SCARY; gas pedal stuck, dropped into "b" gear
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by spinjunkie53, Sep 9, 2006.
  1. spinjunkie53
    spinjunkie53 New Member
    50
    Long Island, NY
    :eek: Scary experience today.. .had to pass someone and hit the gas pedal, after I passed and let my foot off the gas, the car was still speeding. wasnt sure what was going on, so i stepped on the brake but the engine was still revving. finally reached down and saw that the gas pedal was stuck and had to pull it up. also noticed that it was in 'b' gear.. I have never used 'b' gear before so I am assuming it must have automatically switched into that gear when the gas pedal was stuck while I was trying to brake? I was very lucky in that there was no one in front of me nor behind me at the time.
    I thought I had read some posts a while back about prius and stuck gas pedals, but couldnt find anything in my search on the forum. Now I am afraid to step on the gas with any amount of pressure for fear of it getting stuck again. Anyone else ever have this problem?
  2. brandon
    brandon Member
    771
    Manhattan, KS
    nope, but here's what I suppose happened. The floormat came unhooked, moved and got stuck on the gas pedal. In the scramble to get the gas pedal "unstuck," you inadvertantly bumped the gearshift downward, putting the Prius into "B" operation.
    Just my guess.
  3. angeleno
    angeleno New Member
    Seattle
    I
    Bad guess Brandon. Prius gas pedal can stick upon hard acceleration. It has nothing to do with floor mats. It's a potentially fatal situation, so shouldn't be so quickly dismissed. Better advice is to not panic and then apply the brakes.
  4. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,994
    Fort Lee, NJ
    BTW, this is over 3 years old thread.
    2004 - 2009 Prius was not affected from the gas pedal recall but only the floor mat recall.
  5. PriusRoadWarrior
    76
    16
    Wisconsin
    To stop the engine you need to hold the START/OFF button down for a minimum of three (3) seconds.
  6. patsparks
    10,664
    567
    Adelaide South Australia
    Why not just select neutral? Engine drops to near idle once neutral is selected even at full throttle. Takes half of one second.
  7. larycham
    larycham New Member
    Pensacola, FL USA
    As a new member to the forum, forgive me if this has already been covered but I am unable to find it.
    In December we Prius owners received a notice about the gas pedal sticking with an explanation that the cause was the floor mat. The suggestion was that we simply remove the mat and drive on safely. Now with the latest news about Toyota accelerator problems, I am confused even though I understand that production of the Prius is not being halted. Am I to believe that Toyota cars have two problems with accelerators sticking--one involving the floor mat and another more basic to the accelerator device itself?
    Thanks for the answer. Or, just refer me to a previous post that answers my question if you can.
  8. ronhowell
    ronhowell Active Member
    681
    32
    Cypress, CA.
    Forget previous posts. Just stick your head down into the foot-well and work the accelerator pedal with your hand. You won't break anything! But you will be able to tell if there is any tendency for the accelerator to stick in an any open position rather than return the closed stop.
    If all seems well, there is nothing to worry about. After all, you have had the car for 6 years without problems.
    2 people like this.
  9. Flying White Dutchman
    4,374
    313
    the prius is only involved in the floor mat problem not the gas pedal problem.. as of today.. maybe it can change.. keep a eye on the news.
    but nothing to wurry
    just shift in to N neutral and apply the brakes
  10. richard schumacher
    7,663
    1,038
    United States
    The Prius pedal uses an electronic position sensor, the other models use a mechanical linkage. Different mechanisms, different problems, though both can be affected by out-of-position floor mats.
  11. hill
    8,084
    reviving dead threads ... who are these people?!
    :p
  12. sub3marathonman
    sub3marathonman Active Member
    557
    75
    I'll tell you in 2016. :D
  13. DeadPhish
    DeadPhish Senior Member
    2,010
    353
    Outer Banks of NC.. Retired to play golf and poker
    I think that there's a coordinated effort by certain groups or companies to be more agressive in going after the competition via the internet. From GM's own words I think that they are the most likely candidate, along with the help of the UAW. Since mid-December there has been a sudden influx of new posters coming out of the woodwork to highlight every single complaint and issue and trying to create a firestorm of protest against Toyota.
    The Camry, Corolla and Prius are prime targets. These posters pose as 'new Toyota xxxx owners' who are suddenly against everything that Toyota stands for in every product line from Trucks to hybrids to cars.
    I am a betting man and I'd bet $$$ to donuts that this is the case.
  14. Hidyho
    Hidyho Senior Member
    2,698
    529
    2018 Prius
    Don't be so quick to dismiss this problem by blaming the poster, I understand its nice to pretend nothing it going on, but something is, otherwise Toyota wouldn't be trying to fix and find out where the problem is.
  15. DeadPhish
    2,010
    353
    I didn't blame any poster I remarked on a noticable change in the types of posters and the tone since mid-December. If the posters like one herein starts going off on the Tundra and Camry and sludge while the Prius has none of these known issues that to me is a certain tipoff.
    But yes you are absolutely right that a questioning post from a new owner and new poster is not an indictment. It's simply a question like we all had when we all started here.
    It's pretty easy to see the difference in the two though, one becomes an argument on Toyota in general one is focussed on a particular question.
  16. Hidyho
    2,698
    529
    2018 Prius
    Did you notice that the original poster had 49 posts? That doesn't make him an automatic sign on to post bad stuff about the Prius or Toyota, its very possible he experienced what he experienced. Do I think Toyota is bad, no, not by a long shot, do I think this is a real problem, must be, Toyota is working on a fix, do I think the Prius might be involved now or at some point, yes I do.
  17. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    A while ago I would have thought your post was hysterical paranoid crazy talk but I'm on another Forum for my other car (Crown Vic Net) and most posters there have a very scary hatred for Toyota.
    I mean HATRED. Like Toyota is the reason for all of there an Detroits problems. They all hope Toyota dies an ugly death.
    Some posts on there seemed giddy that Toyota's were killing people.
    I tried to point out there hating the wrong people.
    Detroit has problems because they made a sh*tty car for years.
    Toyota revolutionized manufacturing with there "LEAN SYSTEM" car building and there 6SIGMA quality control.
    American car companies stuck there head in the ground for years and prayed America would remain stupid and hooked to the oil tit.
    And we didn't let them down.
    Plus GM is incredibly corrupt.
    Which works out pretty good because so are most of our elected officials.
    GM built a viable electric car more than 10 years ago. Soon as the market showed interest they sold the most important part the battery technology to the oil companies.
    Wow...that worked out pretty good.
    Oil companies killed that technology right quick. DONE.
    All under GH Bush's admin with Cheney riding shotgun. All of them either on Oil Boards or Car Maker Boards.
    Just ridiculous. They probably needed dollies to wheel the bags of cash back and forth.
    And then GM although seeing interest in the EV product dropped that line immediately.
    Meanwhile Toyota saw what GM had produced. Realized Hybrids were the future and immed. began developement of the Prius and there own developement of battery technology and the THS.
    Who Killed the Electric Car? - Wikipedia, the free encyclopedia
    I don't believe in modern times we have ever seen more corruption on both sides than we have seen in the last 10 years from our elected officials. Which is why our country is in the fix its in right now. And short of Banning all lobbyists from Capital hill I see no
    future in our present system.
    But yes to your post. I have a feeling your right. It would not surpise me a bit. It has really become that ridiculous right now.
  18. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,796
    Undisclosed Location
    LOL! Yes this is a 3 year old thread! Someone found a dried out old piece of wood they wanted to throw on the panic and fear fire.
    The Prius is manufactured in Japan, the pedal problem does not apply...nice try whomever...
  19. PazPrius
    PazPrius New Member
    72
    San Diego
    GM didn't just drop those EV1's they SHREDDED THEM!!!
    I'm confused didn't this Change that was voted in promise to ban lobbyists and not allow lobbyists into the administration. Also have open and televised debates in the congress?
  20. john1701a
    john1701a Prius Guru
    12,749
    5,243
    57
    Sadly, I've seen the hostilty grow. As Prius penetrates deeper into the mainsteam, the more they are reminded of their troubles. Lack of progress really hits home when you're seeing more and more on the road. They're frustrated and need a scapegoat and/or the competition to also struggle.
