Replaced Bad Battery Module now won't start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Patrick Jordan, Mar 1, 2014.
  1. Patrick Jordan
    Patrick Jordan New Member
    Hi All initially got the error code P0A80 which indicated a problem with the traction battery which was confirmed by the Toyota dealer. Pulled the battery and found the bad module and replaced it with one from Battery Boy on Ebay. Put it all back together cleared the codes and now it will not switch into drive just stays in Neutral. I included a pic of the dash readout. Any help would be appreciated.
  2. jdenenberg
    jdenenberg EE Professor
    3,837
    1,828
    Trumbull, CT
    2020 Prius
    LE AWD-e
    This is usually caused by not sliding the safety plug into position after inserting it. Many have overlooked this as it is not obvious.
    JeffD
    48,995
    did you balance the cell's, or just chuck a new one in there?
  4. uart
    uart Senior Member
    4,215
    1,200
    Australia
    This is a very common mistake.
  5. greasemonkey007
    greasemonkey007 Active Member
    286
    104
    South Central Arkansas
    When you insert the safety plug and fold the handle up, you have to push the handle straight down to lock it. This makes an electrical connection, could be the problem.
  6. bisco
    48,995
    did you make the correct safety plug connection? it's not as obvious as it may look.
  7. JC91006
    16,470
    8,383
    My mechanic couldn't figure out why my car wouldn't start after a transaxle swap, and this simple push on the lever to lock was the key to starting the car.
    This would also trigger DTC P0A0D
  8. ericbecky
    ericbecky Hybrid Battery Hero
    4,365
    3,209
    Madison, Wisconsin
    Sound like you have a scanner. Are other codes present?
    If so, list them here and we can help.
