1. Offline
    mattebury Junior Member
    Start a Conversation
    Apr 27, 2012
    68
    Southern California
    Your Vehicle Year:
    OK. My wife has a liftback-4 that has a backup camera integrated with the satellite NAV screen. Is there a way for me to add that functionality to my C-3, I have the NAV unit as well.
  2. Offline
    vinny1575 Junior Member
    May 13, 2010
    86
    Jacksonville, FL
    Your Vehicle Year:
    I plan on trying it. Has anybody's had any luck with this?
  3. Offline
    ROLOPR Junior Member
    May 22, 2012
    246
    Puerto Rico
    Your Vehicle Year:
    I'm waiting for that answer also, to see which way I place the backup camera
    1. from the 6.1 navi system
    2. from homelink mirror
  4. Offline
    managerman Prius c and Prius v Nerd
    Mar 12, 2012
    229
    85
    Columbus, OH
    Your Vehicle Year:
    Waiting too...really want to know if the 6.1 can be utilized/activated for backup camera...as it is in the liftback...before going with the mirror option...
    -M
  5. Offline
    May 13, 2010
    86
    Jacksonville, FL
    Your Vehicle Year:
    I also have a 2012 Camry XLE that did not come with a backup camera. I purchased the stock camera and a harness for the 6.1 head unit.
    The Camry has the connection behind the head unit. As far as I can tell the screen is exactly the same as my prius C screen. I am hoping to test it out on the prius while installing the backup camera for the camry.
    This will work for the camry, but it says Toyota OEM so I ordered one for my prius as well.. The connectors will work with any backup camera. I'll keep you guys informed.
    Amazon.com: Beat-Sonic BC5 Rear Camera Input Vision Selector Harness for TOYOTA OEM OPTION NAVIGATION HARNESS FOR BACKUP CAMERA: Automotive
    managerman likes this.
  6. Offline
    Mar 12, 2012
    229
    85
    Columbus, OH
    Your Vehicle Year:
    Excellent..Please let us know how it goes!
    -M
  7. Offline
    May 22, 2012
    246
    Puerto Rico
    Your Vehicle Year:
    So far looking in Ebay I found a variety of rear cameras, most of them need to installed where one of the license plate lights is located. I don't know for sure if I will sacrifice that.
  8. Offline
    May 13, 2010
    86
    Jacksonville, FL
    Your Vehicle Year:
    The license plate light cameras still let the light shine through. :)
  9. Offline
    May 22, 2012
    246
    Puerto Rico
    Your Vehicle Year:
    If that's the case I go on with the mod, only left the big question, rear camera support for the 6.1 navi system. Can you tell me which camera works better with light shine through? :)
  10. Offline
    ftl Researcher
    Jun 2, 2009
    573
    183
    Long Island NY
    Your Vehicle Year:
    Do you have a link for the camera? What's the cost?
  11. Offline
    May 13, 2010
    86
    Jacksonville, FL
    Your Vehicle Year:
  12. Offline
    Mik1 Member
    Apr 17, 2012
    335
    49
    Houston, TX
    Your Vehicle Year:
    I took my nav out today, and it is actually took 5 mins to do; however, I didn't find any round analog video connectors out there. Here are couple of pictures of the back if it will help to someone. The only connectors I found are these pin ones.
  13. Offline
    May 13, 2010
    86
    Jacksonville, FL
    Your Vehicle Year:
    Yep its not going to be that easy. With my Camry I had to splice the analog wire and connect it into the holes in the black connector.
    Terminal 7 is 12v and 15 in Gnd.
    8 is video and 16 is video shield.
    Keep in mind this is what I know from the Camry install that I just did. I will verify as soon as I get my camera in the mail. I was able to verify pin 7 and 15 already, but I will need the camera to verify video.
  14. Offline
    May 22, 2012
    246
    Puerto Rico
    Your Vehicle Year:
    I wonder what does the 4 holes grey pin does?
  15. Offline
    May 13, 2010
    86
    Jacksonville, FL
    Your Vehicle Year:
    I wondered that myself. It is also on the Camry.
  16. Offline
    Mik1 Member
    Apr 17, 2012
    335
    49
    Houston, TX
    Your Vehicle Year:
    Vinny, it will be great if everything will work out for you. Please make some photos during yours installation process. I am sure many of us would like to follow your steps. So anxious to hear a good news from you!!!
  17. Offline
    May 13, 2010
    86
    Jacksonville, FL
    Your Vehicle Year:
    I'll definitely post a tutorial if it all works out as planned.
  18. Offline
    Mik1 Member
    Apr 17, 2012
    335
    49
    Houston, TX
    Your Vehicle Year:
    One more question. The rear view camera shall turn on whenever the reverse is engaged right? If terminals 7 and 15 are the power to the camera, terminal 8 is the camera and terminal 16 is the shielding, which is basically the grounding. Is there anything in between the reverse position of the CVT and the navi which will give the signal to the camera's power pins or some additional wiring shall be installed?
  19. Offline
    May 13, 2010
    86
    Jacksonville, FL
    Your Vehicle Year:
    There is something that tells the navi when islets in reverse, but I'm not sure what.
    It was the same setup in the Camry though. I don't think there is additional wiring.
    The camera I ordered can't get here fast enough. :/
  20. Offline
    Mik1 Member
    Apr 17, 2012
    335
    49
    Houston, TX
    Your Vehicle Year:
Share This Page
