replacing convex with flat mirror
Discussion in 'Gen 2 Prius Accessories & Modifications' started by zeeman, Mar 16, 2008.
  1. zeeman
    zeeman Member
    211
    I do not like the convex mirror that is on passenger side.
    objects always look further then they are.
    this is a real pain in heavy traffic when i need to change the lane.
    is there an alternative, either factory or aftermarket, so that i can replace just the glass/mirror part with a flat mirror, just like the one on driver side?
    j12piprius likes this.
  2. patsparks
    10,664
    567
    Adelaide South Australia
    Go to a window glass replacement place, ask them to stick plain flat mirror over your convex glass. They will cut it to match what you have.
  3. zeeman
    zeeman Member
    211
    not a bad idea -- thanks!
  4. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
    Alternatively, you might be able to find a "close enough", if not perfect, glass match at an auto parts store for around $10. Just make sure it's glass, and not the mylar reflective material that they also sell.
    If you do go with the glass shop custom cut, can you let us know how much it cost? If reasonable, I might want to do it too, or I might do it if and when either of my side mirrors' glass is ever cracked or shattered.
    Thanks.
  5. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Just curious... How long have you been driving. Those mirrors have been on passanger cars for years.
  6. eestlane
    eestlane Member
    110
    Space Coast, FL
    Be very, very careful because you will get a large blind spot because you are much further from the mirror than you are from the flat mirror on the driver's side. If you do put a flat mirror there, you will also need a large blind spot mirror there or you will feel some real pain when you switch lanes without seeing what is really just beside you.
  7. patsparks
    10,664
    567
    Or you could turn your head, it's why we have a moveable spine all the way from our bum to our skull.
  8. priusguru
    priusguru New Member
    Hollywood, California
    the vehicle is engineered and the mirrors put that way for a reason, but there are alternatives @ your local auto parts but doubt very much that an aftermarket is available, custom glass is the way to go but how long will it last i dont know if a custom cut mirror will be able to withstand the weather, food for thought....
  9. patsparks
    10,664
    567
    Thanks Bill.
    I wonder why they use this as the point for difference between a light and heavy vehicle?
    "with GVWR of 4,536 kg or less."
    Why not 4500kg?
  10. Jiipa
    Jiipa MGySgt USMC (Ret)
    314
    Oahu, Hawaii
    1 Kilograms (kg) = 2.20462247604 Pounds (lb)
    4536 Kilograms (kg) = 10000.1675513 Pounds (lb)
    Guess that it's close enough to 10K lbs. for government work.;)
  11. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    While the US DOT may speak in metric terms, it thinks in customary measure.
  12. zeeman
    zeeman Member
    211
    around 35 years
    not on my European cars, and i only drove European cars until now. from Fiat, Lancia to Maserati, Mercedes or Volvo -- not one of my cars had convex side mirror.
    next question please ;)
  13. patsparks
    10,664
    567
    One wonders why they don't speak in US measurements then. At least now I know why we use 4.50 tonnes as the maximum GVM (Gross Vehicle Mass) for a light vehicle. Before metrication the limit was an unladen mass of 3.5 tons.
    How OT is this?
    What have we done with the mirror Zeeman?
    Are you happy with it?
  14. zeeman
    zeeman Member
    211
    well, my temporary fix is that i tilted my rear view mirror to 'cover' the right rear pillar, there seems to be a blind spot anyways.
    now, i can see through the right side of rear window and about 60 % of rear window.
    I am still searching for a good solution, as i heard that regular mirror glass will not last much.
    Carr mirrors seems to be double mirror glass type, for durability and cutting light reflection, it is a sealed type, so i was told that regular mirror would quickly attract the moisture and begin to bring the spots in.
    maybe i will go to a glass shop and talk to someone.
    i am open to any other ideas.
  15. Jiipa
    314
    Oahu, Hawaii
    Can't you just get another driver's side mirror, Prius or other mirror that is close in size, trim to fit and replace the passenger mirror in it's housing?
  16. NoMoShocks
    NoMoShocks Electrical Engineer
    1,292
    81
    Camas, WA
    I don't think it is safe to change lanes without looking over your sholder.
  17. Bill Merchant
    4,096
    81
    That's it, zeeman! Import a Japanese driver's side mirror! Since Japan is right-hand drive, the driver's outside rearview mirror will be flat. You can probably get just the mirror, not the whole assembly. Get in touch with Sigma Automotive or Japanparts.
  18. patsparks
    10,664
    567
    Do you ride a bike too? get ready to get howled down like I was for suggesting such an atrocity.
    Also you might hear about how dangerous it is to leave any more than 18 inches between cars at highways speeds. God forbid another driver might squeeze in.
  19. Boo
    5,051
    483
    97
    Flushing, NY
