Replacing rear bumper protector
Discussion in 'Gen 2 Prius Accessories & Modifications' started by quixotequest, Sep 4, 2007.
  1. quixotequest
    quixotequest New Member
    40
    My 05 Prius clear rear bumper protecter has cracked off in 2 places on the outside edge (and chipped the paint) where my wife's grandpa had backed up into something. Thankfully that was the worst for an otherwise wonderful car which we've loved over the last month. I'm wondering how I could safely remove it to either replace it (after retouching the paint) with a like item, or one of those black rubber ones I see for sale here at the PChat shop.
  2. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    <div class='quotetop'>QUOTE(quixotequest @ Sep 4 2007, 05:16 PM) [snapback]507010[/snapback]</div>
    You probably will not need to remove it if you get one of the heavy duty black bumper protectors. I applied mine over the thin factory one and it covers the scratches.
  3. quixotequest
    40
    <div class='quotetop'>QUOTE(seasalsa @ Sep 4 2007, 08:36 PM) [snapback]507085[/snapback]</div>
    How much of the front edge does the black bumper protectors cover? IOW, would it completely cover the cracked area and chipped spot once I retouch it? (The left side of my clear bumper protector is cracked, broken and paint similarly chipped in the same place as it is on the right, as shown here.)
    [attachmentid=11154]
  4. seasalsa
    1,278
    Kent, WA
    Yes, ther one shown in the Acessory Shop should cover that easily. No need to touch up either, plastic don't rust.
