Rearview Camera
Discussion in 'Prius c Audio and Electronics' started by mattebury, Jun 2, 2012.
  1. AliIzad
    AliIzad Member
    170
    72
    Southern California
  2. Masterloc
    Masterloc Junior Member
    53
    New York
    2015 Prius c
    Okay, just removed the stereo. Looks like the 2015 Prius C has a completely different layout for the harness. I purchase the kit that seems to be compatible up to 2014. Any help on how to proceed?
  3. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    Can you post pics of how it looks the backside of the radio?
  4. Masterloc
    53
    New York
    2015 Prius c
    I uploaded it in the attachment. First time doing so, not sure if it'll work.
    While I was waiting for a reply, I checked on Amazon, and it seems like there's a kit for the 2015. Apparently, it's a 24-pin connector, and what I'm supposed to do was to remove the factory plug and just plug in the harness. Leaving the factory plug dangling. If that's the case, I'm really curious why I don't need to plug back the factory plug. What were those wires for?
    #324 Masterloc, Jun 15, 2015
  5. Masterloc
    53
    New York
    2015 Prius c
    Well, I got it installed. Works perfectly. took about 2 hours. Used the harness in the link in the above post. Still have no idea what the original wires were for.
  6. sib
    sib Junior Member
    Can you post or re-post the info on exactly what kit you purchased for a backup camera that works with a 2015 Prius c three? Thanks
  7. Masterloc
    53
    New York
    2015 Prius c
    It's the amazon link 2 post above. Paid $124.95 for it. You'll noticed the Harness is not a T-harness.
  8. sib
    sib Junior Member
    Sorry, I must be slow, but I can't find an Amazon link in any of the posts above. Could you please post it again. Thanks.
  9. bisco
    49,072
    do you have ad blocker?
  10. Masterloc
    53
    New York
    2015 Prius c
  11. sib
    sib Junior Member
    Many thanks, I ordered one, I'll report back my experience with it. I really can't understand why backup cameras aren't standard on these cars. The dealer told me that they will be required equipment in the near future.
  12. HybridHipster
    HybridHipster Junior Member
    33
    PEI, Canada
    2015 Prius c
    I just installed that one today with a friend on a Prius c 2015 bought in Canada. Installed great and works fine without any wire cutting or adapters.
  13. HybridHipster
    33
    PEI, Canada
    2015 Prius c
  14. Max Powers
    Max Powers New Member
    2015 Prius c
    I installed this model on my 2015 Prius C One without any problems last week. Plug and play into the stereo. It is a bit of a pain threading the cords all the way to the back hatch, but its worth it.
  15. HybridHipster
    33
    PEI, Canada
    2015 Prius c
    That's what makes it a project rather than just a purchase. ;-)
    Max Powers likes this.
  16. Tim Lillis
    Tim Lillis Junior Member
    36
    Grand rapids
    2014 Prius c
    I think I might do that too. It is the one on Amazon right? Have you done it yet and did it work? Do you need the rear cable?
  17. Masterloc
    53
    New York
    2015 Prius c
    you'll need to make sure you're purchasing the correct year. Harness is different between -14 and 15+.
  18. Priusc-2
    Priusc-2 Junior Member
    27
    Cali
    2015 Prius c
    I finally installed my backup camera. Been sitting on my shelf for a few months now and so i finally decided to install it. Took about 3 hours.
    Pretty easy to install.
  19. Tim Lillis
    36
    Grand rapids
    2014 Prius c
    I got it and because mine is the one trim also had to tap the trigger. Dead as a door nail still. Any pointers? I have a multimeter just not sure how to check for faults
  20. Tim Lillis
    36
    Grand rapids
    2014 Prius c
    i checked the continuity and voltage and everything is working as it should. Is it possible my radio doesn't support backup camera? It's from a 2012 prius c and includes navigation hd and sat radio. The model on the front show 100023
