Replacement of 12 volt auxiliary battery
Discussion in 'Gen 2 Prius Main Forum' started by dzitlow, Jun 24, 2005.
  1. seeh2o
    seeh2o Prius OG
    447
    16
    City of Angels
    Thanks so much, Ron. I'm stuck in Las Vegas right now. Back home in Los Angeles, I have the BEST guy who works on my car...if I didn't have the dogs with me, I'd have had the battery jumped and just driven straight to his place and he would of changed it out for me on the spot. I talked to him this morning, he thought it would be safe to do it that way, but again, I'm more concerned about the dogs. I won't melt and overheat, but they might!
  2. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    I hear ya, if you are forced to make the trip do so without shutting the car down. Jumping a Prius is very risky. If you ever get the cables reversed, you are looking at a four digit repair bill. The Prius will run Ok as long as it is in ready mode with a bad battery. The worst that could happen would be your mileage to suffer if you have a dead cell. Get a new battery as soon as possible. Good luck to you.
  3. seeh2o
    seeh2o Prius OG
    447
    16
    City of Angels
    While I was in the parking lot at B, B & B, a woman walked by and asked what happened. I told her the little battery died. She said the same thing happened to her daughter last night and she had to have it towed to a shop. Then, this afternoon I found out that a friend of mine back in LA had the same thing happen to her Prius yesterday.
    Could the unseasonably hot weather be wreaking havoc on weak 12 volt batteries?
  4. dorunron
    3,318
    1,103
    Houston, TX
    Unfortunately, a 12 volt battery always seems to die at the worst time. With the Prius there really is no warning signs like a slow cranking engine. What usually happens is the electronics start acting funny and sometimes the red triangle will appear when you first go into ready mode. But yes, heat can kill a battery just as much as cold temp can kill one too. All batteries have a life span. Sometimes they just last a little longer than others, but eventually they will have to be replaced.
    One thing that helps on the Prius is this test you can run. Take a look at this string.
    Weird stuff happening? MPGs dropping? Test The Battery | PriusChat
    Ron
  5. Britprius
    Britprius Senior Member
    5,194
    1,917
    Herefordshire England
    The AH capacity of the battery has no bearing on it's day to day running of the car, but in terms of reliability the higher the AH capacity the better. If it were the case of using the correct AH battery the Optima would be a no go as it is lower than the OEM battery.
    John (Britprius)
  6. Nakedinthewind
    Nakedinthewind New Member
    Bishop, GA
    StreetSideAuto.com, LLC
    http://www.streetsideauto.com/
    [email protected] 877-787-8989
    Optima 8171-767 - YellowTop; Deep Cycle Battery
    $147.05 + Free Shipping
    It is a direct fit. I just installed mine today....
  7. AvTech72
    AvTech72 Junior Member
    28
    Miami Beach, FL 33140
    Three Touring
    Hello I know this is an old post, but it seems Toyota does not have original OEM 12v aux battery # 28800-21170.
    Any suggestions where to find it, or just go with Bosch replacement?
  8. Georgios
    Georgios Member
    126
    85
    Chicago
    Advance auto with 20 online coupon and $22 refundable core its total for around $177 and that is AGM Battery. They also have much cheaper "silver" which could be ok or very good or very bad. Some of the advance auto battery for german cars are made in germany and last long time.
    Alsto the post before was stating the exact part number of the Optima.
    Walmart probably has some options too, Autozone, Napa...
  9. Stevewoods
    Stevewoods Senior Member
    650
    1,005
    Seattle, WA
    And, you can get a real Toyota with a great warranty for $20 more.
  10. bisco
    49,796
    try another dealer, or the bosch is fine
  11. Beshara1111
    Beshara1111 Junior Member
    57
    I had purchased the 12V31M Westco elsewhere and went to a few auto stores getting post adapters, a new negative cable, vent tubing, and fashioning wood blocks for making the hold down work, and would have rather have had a kit like the above had I known about it.
    The elearnaid site now appears to sell a Deka battery instead of the Westco. I don't know how to compare performance, but it is also a Miata replacement. The site recommends an Optima battery replacement, but many comments on different sites claim Optima quality is no longer consistent...
    #111 Beshara1111, Mar 4, 2021
  12. uclabruins
    uclabruins Member
    265
    City of Angels, Baby!
    What's the best 12V battery to replace with these days if not Optima Yellow Top? OEM? Thanks in advance.
  13. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,790
    2017 Prius c
    OEM.
    But right at the moment, the best answer might be: Whatever direct replacement that you can find.
    "Piece parts" for a LOT of things are scarce at the moment.
