Scary Prius Moments...
Discussion in 'Gen 3 Prius Main Forum' started by 2010_Prius_I_White, Oct 23, 2012.
  1. 2010_Prius_I_White
    2010_Prius_I_White Junior Member
    62
    Las Vegas, NV
    I
    What are some of the scary moments you've had in your Prius? I will start it off...
    1.) Drifting in the rain by accident on a left turn
    2.) Flashing single line of gas... yea...
    3.) Finding joy in the indent on the backside of the cruise control lever... it's just SO COOL that they would think of that! It reminds me everyday why I bought a Prius, but it is kinda scary... lol
  2. xliderider
    xliderider Senior Member
    7,849
    3,103
    Honolulu, HI
    Seeming almost invisible to other drivers, who change lanes on the freeway into my lane without checking their blind spot. It's a good thing I drive defensively and can almost always tell when they are going to do it. Also, it helps that I installed the FIAMM Freeway Blaster HI/Lo horns into the Prius. It sure gets their attention when I have to blast them to let them know I'm there. :(
  3. OceanEyes
    OceanEyes Active Member
    527
    424
    Southeastern Connecticut
    I like the idea of the Freeway Blaster horns... folks switching lanes without checking their blind spot might also have to switch their Depends out for a clean pair, especially when they realized the blast came from a Prius.... :whistle:
    2010_Prius_I_White likes this.
  4. 2010_Prius_I_White
    62
    Las Vegas, NV
    I
    Is that like a really loud horn or something?
  5. Cristino
    Cristino Junior Member
    46
    24
    Bayamon, Puerto RIco
    Discovering that the antilock system thinks an uneven paved road is a wet road and applies brake force accordingly. Learned to start braking from farther away, also helping the regen system. :)
    2010_Prius_I_White and OceanEyes like this.
  6. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    The first time the regen brakes switched off on rough pavement. (Answered here - now I expect it.)
    The first time I walked into the garage and heard the purge cycle running in the middle of the night. (Answered here - normal.)
    The first time I had the rough start was AFTER I read about it here, so I knew what it was and it wasn't scary - just annoying.
  7. NargilFenris
    NargilFenris Junior Member
    75
    Wherever Uncle Sam sends me
    The very first time I test drove a Prius and the gas engine shut off (I knew nothing about the Prius aside from seeing the est. fuel economy on the sticker and that it had an eletric motor with a regular engine). It reminded me to much of when I drove a truck that had a faulty idle engine sensor that would shut off the engine when it idled to low.
  8. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    420
    Whereabouts Unknown
    Either that, or a new medication that functions like super-Viagra. ;)
    2010_Prius_I_White and WE0H like this.
  9. Selzier
    Selzier Whee!
    148
    51
    1. Staring at the HSI so intently to get better FE that I almost went into a ditch
    2. Having an 18 wheeler right up my back end because I was going too slow on the freeway (maybe he was trying to draft me?)
    Probably not as bad as some folks, but #2 really freaked me out.
  10. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    Do the 2010s have VSC? It should not have drifted very far. Usually just a little jerk, followed by beeps and the flashing skid control icon, the car will slow some, and then you are on your merry way...
  11. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    LOL @ Drafting.
    I have found my DRCC awesome to draft 18 wheelers with on the one bar (100 ft) setting.
    Selzier likes this.
  12. miscrms
    miscrms Plug Envious Member
    2,076
    523
    Phoenix, AZ
    That used to get me too :) My college car had something sticky in the carb and used to totally fail to idle from time to time. Got pretty good at feathering the gas pedal with the side of my foot while simultaneously pressing the brake and clutch when stopped. Was also hyper sensitive to it stalling while rolling to a stop, so I could usually pop the clutch and restart before stopping :) Every so often when the ICE would quit on the Prius I'd try to pop the clutch to restart before remembering I didn't have one anymore :D
    Rob
  13. 2010_Prius_I_White
    62
    Las Vegas, NV
    I
    It does, I just really threw it into the turn that time. :D
  14. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    The first time you are forced to use the Panic Mode braking in bumper-to-bumper traffic and you stop much quicker than the car on your bumper. :eek:
    2010_Prius_I_White, Selzier and WE0H like this.
  15. Selzier
    Selzier Whee!
    148
    51
    The 3 doesn't have DRCC :mad:
  16. MrChristian
    MrChristian New Member
    31
    Washington
    One of the scariest moments for me was driving from Chicago to Seattle... Around Montana I was feeling tired so we stopped at a rest area and fell asleep with the AC on..... I would hear the ICE kick on intermittently. I totally lost track of the time, when I finally got around to, we were down to 1 bar of gas...
    I don't know if you're familiar w/ Montana or not, but on the road, gas stations are few and far between.
    We had to back track to find a place for gas... I'm sure we made it on vapors alone...
  17. OceanEyes
    527
    424
    Drove Montana back in the Middle Ages... not much there other than impressive thunderstorms inbetween gorgeous mountains and grizzly traps from my youthful memories - when they can harness that lightning power through generators to something we can safely use... what a day it will be!:cool:
  18. Jin
    Jin Blizzard PRIUS 2010, Nav+ solar roof
    174
    West Virginia
    1) Driving behind a 18 wheeler and feeling the turbulence on front end along with swaying and rattling of the body. Really need to hold tightly on to that steering wheel if you don't want to drive to a ditch.
    2) Driving beside front end of 18 wheeler and feeling their side wheel turbulence trying to drive you off your lane.
  19. Tim Bender
    Tim Bender Member
    134
    44
    Occasionally the TC indicator lights up and I lose regen braking, which is scary since the friction brakes by themselves are very unresponsive.
    Figured out this happens when I leave my phone syncd to a kiwi obdii adapter when I shut the car off (to run into a store real quick, for example) then return to the car and drive again.
    phone using an app
  20. Whiteyprius
    Whiteyprius Active Member
    389
    105
    North Carolina, USA
    First time ever employing ABS in any vehicle, but when bozo looked straight at me talking on her cell phone, then pulled from side road RIGHT in front of me - ABS did wonderfully - Totally impressed with how quick she stopped!
    BlackBerry 9930 ?
