Replacing Condenser .. need help
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SWprius08, May 4, 2011.
  1. SWprius08
    SWprius08 SoCalprius
    170
    Los Angeles (SFV)
    Hello all,
    I need to change the condenser of my Prius as flying debri broke it. I just recieved a new one ordered online. I do not want to have it replaced or charged at the dealership as they are too expensive. I found this mechanic shop who quoted me about 4 times less than the dealer to replace the condenser and charge the system. But he is not aware that Hybrid cars requires POE refrigerant oil. I am planning to buy it myself and give it to him to use it on my car. I want to know if there any other guage or oil or freon that I should buy and give him to use while replacing/charging the system rather than using it from his shop which probably was used on a car using PAG refrigerant oil? Any help will be gretly appreciated.
    Also, the new condenser that I got has some of these lines bent at 3 locations, probably due to shipping and handling. Is this something to worry about? Should I talk to the store where I purchased this condenser from and get try to get it replaced? See pics, please help.
  2. SWprius08
    170
    Los Angeles (SFV)
    I guess I am asking too much ... huh!!
  3. prius4ed
    prius4ed Member
    120
    Irvine, CA
    I'm a SoCal Prius owner too. My Prius had a front end collision which damaged the AC line (line with the sight glass on it) and let all the freon out. I asked around, including a Toyota Master Technician at a dealership in NorCal. He said the oil stays in the AC compressor, and for my case all I need to do is replace the broken line and recharge with R134a. No AC oil needed. In your case, you're replacing the compressor - he said the new compressor should come filled with oil (if not, you need to fill it with ND-11 hybrid oil). The caution is if you or a shop charges the freon, not to let "conductive non-hybrid oil" get into your Prius system - it may exist in the AC charge system lines. I'm not taking chances; I'll buy freon in pressurized cans (Harbor Freight on sale this week) and add it myself that way.
  4. SWprius08
    170
    Los Angeles (SFV)
    prius4ed, I am changing the condenser, not the compressor.
  5. Patrick Wong
    18,200
    6,479
    You probably know that a vacuum pump is required to evacuate air out of the system before adding the refrigerant. I would be concerned that the oil residue from the pump might contaminate the Prius AC system.
    Considering the fairly high replacement cost of the Prius AC compressor which is subject to failure in the event the wrong oil enters the system, I personally would have a Toyota dealer handle AC component replacement.
  6. prius4ed
    prius4ed Member
    120
    Irvine, CA
    need to replace AC oil if system broke open in a crash? How?
    Hi Patrick. I was hoping to hear from advice from the forum about this before I try it myself. Yes, the compressor is a costly item, hence many months of deliberation on doing this myself. I agree there are risks (but mostly out of my own admitted ignorance on this). I suppose the vacuum pump, although "sucking air out", could theoretically introduce the wrong type of oil (which is in the lines connecting the pump to the gauge manifold and to the car, and in the vacuum pump itself) into the car's system due to vapor pressure. I was considering buying a new gauge manifold set, to reduce part of the risk. By the way, do the new manifold gauges come with any kinnd of oil in them? If not, this part should prevent the wrong oil in the manifold lines from getting in.
    To completely eliminate contamination, I just saw an interesting vacuum device on Harbor Freight for $15, designed for evacuating AC systems. It uses a venturi effect, and shop air flowing at some 4.2 CFM @ 90 psig to generate a vacuum strong enough to work for AC systems. I'm tempted to try it.
    I don't know what a dealer charges to evac and recharge a Prius, but doing it myself would cost me: $50 new gauge set, $15 venturi vacuum device, $25 freon = $90.
    Oh, was wondering your opinion on whether any ND11 AC oil was lost if a car accident caused the line with the sight glass to break and let all the freon out. I think the line broke open near the sight glass. I heard the oil returns to the compressor when it's not operating. My super Toyota master tech friend insists very little oil would have been lost by a ruptured freon line, but my high school auto shop memories tell me the oil circulates through the AC lines when it's running - which would explain how compressors get oil even when they're mounted high up in the AC system. By this logic, if the AC was running when the accident happened, I'd expect a lot of oil was lost. How would a shop hadnle this? I read somewhere you should drain the oil, measure exactly what was drained out, and add the same oil in. That may work if you are replacing part(s) of a system that was never broken open. For a system that was broken and all the freon let out (with whatever oil was lost), is there a way to drain all the oil left in the system, flush the lines, fill the correct amount of oil in, then close up the system, evacuate, and add freon? Would a shop do this on accident vehicles? Your thoughts please?
  7. Patrick Wong
    18,200
    6,479
    I agree that there's no way to know how much oil remains in a system that has been damaged by accident and left unrepaired for months. Hence it would be best to drain the remaining oil (might be necessary to remove the AC compressor to facilitate this) and install the correct amount. I suggest you obtain the repair process from techinfo.toyota.com if further guidance is needed.
  8. SWprius08
    170
    Los Angeles (SFV)
    Patrick,
    Follwoing your advice I did get the condensor replces at the dealership. Peace of mind atleast. No I did not know that a vaccum is needed to recharge the AC. Thank You Much.
  9. SWprius08
    170
    Los Angeles (SFV)
    Oh and BTW the condensor with bent fins did work. But the dealer said that it is not normal.
  10. miscrms
    miscrms Plug Envious Member
    2,076
    523
    Phoenix, AZ
    SWprius, if you're still around would you be willing to share how much the dealer charged for installing your condenser and recharging? In a similar situation. Condenser damaged by debris, bought a new one off ebay, trying to decide whether to give it a shot or take it in to have the dealer do it.
    Thanks,
    Rob
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,812
    Clearwater, Florida
    Btw, most condensers that are damaged on a G2 are because the plastic plate is missing from the bottom.
    Missing plate is a guaranteed condenser damage given how low the front end on the car is.
    I know your car damage was from an accident but alot of body-shops forget that plastic plate because the plate body attachment points are destroyed making it difficult to re-attach without a rig.
    If you can look at the condenser and see the ground underneath it its missing the plate.
    SageBrush likes this.
  12. dorunron
    dorunron Senior Member
    3,318
    1,104
    Houston, TX
    Rob,
    I had that kind of work done on our Gen II Prius 09 Model Package #2 Dealer charged me over two days time a total of $910 and a few odd cents on two separate work orders for the whole job. That included diagnostic, dye, O-rings, Condenser, and labor to do the job. They did it over two days. First new O-rings, add dye and recharge. That didn't fix it completely. Said it still needed the condenser. Ordered that and finished the job the following day. The only thing they really burned me on was the Freon as they charged the thing twice and charged $16.50 each time. The Condenser was $309.53, O-rings ran $2.86, Dye ran $6.83 Labor ran right at $495.00 by the time they got through. Of course there was taxes in there too. I think the break down above pretty much covers the fees they charged me. After all the work was done had no more trouble with the A/C. It gets HOT here in Texas and believe me we used it as needed. Work was done July 19th and July 20, 2012. Sold car last Friday and dropped it off today to get our new Gen III Model 3 Prius.
    Hope this helps you. FWIW, Gen II Prius is a great car. Gen III so far seems to be just as get, if not better. Only time will tell!
    Best of luck to you!
    Ron (dorunron)
  13. miscrms
    2,076
    523
    Phoenix, AZ
    Thanks Ron, appreciate it!
    Rob
  14. dorunron
    3,318
    1,104
    Houston, TX
    Your welcome Rob.
  15. SWprius08
    170
    Los Angeles (SFV)
    Hey Rob,
    I vaguely recall the dealer charged somewhere between $400 and $500 as labor only to replace the condenser. Been few years now no issues with Air conditioning. Good luck.
  16. miscrms
    2,076
    523
    Phoenix, AZ
    Ok, thanks! Appreciate the follow up.
  17. dorunron
    3,318
    1,104
    Houston, TX
    SW hit it right on the head. Remember that is about what they charged me. Honestly, if you got the money let Toyota fix it for you. That way it will be right. Any thing done wrong might damage the compressor. That part is NOT cheap.
  18. Expo Prius
    Expo Prius New Member
    Is this true? I will be installing a new condenser on my Prius this week. I know I have to vacuum the system but wouldn't this vacuum suck out all the oil too?
  19. miscrms
    2,076
    523
    Phoenix, AZ
    When I did mine I found that the repair manual on TIS recommends adding 1.4oz of oil when replacing the condenser.
    Here's the thread from my DIY replacement: 2005 AC Condenser Replacement | PriusChat
    Rob
  20. Expo Prius
    Thanks for the useful info miscrms. I think my compressor is bad. It's running but I'm only getting 40 psi on the high side. The system seemed to recharge too quickly as well. It got to 30 psi (low side) after only a few seconds of charging. I didn't even use 1/4 of a can of refrigerant.
