replaced hybrid battery drives great but have red triangle
Discussion in 'Generation 1 Prius Discussion' started by drsjr1969, Sep 22, 2014.
  1. drsjr1969
    drsjr1969 Junior Member
    la quinta, Ca
    well I saw one other thread on this topic but no resolution. I replaced the hybrid battery like the codes told me too on my 2003 prius and it now drives great but as soon as it start it shows a problem and the red triangle stays on. No check engine light, no codes, no driving issues just a red triangle.
    Hoping someone has knowledge of this or how to diagnose a red triangle when there are no codes.
    we
  2. LEVE
    LEVE Member
    191
    97
    On the Willapa
    Do you have a code scanner that will turn off all DTC's?
  3. bwilson4web
    15,407
    You need a Prius-aware, OBD scanner. There are Prius-specific OID codes.
  4. drsjr1969
    la quinta, Ca
    I have code reader that is about 8 years old. reads and erases codes like it always has. Are you telling me there are new models of code readers that are prius specific or just that mine is outdated? Is there something still to read with just a red triangle that a regular code reader doesn't pick up?
  5. Britprius
    Britprius Senior Member
    5,194
    1,912
    Herefordshire England
    Most scanners will not read the Prius specific codes. Emissions related codes are standard by international agreement so generally engine codes are all the same from car to car. There is no such agreement on manufacturers specific codes, transmission, airbags, ABS, traction control, and others.
    The best and cheap system is the Mini VCI with Techstream software using an old preferably Vista/ XP laptop. This can read all Prius codes, and sub codes, and is capable of all the service tasks such as zero point calibration, brake bleeding, programming to key fobs, ect.
    Costs about $25 plus a laptop. It will work on all Toyota and Lexus cars.
    John (Britprius)
    #5 Britprius, Sep 22, 2014
    bwilson4web likes this.
  6. robert mencl
    robert mencl Member
    173
    49
    hartland me
    2002 Prius
    I
    SJR, have you tried the cave-man method, remove a terminal from the 12v battery for a minute to clear the code...you may lose stored dtc codes, but if the beloved triangle doesn't come back there wasn't a problem to start with....I did take Wilson and Britprius' advice above and got the $25 scanner, too cheap to pass up.
  7. drsjr1969
    la quinta, Ca
    Yes fail to mention that I have disconnected 12v battery many times for up to 10 min and as soon as I start car it comes back.
  8. JC91006
    16,470
    8,383
    There are no magical code readers that can eliminate problem codes that are existing. No matter how many times they are erased, they'll come back if the problem is not fixed/addressed.
  9. drsjr1969
    la quinta, Ca
    That has been the frustration, there is no check engine light and no code to read. I have ordered the mini vci maybe that will tell me why the red triangle keeps coming on since I have no codes to read right now when its on.
  10. LEVE
    LEVE Member
    191
    97
    On the Willapa
    After I reworked my 2nd Prius' battery I installed it and before I tightened it down with one bolt and then started the car. I figured that I'd like to just make sure everything worked before went to the bother of reinstalling every bolt. As the car started the red triangle come on and I was shocked.
    Then I remembered that I'd not not reinserted the safety plug. After shutting of the engine and reinserting the safety plug I restarted the engine. The triangle was still illuminated.... no cods. So, I used my Scangauge II to turn off all
  11. ChapmanF
    15,110
    Since you had a ScanGauge II, did you try programming it with the XGAUGE data to read the HV and battery ECU trouble codes and inf codes? I'm betting that if you had, you'd have seen at least one of: P3004(inf 131) for the service plug out, P3140(inf 350) for the interlock circuit open.
    Generally, if you've got warning lights on, it's because you've got codes. If you make sure you have a code reader capable of reading the codes in a Prius, you'll know more about what's going on than if you don't.
    -Chap
  12. LEVE
    LEVE Member
    191
    97
    On the Willapa
    Nope, I'd already used my Denso Toyota specific Hand Held Scanner to do the diags. I used the Scanguage for fun... and to see what it would do.
  13. drsjr1969
    la quinta, Ca
    just loaded this toyota mini vci software on laptop and it does nothing but ask for regestration info which it didn't come with and I can't use it unless I have a wifi signal? Wth ....... I thought I was getting a program I could just load up and use. you guys that recommended this how do you use it?
  14. dolj
    dolj Senior Member
    7,510
    3,773
    Wellington, New Zealand
    Close TS, edit the file IT3System.ini as below, then open TS again:
    open My Computer, C: Program files\Toyota Diagnostics \Techstream\Env
    open IT3System.ini file and scroll down to
    AVAILABLE FUNCTION SETTING
    Switch TISFunction=1 to TISFunction=0
    Click File, and Save.
    #14 dolj, Sep 28, 2014
    Prius_Cub likes this.
  15. drsjr1969
    la quinta, Ca
    still can't get this software to work for me. I try to connect and get a error everytime. I try doing a cable check and it fails everytime. I must be doing something wrong? help please.
  16. bwilson4web
    15,407
    Perhaps you might include some of the error messages and a few screen shots?
    Use "print screen" and "paint" to make jpegs.
  17. dolj
    dolj Senior Member
    7,510
    3,773
    Check out this thread over on TundraTalk: Techstream ABCs and 123s: Reference point for all new users and check your install. If you still have problems after this, please post some screenshots as Bob mentioned above.
