Red triangle warning light!!!*
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by pseudolus, Jun 15, 2013.
  1. pseudolus
    pseudolus New Member
    Hey, gang..., Just got my 2004 back from the front end being "reconstructed" after an accident. Occasionally, as I slow down (25 mph or so?, the red triangle/exclamation point) lights up, stays on for a few seconds, then disappears. The car otherwise is running as it always has - nicely. The manual, as expected, is NO help here. Maybe a brake issue, ..? Any thoughts?
    Thanks, Pseudolus
  2. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    With any electrical issues with the Prius always suspect the 12V until proven impossible. I would run the check. Shops are notorious for draining the 12V.
  3. pseudolus
    "Run the check" What's that?
  4. Patrick Wong
    18,210
    6,517
    Check the engine oil level on the dipstick when the car is on level ground and the engine has been off at least 5 minutes. The oil level is probably low.
    koolingit and JMD like this.
  5. SteveLee
    645
    180
    North Carolina
    I
    Patrick's suggestion is likely correct. But to check the 12v do the procedure found here and report back all three readings.
