replace shocks/struts?
Discussion in 'Generation 1 Prius Discussion' started by jhknight, Mar 28, 2012.
  1. texaslorraine
    texaslorraine Junior Member
    texas
    trouble with passsenger rear strut. can springs get bent?
  2. Patrick Wong
    18,200
    6,479
    I suggest you provide some photos so we can understand what you are writing about. Also, did this clatter exist with the old right-rear shock?
    If the clatter did not exist previously, then perhaps there is something wrong with the rear shock or its mounting hardware?
    Well, this is possible, or perhaps the rear axle beam is damaged?
    #62 Patrick Wong, Sep 30, 2015
  3. texaslorraine
    texas
    Is that also known as the hubs? if s
    the sound is only with the new strut assembly. the old strut was a bumpy affair but did not clatter. AND, my son took the page out of my prius book and lost it, agh! so I cannot check how to put it back together.. I have all components and was going to reassemble it, for he has sorta given up today. sorta at my wit's end.
  4. texaslorraine
    texas
  5. kutcht1
    kutcht1 Member
    305
    82
    Andover, Minnesota
    Could it be the sway bar bushings/links or some other component than the strut? Are you sure it just doesn't need a wash?
    TomK
  6. Berch1943
    Berch1943 Member
    146
    Arizona
    Hi I got a similar question, is it normal if a shock / strut is leaking. That's what my mechanic told me , should I believe him or is he lying?
  7. Patrick Wong
    18,200
    6,479
    It is normal for a leak to occur and normal for that suspension part to consequently be impaired. However if you hold a high maintenance standard, it would not be normal to accept that condition indefinitely.
  8. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    Rockauto carries them, and the front ones include the top assembly which I call the strut bearing.
  9. FireFighterHill
    221
    92
    Orlando/Clermont
    2003 Prius
    I
    Ordered full front and rear assemblies on Ebay for my 2003 Gen 1. The brand is "Unity". Price for two rear assemblies was $113.15. The two front assemblies were a total of $138.21. The car definitely needed them. It would bottom out going over speed bumps and railroad tracks. And dips in the road led to long drawn out bouncing.
    Brian in Tucson likes this.
  10. Hannahkh
    Hannahkh New Member
    New Jersey
    2002 Prius
    Hello!
    I have a 1st generation 2002 Prius with about 186K miles on it. I went to the Toyota service dealer and they said I need to replace the front struts, shocks, and bushings, which would cost about $1300-1400. I was hoping to keep my car going for at least another year, is it worth it to get it fixed at this point and if so is this a reasonable cost?
  11. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    No, it's not reasonable. It's expensive, that's what you get at a Toyota shop. Can you do any of your own work? Shop Rockauto, you can get the stuff you need at a good price. Any decent shadetree mechanic can do this stuff, even replace the ball joints and control arns. Then have an alignment done.
    If I'm doing the front struts on my 02, I get a set of those loaded struts, new springs, rubber parts, and the strut bearings up on top--even new nuts. And I do tie rod ends.
    Or, you can just keep driving it for a year or so. Probably won't fall apart on you.
    #71 Brian in Tucson, Jul 12, 2017
  12. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    I got these on Ebay. 01-03 Toyota Prius Quick Complete Struts & Coil Springs w/ Mounts Set x4 | eBay Total was about $239. I'm gonna do a brake job and replace the front end suspension and steering components at the same time. Need to have it aligned after the new struts, so why wait. Rock auto sells a Moog front end kit for abput $250. Maybe it will solve all the front end twitchiness on the freeway. I can do everything except the alignment myself.
    FireFighterHill likes this.
  13. FireFighterHill
    221
    92
    Orlando/Clermont
    2003 Prius
    I
    Brian, those are same struts I used from the same seller. I was and still am happy with them.
  14. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    They look okay, no idea how they work, but at least they're easy and a clean install. Got stalled on my Prius project, I bought a Porsche Boxster in need of TLC. Back to the Prius tomorrow.
  15. WHCSC
    WHCSC Member
    277
    63
    Omaha, NE
    2003 Prius
  16. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    They are everything you need to replace your front struts.
    I just noticed that they are Unity brand. The same as what I got on ebay. Unknown how good they are, I haven't installed my set (all four) yet.
  17. WHCSC
    WHCSC Member
    277
    63
    Omaha, NE
    2003 Prius
    Is there a write-up somewhere on how to get at the top mounts?
  18. FireFighterHill
    221
    92
    Orlando/Clermont
    2003 Prius
    I
    To get to the top mounts you have to remove the windshield wiper arms (note their orientation before removing) and plastic "cowling". It has two Phillip head screws holding it on, one at both sides. Once its off you will have access to the shock towers. Before you loosen it from the shock tower mounts you need to remove the wheel and remove the brake line bracket that attaches to the brake line to the shock. I recommend a decent length "breaker bar" to loosen the nuts on the spindle assembly.
    I have the Unity shocks on my Prius and it made a world of difference. Not sure how they compare to say KYB. But they are a whole lot better than worn out blown ones.
    The rear shocks you have to remove the rear seat back to get to the shock tower mounts.
    Brian in Tucson and WHCSC like this.
  19. FireFighterHill
    221
    92
    Orlando/Clermont
    2003 Prius
    I
    While you have it off I highly suggest cleaning out the cowl area with a shop vac and a crevice tool, then cleaning the area with some dish soap, a scrub brush and a garden hose. Just be careful not to soak your cabin air filter.
    WHCSC and Brian in Tucson like this.
  20. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    I may be the only person here that regularly cleans the cabin air filter on a regular basis.
