Removing KARR Alarm
Discussion in 'Gen 2 Prius Main Forum' started by hilore, Feb 10, 2009.
  1. hilore
    hilore New Member
    135
    Palm Springs, CA
    Greetings All,
    I didn't want the KARR Alarm and didn't paid for it.
    There is an umbilical cord width a flashing blue led.
    The dealer said it's been deactivated. Is this mean
    the KARR Alarm still living inside my car?
    Anyone have instruction on how to remove it?
    Manual? Diagram?
    Many thanks!
  2. jelloslug
    jelloslug It buffed right out!
    813
    Greenville, SC
    This is the KARR alarm system in it's entirety:
    There was one installed on my salvage car when I got it. It took about 30 minutes to remove it. Most of the connections were just plug in splices with exception of one at the brake lights. You will have to remove the lower knee plate under the steering wheel to access the area were it was installed.
    roflwaffle likes this.
  3. hilore
    hilore New Member
    135
    Palm Springs, CA
    Thank you for the tip. If the break lights wire were cut. Any suggestion on how to rejoin the cut wire safely/securely?
  4. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    A crimp-on "butt splice" will work just fine. I like to solder the stranded wires first to ensure good crimping. The "butt splice" comes with plastic insulation on it. Probably the red size would be right for that wire. The Yellow is for larger wire (#16 to #12). Borrow the tool or have someone with a good crimp tool crimp it for you. There is nothing worse than a poor crimp electrically speaking.
  5. jelloslug
    813
    Greenville, SC
    I soldered and heat shrunk mine.
