ScanGaugeII work on 2010?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by taxachusetts, Jun 29, 2009.
  1. adrianblack
    adrianblack Member
    447
    187
    Los Angeles
    Injector Volume (ml)
    TXD: 07E0213C
    RXF: 0461453C0000
    RXD: 2810
    MTH: 00017E6D0000
    Untested
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Keep up the good work/testing. How would you deal with the multi-frame responses? Oh, I see you are writing to that post as well...
  3. adrianblack
    adrianblack Member
    447
    187
    Los Angeles
    I have two working Xgauges here for the 2010 Prius. Don't use my untested one below -- I had an error in it.
    Battery AMPs for Gen III prius (- values are charging, + values are draw) -- tested working
    TXD: 07E2218A
    RXF: 0461858A0000
    RXD: 2810
    MTH: 0001000AF334
    Fuel Injector Volume (ml) for Gen III Prius -- tested working
    TXD: 07E0213C
    RXF: 0461453C0000
    RXD: 2810
    MATH: 000101440000
    (Sadly when the ICE shuts off, the computer keeps reporting the last known value ... it does not show 0.00 except when you first turn on the car before the ICE starts.)
    6 people like this.
  4. adrianblack
    adrianblack Member
    447
    187
    Los Angeles
    We are SOL for multi-frame/multimessage with current 3.17F firmware as it's not just three responses to one command, you have to send two commands in sequence ...
    I think our best bet right now is for someone who is monitoring the CAN bus to find the broadcast traffic for some of these parameters. Plenty of information flows at all times on the CAN bus and it's just a matter of time before someone can figure out the packets we need to pick up on the scan gauge. The the best thing about listening to these packets already on the BUS is often their refresh rate is very fast.
    I have a "MPH" xgauge on my SGII that runs at about 60fps picking up on broadcast traffic. (it's the same xgauge as for the Gen II car.)
  5. John2010
    John2010 Junior Member
    Portland OR
    Thanks Rob H & adrianblack. I tried the single back up fix and it worked great!
    2 people like this.
  6. adrianblack
    adrianblack Member
    447
    187
    Los Angeles
    2 people like this.
  7. adrianblack
    adrianblack Member
    447
    187
    Los Angeles
    Oh ya, something else .... I wanted to see what would happen if I tried to set that parameter with other values besides 0x40 .... I tried 0x01, 0x02, 0x04 and none worked. (I didn't get the confirmation message.)
    But 0x80 was stored ... strangely, it disabled the beep in exactly the same way as 0x40. I was thinking maybe it was a binary setting and 0x80 would disable change something else but leave the backup beep enabled.... I guess not.
    0x01 = 0000001
    0x02 = 0000010
    0x04 = 0000100
    0x40 = 0100000
    0x80 = 1000000
  8. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    Here's another few to try:
    07 c0 3b a7 c0 Seat belt warning for both driver and passenger.
    07 c0 3b a7 40 Seat belt warning for driver only.
    Untested WAG:
    07 c0 3b a7 00 Seat belt warning disabled?
    2 people like this.
  9. Spartane
    Spartane Member
    149
    43
    Mississauga, Canada
    Thank you, thank you!
    I am very pleased to finally get rid of that annoying backup beeping! My dealer refused to change it so I'm extremely happy to have been able to do it myself via the Scangauge II!
    I also added the AMP Xgauge and it too seems to be working correctly. It will be most interesting to observe this while I'm driving to work tomorrow.
    Thanks again to everyone involved for making this work!
  10. Spartane
    Spartane Member
    149
    43
    Mississauga, Canada
    Add me as another who would like to have his headlights turn off immediately instead of having to wait for 30-seconds. Seeing is believing and I don't like waiting around for it to happen, particularly with the cold weather we're having right now.
  11. adrianblack
    adrianblack Member
    447
    187
    Los Angeles
    I will give these a try tonight! Going out for drinks. (walking, LOL!)
  12. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    You deserve a drink, good work to RobH and Adrian and everyone else who helped out. :)
  13. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Yes, here here. Once that guy gets his ODB scanner and Rob and Adrian get some of the data, the Gen III will be good as cracked.
  14. adrianblack
    adrianblack Member
    447
    187
    Los Angeles
    Once again RobH comes through! These work perfectly as well! I couldn't test the passenger seat belt warning, but since 00 disabled the driver's side, I assume it's gone as well. I drove up to about 20mph and unclicked my belt. The warning light came on but no beep. I set it to C0 and tried again and sure enough, beeping.
    You still get the initial beeping when you first turn on your car. Connect your seatbelt before hitting start to disable that. :)
    Query Seat Belt Setting (stock result is C0)
    TXD: 07c021a7
    RXF: 046115a70000
    RXD: 2808
    MTH: 000100010000
    Set Seat Belt Setting Disable driver and passenger
    TXD: 07c03ba700 (or change last 00 to C0 for stock, 40 for passenger disable)
    RXF: 047b15a70000
    RXD: 2008
    MTH: 000100010000
    3 people like this.
  15. adrianblack
    adrianblack Member
    447
    187
    Los Angeles
    It's all RobH -- I simply tested the data he provided. So my hats off to him for snooping the Techstream data. :)
    I looked through the service manual to see what else Techstream can change and there isn't much else that is interesting....
    It's probably possible to create a XGAUGE to put the car in Maintenance Mode -- helpful when working on the engine. (It stops the engine from auto-stopping.) You can do it without any tool, you just have to enter a sequence on the pedals which could be bothersome if you're doing things like adjusting the vales, etc.
    I did order myself an ELM327 USB interface -- my old gateway is old and doesn't support CAN. I really have no experience doing anything with CAN but maybe I'll be able to figure out a few things. (I doubt it, though, haha -- considering there are a lot of experts working on it too and progress seems very slow.)
    The best way to glean data is to snoop techstream as RobH did -- as it can pull so much info out of the car.
  16. fuzzy1
    10,461
    The brain said to wait until other suckersXXXXXXXvolunteers tested this first. The heart said do it.
    So I did it. These and the reverse single beep command seem to be working on mine.
    Any idea what the actual injector volume units are? If that is volume per stroke, I'm guessing it is off (too high) by about one decimal place. More observation, including comparing this against GPH and RPM, during tomorrow's commute.
  17. adrianblack
    adrianblack Member
    447
    187
    Los Angeles
    Everyone, just a friendly reminder:
    Since this XGAUGE changes a value in the car's ECU, please DOUBLE and even TRIPLE check the XGAUGE before you use it. If you have it programmed incorrectly, you could inadvertently change a value into some other function we don't know about with unknown results.
    Once you are done using it, remove the XGAUGE from the ScanGauge II by setting the first digit to "blank."
    I am confident, though, that using this to change the reverse and seatbelt beep is safe. RobH's data was very clear on what Toyota Techstream is doing and we are basically replicating it. Just make sure you enter the XGAUGE correctly. :)
    /soapbox
  18. frenchie
    frenchie Member
    150
    48
    France, not far from PARIS
    I use with success the following formulas (metric)
    • FuelFlow_mLS = Inj_mL * ICE_RPM / 9 600 000 '------- unit is(mL/S)
    • FuelFlow_L/H =FuelFlow_mLS * 3,6 '------------unit is (L/H)
    • mpg1 = Speed / FuelFlow_L/H '---------------unit is (kM/L)
    • mpg2 =100 / mpg1 '----------unit is (L/100kM)
    green Units :
    mL/S = milliliter /Sec
    L/H = Liter /Hour
  19. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Are y'all sure you're not chasing injector *ms*, rather than
    *mL*? Milliseconds would actually be a somewhat more useful
    figure, as it's an almost direct indication of your torque
    plateau as the engine starts taking on load.
    _H*
  20. adrianblack
    adrianblack Member
    447
    187
    Los Angeles
    I would rather see pulse width for that reason ... but it seems this metric is mL. But what makes it essentially useless is that it keeps reading the last value when the injectors are shut down, so you can't even verify warp stealth.
    I would assume if we found the pulse width it would zero out when no fuel was going in.
