red triangle of death!
Discussion in 'Gen 2 Prius Technical Discussion' started by GasSaver1, Mar 9, 2011.
  1. GasSaver1
    GasSaver1 Member
    220
    South Florida\Long Island NY
    a few mornings ago I started up the car and got the red triangle :( I quickly killed it and started agauin and it was still there! I repeated and this time it was gone. Today I did a search and suspected the battery but I wanted to confirm it with the system diagnostic...... No matter how many times I tried I just could not put the car into system diagnostic! At one point I started the car and tried and it actually let me in- the battery showed 14.4v but that just proved the charging system was working.
    So I tried a few more times to put it into Diagnostics and as I was holding down the info button all of a sudden the car beeped once and the error message about parking mechanism came on the screen- as well as more red triangle alerts :(
    So finally when I got home from work I tried again a few times- more red triangles and volt meter directly on the battery said 10.5v but with all those headlight on and offs I was not sure if that drained it. Nevertheless I picked up a new oem battery for $150 and wrestled to get it in....
    Right away I was able to get into system diagnostic! 12.1v to start...
    I went for a drive and all seems ok. I was not able to throw the car into red. I am hoping this was all a matter of a bad battery. What do you all think?
    My car is 3 years old with 41.5k miles on it
  2. uart
    uart Senior Member
    4,215
    1,201
    Australia
  3. Patrick Wong
    18,200
    6,479
    Yes, it sounds like the 12V battery needed to be replaced.
    I'm not able to enter the hidden diagnostic screen with my 2007, although the procedure works fine on my 2004.
  4. GasSaver1
    GasSaver1 Member
    220
    well it is the morning after the battery adventure and everything still seems good. Just to check, I threw it into system diagnostic mode before starting it up and I was reading 12.1v on the battery. I have not seen anymore red triangles so I am hoping it is all solved.
    It was not like the triangles were appearing all the time, only when I was messing with the car to get it into diagnostics or that one time in the morning.
    But I am thinking that the morning event was maybe due to losing charge over night. It may even have been that I was driving the previous night and shut the car off but was slow to turn the headlights off so the battery was in an even weaker state the next morning. Then the triangles appeared again with all the headlight flashing in ACC mode. I guess batteries all have to be replaced sometime.
    I was not expecting it to be so difficult to change the battery! but then again I did it in ther middle of the night with just a flash light. I made the mistake of closing the trunk with the positive terminal disconnected because I needed a tool from the apartment. I guess it would have been good to know that you cannot open the trunk without any power! thankfully I was able to crawl into the trunk from the back seat and reconnect the positive terminal again long enough to pop the trunk again.
    So here are the key lessons from this adventure.
    1. random red triangles on start up could mean battery
    2. if you are normally able to enter system diagnostics and suddenly cannot, this may also point to battery.
    3. If you are changing the battery, do not close the trunk hatch with the battery disconnected because you cannot open it again.
    4. do not forget to reconnect the venting hose to the battery and try to do it after everything is back together. Getting it in with the plastic vent in the way is nearly impossible.
    As far as prices, this is an expensive battery. The OEM toyota discount website that usually has everything really cheap has it listed for 138.00. The local dealer here in south florida had it for the same price but after taxes it is just shy of $150.
    I actually had the Optima kit on stanedby but learned there was no local place to actually get the Optima that fits in the Prius so I went the quick route and hit the dealership.
  5. Patrick Wong
    18,200
    6,479
    It is possible to open the hatch w/o electrical power, but this requires you to climb into the hatch area, remove the folding hatch floor, then find the mechanical hatch latch release which is behind a small rectangular door in the black plastic tray over the spare tire.
  6. GasSaver1
    GasSaver1 Member
    220
    wish I would have known :(
  7. 63jimmyjo
    63jimmyjo New Member
    illinois
    This is my second Prius, first was a 2008 that some moron hit and totaled it. I replaced it with a 2006. Anyway the 2006 had the red triangle of death along with every other light lit up like a Christmas tree. I replaced the hybrid inverter pump that iI purchased from Amazon for about $100 (genuine Toyota part). This required removal of the driver side bumper cover, just enough to pull it back to get to the bolts to remove the headlight. Once the headlight was removed the pump is easily accessible. There are two hoses attached as well as an electrical clip. Then there are 3 bolts attaching the pump to the vehicle. Drain the Denso fluid from under the car using a 15/16" socket, remove and replace the pump, refill the Denso fluid and put a tube on the zirc fitting at the top of the motor turn on the power but do not start the car and open the zirc fitting and let it pump until you see no more bubbles. This fixed my Prius and I hope it fixes yours. It sounds more difficult then it is. the entire repair took about 2 hours. Good luck. Note: the Toyota pump came with new hose clamps as well as a new aluminum gasket for the 15/16" drain plug. Also bleedig the system at the zirc fitting is very important do not skip this step.
    #7 63jimmyjo, Oct 14, 2018
  8. bisco
    49,796
    welcome,
    this thread is 7 years old, but thanks for the write up!
    Skibob likes this.
