Red Triangle check engine (PA080 Over Temperature)?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by icesurfer408, Jul 15, 2014.
  1. icesurfer408
    icesurfer408 Junior Member
    Gilbert, AZ
    Hi Guys,
    I need help with this DCode PA080 (Over Temperature). The check engine with red triangle just come on a few days ago and I would like to know if anyone has ever gotten this code? Please help...
    Thanks in advance.
    -Ron
    48,996
    how miny miles on her?
  3. icesurfer408
    Gilbert, AZ
    176,000 miles!
    48,996
    i think that's the hybrid battery, did you get triangle of death? you might want to check your inverter pump, 12 volt and battery cooling fan.
  5. icesurfer408
    Gilbert, AZ
    Yeah the Red Triangle showed up, and also I had the inverter pump replaced 2 years ago (recall)...
    #5 icesurfer408, Jul 16, 2014
  6. usnavystgc
    3,159
    988
    Tucson, AZ
    Yes, that code is the "Replace Hybrid Battery" code. Is the fan in the back running all the time (or nearly)? Does the battery go from fully charged to almost no charge and back to full in about thirty seconds?
  7. icesurfer408
    Gilbert, AZ
    The fan comes on here and there, but not constantly. The battery reading goes from nearly full to 1 bar in about a minute or 2...
  8. usnavystgc
    3,159
    988
    Tucson, AZ
    Yep, replace or rebuild hybrid battery. Sorry
  9. icesurfer408
    Gilbert, AZ
    I do have 2 extra cells layer around that still good. How would you recommend rebuilding the HV pack?
  10. usnavystgc
    3,159
    988
    Tucson, AZ
    IAW scotman27's thread called "got some new 2012 modules"
  11. bisco
    48,996
    it's a time consuming job, and takes some technical expertise. or, you can buy a new one, a rebuilt one or a junkyard dog. all the best!(y)
