Rotten Egg Smell / Sulfur Smell?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ITGuy1024, Aug 21, 2011.
  1. ITGuy1024
    ITGuy1024 Junior Member
    78
    York, PA
    Hey Guys / Gals,
    For the last 3 months or so I have noticed my car is creating a rotten egg / sulfur smell when going up long steep hills. At first I was hoping it was just some older car a head of me causing it, but even with nothing a head of me the smell returns. AC is off and windows can be either up or down and I smell it.
    Car has 50,xxx miles, no codes, no change in mpgs.
    Any ideas / input?
  2. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    I'm no expert but it might be an exhaust leakunder you car combined with a bad catalytic converter. Possibly the plastic fairings under the Prius cause air to sweep back up to the front of the car and enter the cabin air intake. Just guessing.
  3. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    Charging a lead-acid battery (auxiliary 12v battery) can give off hydrogen sulfide (the chemical in rotten egg smell). Perhaps you are only smelling going up hill, since it is lighter than air. Or you are charging mostly when going up hill. Just a guess.
    [Edit: I should note, that the original 12v auxiliary battery is sealed, so if you are smelling its chemicals, you will want to check it out, and possibly replace it).]
  4. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Isn't a rotten egg smell something to do with over fuelling the cat? Either that or a bad batch of petrol with too much sulphur in it.
    I'd fill her up again from somewhere reputable and see if the problem starts to go away.
  5. Tideland Prius
    16,206
    I was gonna say A/C until you mentioned that it was off. Sometimes it can give off a musty smell.
  6. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    . I will make a wild guess that BECAUSE your AC is off, your HV may be overheating, this is very injurious to the HV battery. Run your AC high in the beginning and then moderate to comfortable for the rest of the drive. High temps are killers! :cheer2:
  7. FreydNot
    FreydNot Member
    210
    37
    Seattle, WA USA
    Consider switching brands of gas for your next fill up. If the smell reduces greatly or goes away completely then it was poor quality gas.
  8. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    I get this sometimes too, although I'm not sure that I would associate the smell with sulfur. To me it smells like something heating up and working harder. It has never been associated with any sort of error code or problem, so I assume it's just that most of the time my Prius has a pretty easy time of it, so a bit of organic material builds up to later burn off when it works harder.
    There can also be a similar smell from the battery vent on older Prius. Check out hobbit's page for more information.
    Tom
  9. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    No they are NOT sealed. The OEM battery in my 08 had a vent tube, as well as the optima I upgraded to.
    I would check the 12 battery and see if the vent tube is plugged and popped out of the vent port. :eek:
  10. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
  11. qbee42
    18,058
    3,074
    Northern Michigan
  12. 2009Prius
    2,705
    510
    63
    I must have scanned too quickly. :)
  13. Feri
    Feri Active Member
    761
    144
    Another thought! you still may have a crap catalytic converter and your rear door seal is not air tight.
  14. wjtracy
    wjtracy Senior Member
    11,329
    3,593
    Northern VA (NoVA)
    Let's assume it is sulfur smell. The 4 sources of sulfur I can think of are:
    Sulfur sources
    1. H2SO4 in 12v batt
    2. Sulfur in Rubber (eg tires, maybe the EV and 12v batts vents rubber tubing per older post)
    3. Sulfur in gaso (<10 ppm S these days - very low)
    4. Motor oil zinc additive
    The two sulfur smells would be H2S (rotten eggs) or SOx (burning matches smell)
    Sulfur smells
    1. H2S (rotten eggs) via reduction with H2
    2. SOx (burning matches) via oxidation with O2
    Sounds like we are talking a battery source if it is really rotten eggs. I must do some checking myself. Never had any battery smells from 2006 Prius. Apparently both batteries can make some H2 that could react with rubber vent tubes? Not sure. If it was SOx smell I'd go with tires rubbing or possible cat converter. Maybe burning motor oil but thats a long shot. Probably nose can smell H2S at trace levels, so that may be what is happening.
  15. arayan
    arayan Junior Member
    UK
    did you manage to find out what it was? i am also smelling somehing quite sharp in my cabin
  16. MNGoan
    MNGoan New Member
    La Crescent, MN
    Ignition coil or sparl plug issue on 1 or more cylinders?
  17. wjtracy
    11,329
    3,593
    Northern VA (NoVA)
    Hey wow I remember saying that. Apparently Originally Posted by ITGuy1024 so you'd have to message him. Also you probably saw my post to check your air filter inside the car vent system.
  18. daveinthesky
    daveinthesky New Member
    Los Angeles
    I just had this same exact problem. My car was smelling like sulfur / rotten eggs and it wouldn't turn on at all. The car was dead, dead, dead. The "Security" warning light kept coming on, as if the key wasn't registering. Weird!
    It turns out that it was the Auxiliary Battery in the back of the car next to the spare tire. I bought a replacement (Optimu YellowTop battery) at autozone and, voila, the car came back to life. I saved myself a whole day of hassle by doing it myself.
    You'll need a socket(?) wrench with 12mm and 10mm pieces to do the replacement. It took about 15 minutes.
  19. Okinawa
    Okinawa Senior Member
    1,333
    317
