17mm boxed-end wrench. It is suggested that the b0xed-end wrench be of a ratcheting type if you want to save time. You will also need a torque wrench (capable of 66 ft-lbs), a 17mm socket & ratchet, floor jack, jack stands, and wheel chocks.
    All of the interior from the rear seat and back, will need to be removed. Be prepared to buy some new clips (white ones) for the trim piece that is on-top of the traction battery, as well as the fasteners for the seat cushion. Having a trim removal tool such as this one may be helpful in the event that the clips get stuck on the traction battery.
    See the pictures that I took for an idea of what needs to be done:
    All interior trim removed; rear seat cushion was unfastened and lifted up for better access. Basically, you will need to remove all of the interior panels behind the seats.
    L/R shock mount:
    R/R shock mount:
    The torque spec for the nut on the shock rod is 18 ft-lbs. You will need to use some kind of adhesive on those threads; I just used Loctite blue. The nut needs to be replaced each time and a new one is included with your new shock assembly.
    In addition, this is VERY important: after tightening the nut on the shock rod, install the 17mm bolt that attaches the shock to the torsion beam, finger-tight only. The final tightening of this bolt MUST be done after the vehicle is lowered to the ground or else you may damage the bushing inside of the shock. The torque spec for this bolt is 66 ft-lbs. Remember that the nut on the 17mm bolt head is a locking nut - you need to turn the bolt itself.
    Lastly, you will need to use your floor jack to lift the torsion beam up/down to remove/install the 17mm nut.
    I hope this answers some questions on rear shock replacement. I would suggest adding this task to your 60k service list - you will be amazed by the improvements.
  2. peterjmc
    917
    188
    Clarksburg, MD
    Nice write up. The biggest pain in doing the rears for me was taking the interior trim apart. The rest of it was a breeze.
  3. The Critic
    3,193
    2,319
    CA
    Yes, and I also broke one of the clips that holds down the rear seat cushion. Two of the clips on the rectangular piece on-top of the traction battery were also chipped. So, it looks like I'll be visiting the dealer tomorrow.
  4. crazyjeys
    crazyjeys Member
    135
    16
    Sunny Socal
    Why did you need to take out the interior trim? Mine has a hatch/cover to open and it exposes the top of the struts already. That's where I loosened the top but of the struts.
  5. The Critic
    3,193
    2,319
    CA
    ?? What hatch cover?
    iPhone ?
  6. gliderman
    gliderman Active Member
    751
    223
    Picture please.
  7. crazyjeys
    crazyjeys Member
    135
    16
    Sunny Socal
    This one!
    Prius_Angie likes this.
  8. Indy John
    Indy John Member
    75
    33
    Indianapolis
    Great write-up! Question: Given the time/trouble/broken clips of removing and reinstalling all that trim, and now that your great photos show us where the shock tops are, why couldn't I carefully cut out little access panels in the trim and avoid all of that effort and frusration? I'll just use little hot-glued tabs and velcro to reinstall the panels when I'm done. What do you think?
  9. The Critic
    3,193
    2,319
    CA
    This must be new for 2012, as my does not have the access panel.
    I suppose you could do that, but it's kind of a "hack repair" since you are short-cutting the job by permanently modifying the car.
  10. Stangar
    Stangar Active Member
    174
    173
    Palmdale, CA
    Yeah, my 2011 doesn't have the rear shock access panels. Here's an idea: Make your own using an Xacto knife. You can cover the holes with the same plastic covers used to access the tail lights. You just have to buy a couple of those tail light covers. Sorry, I don't have a picture of the covers but it will work and look factory. It's sad that a car with such brilliant engineering has such basic considerations deleted. I remember my old 1989 Mustang having access panels for ease of removing the rear shocks.
  11. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    What are those sensor looking things directly above the shock mounts?
  12. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    Thanks for the heads up Critic.
  13. solrunner
    solrunner Member
    114
    37
    Reston, VA
    Thanks for the instructions. I performed this procedure this weekend with my friend who has tools and experience. Took us an hour and a half plus a trip to the store for loctite.
    My car has just 11,000 miles. It was very smooth until I took an unexpected trip across 15 miles or so of dirt roads, and I had my tires up to 44/42 psi. This was when the car had 5,000 miles on it. I thought about getting out and lowering the tire pressure, should have done that. Once I got off the dirt road the car was definitely riding more harsh.
    I took it to several dealers and they inspected it several times and said nothing was wrong. I don't think even Toyota knows how the car is supposed to ride. They did perform an alignment and balance the tires which helped a little. But the car was still rough, especially in the rear. Lots of rattling noises coming from the back over bumps and just harsh.
    After replacing the rear shocks this past weekend (KYB Excel-G, pair on Amazon ordered for $120), I can definitely say the ride is better. Not like new, but way fewer rattles from the back interior and bumps are not as jarring. Definitely glad I replaced the rear shocks. The feeling from bumps in the front and back now seem about even; I am not sure the fronts need replacing. Much more difficult / expensive anyway.
    When I took the old shocks out and compressed them alongside the new ones, the old ones took several seconds more to fully extend. And one of the old ones actually made a couple of faint grinding noises like a piece of sand or something gritty was stuck inside.
    I had no experience working on cars at all. With my friend telling me what to do this was a fairly easy project.
    One thing that surprised him was when we loosened the second shock the springs came loose. He had another jack to prop up the spring mounts on bottom so we could remount the springs. Other than that went smoothly.
    I am now running at 35/33 and might increase it a little bit, but definitely not going over 40 psi again! I learned the hard way not to over inflate and ride on dirt roads.
    Rear shocks are cheap to replace especially if you can do it yourself, and made a great improvement in ride quality.
    The Critic likes this.
  14. corystal
    corystal Junior Member
    40
    Los Angeles
    Did this... but I totally misunderstood the part about finger tightening (until I got home and read it again post-repair =\) but I only drove the car a couple miles so I will loosen and re-tighten them before driving it again. How exactly does it damage the bushings? Is the damage already done?
    Also.. this was helpful
  15. solrunner
    solrunner Member
    114
    37
    Reston, VA
    I'm not a car expert, but if you take the bushing out and look at it you should be able to tell if it looks okay (not cracked or splitting). It would probably be okay after you take it out and install it finger-tight.
  16. Bigham
    Bigham Junior Member
    Do not order the Monroe 5685. Online and parts store offer this as a replacement and it's not. The threaded rod is 19mm and will not for through the shock cover and the rubber washers are generic and not an exact fit.
    KYB 349035 is an exact replacement for the stock shocks at 17mm.
    Unfortunately my price went from 56 for two Monroes to 132 for the KYB.
    Any money I saved was wasted on three trips to the auto parts store and having to reassemble the first strut when I found out the Monroe didn't fit.
  17. Mendel Leisk
    38,344
    I took off that hatch floor piece, the one atop the battery, when doing a fan cleaning. I found them alarmingly hard to remove; though for sure I would break something, luckily didn't. But I decide then-and-there: just leave 90% of them off when reinstalling the floor. I did bag and label them, stow in the underfloor tray.
  18. Tyndall
    Tyndall Junior Member
    NC
    So I replaced the rear shocks this weekend with the KYBs from Rick auto.com. I’m getting a mild knocking noise on the right rear when I hit a bump. (I installed Eibach coils on all 4 corners and new front struts as well.)
    Also, how did y’all get the battery cover panel back on (the one at the base of the rear seats).
  19. Landon51
    Landon51 Member
    190
    63
    US
    Did you every figure out ... the knocking?
    SFO likes this.
  20. elementnomore
    elementnomore Member
    136
    44
    Los Angeles
    98,000, 2012. 50% spent in Los Angeles, nuts were very difficult to remove. Sharing my VIN with a dealer they helped choose the rear shocks but I swear the ones on my car were for the model with 17” wheels. I purchased the car used from a dealer who maintained it so who knows if they swapped the 15” and 17”s. It’s a package IV with a sunroof. I’ll do the fronts tomorrow. Video of how spent they are, no oil leaking that I can tell.
