Remove and replace antenna base
Discussion in 'Gen 2 Prius Accessories & Modifications' started by mehrenst, Mar 5, 2006.
  1. mehrenst
    mehrenst Member
    439
    San Jose, CA
    This has been asked before but not recently and hopefully someone has some new information they can share..
    Does anyone have any suggestions on how to remove and replace the antenna base? :unsure:
    Specifically;
    1. How to get under the headliner at the rear of the roof.
    2. Is it possible to do this without having to remove the complete headliner and "pad"?
    3. Do the plastic trim strips/covers along the edge of the headliner just "snap" away from whatever is holding them?
    4. Does anyone have a pix of the process of removing & replacing the trimstrips, headliner and antenna?
    Thanks. :unsure:
  2. charliehoward
    charliehoward Junior Member
    California, USA
    It's actually fairly quick and easy to replace the antenna base. Here's a link to detailed, illustrated instructions for doing it:
    http://www.wallwatcher.com/Antenna
    When this post was made (August, 2009), the part sold for about $200 on the web. Following those instructions and working slowly and carefully, you probably can do the job in 30-60 minutes.
    4 people like this.
  3. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
    Many thanks Charlie. Those illustrated instructions are fantastic.
  4. nmrickie
    nmrickie Member
    200
    New Mexico
    It's worth going to Auto Zone and getting a trim removal tool (about $10). You'll be less likely to damage the plastic fasteners.
